Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
1972
4722904483 11/1971 L80E 4539523 ![]() ![]() ![]() ![]() |
DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
is that the pick n pull on Monterey?
looks like there might be some decent parts there. |
Mike Bellis |
1976
4762902724 11/1976 L13K 4549039 ![]() ![]() ![]() ![]() |
Mike Bellis |
Mike Bellis |
I bought the Targa from the 72. It was mint! only a little dirty. even the felt headliner is perfect. $50
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,150 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
914's at San Jose Pick N Pull, Pictures and VINs Thank you Sir! Added to the VIN database ... (IMG:style_emoticons/default/smilie_pokal.gif) Andy |
tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
now the white one is missing the bilstein shocks, the speedo and a few misc parts. the bilsteins had new 100lb springs and were only 16.99 each for the assy
there is not a ton of good stuff (for me) the front rotors looked good, but need cleaning. the calipers on the '76 may be good. beware of the hornets living in the white car pass door |
carl k |
Member ![]() ![]() Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None ![]() ![]() |
Mike Bellis |
realred914 |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None ![]() |
thanks kg6dxn!!!!!!!
tradisrad |
Hey Carl,
Dave said someone else showed up. I was inside paying when he ran back to get the thermostat bellows. Too bad I did not see you. He told me someone else showed up. The thermostat was $1.80! What did you buy? -Rob |
carl k |
Rob-
I had been there the afternoon before (in fact I said hi to the guy who bought the targa top and took the pictures), but didn't have metric wrenches with me so only got one bolt off the thermostat. I came back the next day and saw two guys pulling parts. I was waiting till you both were done since it's never comfortable to have two people working over the same hulk. Only when you were leaving did I figure out it was you. I saw the thermostat missing and since Dave had the part wrapped up in a rag, I deduced it was greasy hence the thermostat guess. I needed the "taco plate" and sensor for my console install. I also grabbed the column switches in my never-ending attempt to have self-cancelling turn signals. Carl |
tradisrad |
Carl,
too bad you did not approach sooner it would have been good to see you. Dave was stoked that one bolt was missing from the bellows; he has bad hands and can't wrench anymore, I was in my work jeans (Dave brought me a dirty shirt to wear) so I would not have crawled under the car to remove it. good deduction. We got the employees to remove the top shock nuts with thier impact wrench; I could not hold the strut and remove the nut with the tools we had. take it easy -Rob |
Mike Bellis |
Like a pack of Wolves. Stripping the carcase to the bone.
tradisrad |
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
beware of the hornets living in the white car pass door ...Been there...got stung! (IMG:style_emoticons/default/laugh.gif) (another time....another car) |
Nürburg Nomad |
914Rubber.com! ![]() ![]() Group: Members Posts: 296 Joined: 30-March 10 From: Buckeye State Member No.: 11,536 Region Association: Upper MidWest ![]() |
I bought the Targa from the 72. It was mint! only a little dirty. even the felt headliner is perfect. $50 Wow, a deal! Plus that has to be one of the easiest and least time consuming parts to remove from a vehicle. I wouldn't mind having a spare targa top painted body color just to switch it up now and then! (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 13th March 2025 - 04:05 AM |
