FS - SS fuel lines, engine compartment lines,, all 4, fuel tank socks, sealing rings, FI hose clamps, grommets |
Wayne |
Feb 7 2017, 09:46 AM
SoCal-Bumblebee Group: Members Posts: 47 Joined: 29-January 16 From: Orange County, CA Member No.: 19,612 Region Association: Southern California |
PM sent
aggiezig |
Feb 7 2017, 11:52 PM
Porsche Wannabe Group: Members Posts: 319 Joined: 13-January 16 From: Los Angeles, CA Member No.: 19,557 Region Association: Southern California |
PM Sent.
sawdust |
Feb 15 2017, 07:42 PM
Newbie Group: Members Posts: 26 Joined: 21-January 17 From: Paint Rock, TX Member No.: 20,770 Region Association: None |
I've made this set, it's 9.5 mm SS .028 tubing, and 8mm SS .028. The ends have beads to keep the fuel lines from blowing off. I've bent it and test fitted the prototypes upon my car. They fit very well IMHO. Engine Compartment $22 each + $10 shipping Engine Compartment set (2 lines) $40 + $10 shipping Tunnel fuel line each $38 + $14 shipping Tunnel fuel line (set of 2)$70 + $16 shipping complete your installation with the following,,, Fuel tank fuel sock $10 Fuel tank sealing ring $.50 each Firewall grommets $2.00 each Engine shelf grommets $4.00 each FI hose clamps $2.00 each or $1.75 each(if you order more than 10) Shipping included if you buy a set of lines. Can these be installed with the engine in? Thanks for looking! |
Rotary'14 |
Mar 1 2017, 05:15 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
I've made this set, it's 9.5 mm SS .028 tubing, and 8mm SS .028. The ends have beads to keep the fuel lines from blowing off. I've bent it and test fitted the prototypes upon my car. They fit very well IMHO. Engine Compartment $22 each + $10 shipping Engine Compartment set (2 lines) $40 + $10 shipping Tunnel fuel line each $38 + $14 shipping Tunnel fuel line (set of 2)$70 + $16 shipping complete your installation with the following,,, Fuel tank fuel sock $10 Fuel tank sealing ring $.50 each Firewall grommets $2.00 each Engine shelf grommets $4.00 each FI hose clamps $2.00 each or $1.75 each(if you order more than 10) Shipping included if you buy a set of lines. Can these be installed with the engine in? Thanks for looking! Yes the tunnel lines can be installed with the engine in. The higher up you get the car,, the easier it will be. And you really should remove the fuel tank to make the job easier. -Robert |
arvcube |
Apr 5 2017, 08:21 PM
Member Group: Members Posts: 170 Joined: 25-September 07 From: poway, ca Member No.: 8,147 |
Just installed my set. Easy install. Jacked up the rear on stands, didn't have to remove anything. Fished it through. The ends snapped right into the existing clips. Thanks for a great product Robert!
emmy914 |
Apr 22 2017, 10:42 AM
Newbie Group: Members Posts: 2 Joined: 22-April 17 From: Perrysburg, Ohio Member No.: 21,039 Region Association: Upper MidWest |
I've made this set, it's 9.5 mm SS .028 tubing, and 8mm SS .028. The ends have beads to keep the fuel lines from blowing off. I've bent it and test fitted the prototypes upon my car. They fit very well IMHO. I am in need of replacing the fuel lines from the tank back to the motor and engine compartment lines- all. Also, all of the lines on the fuel injection system. I have no idea of the total number of clamps need. I would want a few extra. Do you sell the injection line as well ??? 1975 2.0. The long term project is to up hp by a modification of 2.0 or swap for more cylinders - V8. If that is a larger size line I am going to do that now. I want everything to do it right....Fuel tank fuel sock, Fuel tank sealing ring, Firewall grommets - how many 2 ??? Engine shelf grommets - how many ??? I can be reached at 419 276 2299. Thank you and God Bless Jim Engine Compartment $22 each + $10 shipping Engine Compartment set (2 lines) $40 + $10 shipping Tunnel fuel line each $38 + $14 shipping Tunnel fuel line (set of 2)$70 + $16 shipping complete your installation with the following,,, Fuel tank fuel sock $10 Fuel tank sealing ring $.50 each Firewall grommets $2.00 each Engine shelf grommets $4.00 each FI hose clamps $2.00 each or $1.75 each(if you order more than 10) Shipping included if you buy a set of lines. Thanks for looking! |
seanpaulmc |
Apr 23 2017, 06:42 PM
Member Group: Members Posts: 371 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
PM sent
sholman5 |
Apr 30 2017, 05:15 PM
Kraut burner Group: Members Posts: 189 Joined: 11-September 16 From: Ormond beach, Fl. Member No.: 20,391 Region Association: South East States |
sholman5 |
May 13 2017, 06:07 AM
Received mine yesterday. Great workmanship. Install was a breeze. Engine was out. Took me about 20 min to install including removal of old lines. If you don't have these lines and have the ability to replace them. DO IT.
Wyvern |
Dec 16 2017, 05:43 PM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
PM sent to OP.
Are you still putting the kit together ? |
slyder |
Jan 11 2018, 07:48 PM
Newbie Group: Members Posts: 10 Joined: 9-September 04 From: Cambridge, ON Member No.: 2,724 Region Association: Canada |
PM sent
Rotary'14 |
Jun 26 2018, 03:57 PM
Even though I am not actively posting,, I am still making these and responding to PMs.
Friendly bump. (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/icon_bump.gif) |
VintageExcellence |
Aug 21 2018, 02:07 PM
Member Group: Members Posts: 52 Joined: 27-August 04 From: San Diego, CA Member No.: 2,636 |
Robert, sent you a message, need a pair of lines
rhodyguy |
Aug 21 2018, 03:22 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,192 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
His email feature is active in his profile.
mb911 |
Jan 2 2019, 02:38 PM
914 Guru Group: Members Posts: 7,254 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Pm'd a while ago. No response? Not sure if this service is still offered?
JmuRiz |
Jan 3 2019, 01:22 PM
914 Guru Group: Members Posts: 5,504 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Yes it is, I got a set a couple weeks ago.
Maybe a full inbox? Give him another try and he should respond. |
rallysport70 |
Feb 9 2019, 04:36 PM
Member Group: Members Posts: 64 Joined: 1-May 09 From: Albany, NY Member No.: 10,321 Region Association: North East States |
PM sent
flmont |
Jun 15 2019, 03:20 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Do you make custom lines,I would like the ends bent in different directions..?? Thanks frank
Rotary'14 |
Jul 9 2019, 05:39 PM
Bump to let everybody know I'm still around.......
PMs work much better than email for me because I lost access to my old email account. and not sure how to change it,,,,, (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) |
ndfrigi |
Jul 9 2019, 05:47 PM
Advanced Member Group: Members Posts: 2,959 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Bump to let everybody know I'm still around....... PMs work much better than email for me because I lost access to my old email account. and not sure how to change it,,,,, (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) Robert, to change email settings: Go to Control Panel then Go to Option then select Change Email. Anyway, I will be ordering tunnel fuel lines soon again. |
Lo-Fi Version | Time is now: 26th November 2024 - 11:40 AM |
