2 Pages V < 1 2
> Valve Adjustment, ...why did I have zero clearance?
VaccaRabite
post Aug 10 2010, 09:34 AM
Post #21
En Garde!
QUOTE(jeffdon @ Aug 9 2010, 03:08 PM) *
Awe hell, i used the lobe method......494 cam, with 0.465 lift, 280 duration, 108 degree lobe center. Think i am ok?
I used to have that exact cam in my car, and did valves both ways to see if the opposing lobe method really worked. It worked perfect.
I am now using a cam very similar to the 494 (same lift, but longer duration on exhaust) and guess what. It still works.
All the folks that claim it does not work have probably never tried it to see for themselves. Whatever, its their car. I have tried both ways, and you will be fine using the opposing lobe method to set your valves.
Zach
ME733
post Aug 10 2010, 09:54 AM
Post #22
QUOTE(Vacca Rabite @ Aug 10 2010, 11:34 AM) *
Zach
..................If you are satisfied with getting an" approximation " in setting valve lash thats just fine. Other people may not . It is not as accurate as using the TDC method.... period.
bandjoey
post Aug 10 2010, 10:23 AM
Post #23
bandjoey
(IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif)
So, after all of this and several other posts on Pelican and Club, seeing that everyone has another opinion, will someone kindly (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) take out all the variables, and possibilities, and just write up a concise step by step for us inept adjusters and put it in the technical section next to Cap'n's valve adjustment write-up?
Thanks (IMG:style_emoticons/default/grouphug.gif)
VaccaRabite
post Aug 10 2010, 10:45 AM
Post #24
En Garde!
QUOTE(ME733 @ Aug 10 2010, 10:54 AM) *
Uh huh. Spending an evening doing this back to back TDC method and rocking method and getting the exact same results is a little more then "approximation."
But as I said. Your car, your time. Do what makes you happy. I have proven to myself that the opposing lobe method works, and it saves considerable time and effort, so I use it.
Zach
tomeric914
post Aug 10 2010, 01:49 PM
Post #25
One Lap of America in a 914!
(IMG:style_emoticons/default/wacko.gif) I've tried both ways. The opposing lobe method is inconsistent.
It worked for the 2 cams in particular that you have adjusted valves on which is great. You know it works for those, so stick with it.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 6th April 2025 - 07:31 AM
