Another amateur question (negative stripes) |
RonnieJ |
Aug 12 2010, 07:53 AM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
I just ordered new negative stripes and want to know the proper way of applying them without making a mess. On the site I am ordering from it says use soapy water and these are an adhesive backed stripe (IMG:style_emoticons/default/confused24.gif)
dr914@autoatlanta.com |
Aug 12 2010, 08:01 AM
914 Guru Group: Members Posts: 8,111 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I just ordered new negative stripes and want to know the proper way of applying them without making a mess. On the site I am ordering from it says use soapy water and these are an adhesive backed stripe (IMG:style_emoticons/default/confused24.gif) The little bit of soap (like ivory liquid) in the spray water bottle lets the stripe slide into place. It is "banked" against a straight blue tape line applied to the very bottom of the fender/door/quarter panel. The adhesive on the back still works and "glues" the stripe in place when it dries. Squeegee the extra water out of the stripe and then after the drying process, simply peal the front paper from the stripe. Finally cut between the front and rear of the door with a razor blade and you are done. |
RonnieJ |
Aug 12 2010, 08:03 AM
Many thanks George. Just ordered a set.
Lo-Fi Version | Time is now: 2nd January 2025 - 06:15 PM |
