FS - SS fuel lines, engine compartment lines,, all 4, fuel tank socks, sealing rings, FI hose clamps, grommets |
rhodyguy |
Jan 31 2016, 06:58 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,192 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Helped a fellow member install the tunnel lines today. If you buy the whole kit, EVERYTHING is right there. The lines slip into the stock clips on the firewall like butter. Tell the guy you're helping to take off the pass rear tire. (IMG:style_emoticons/default/dry.gif) Repeatedly. (IMG:style_emoticons/default/rolleyes.gif) He will listen to you later. Then it will take about 10 minutes to fish the lines thru. You'll never get the 30+minutes you wasted back before the tire removal. (IMG:style_emoticons/default/biggrin.gif)
Jan 31 2016, 07:44 PM
914-6 GT in waiting Group: Members Posts: 19,601 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Have you thought about offerin stainless, pre-bent brake lines. Many of the originals are NLA and no one seems to offer a pre-formed kit. Sure, you can buy straight tubes and bend your own. But for those of us who are 3-D deficient, they always come out looking bad. Pmbperformance makes them |
Rotary'14 |
Feb 5 2016, 12:21 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
malcolm2 |
May 10 2016, 04:45 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I put together an install video,,, http://www.youtube.com/watch?v=hxFRQTWLetw There is a still image where I show a drill, WD-40 and the stock grommet. You only need this if you are using a 9.5mm return line. what happened to your video? |
Rotary'14 |
May 17 2016, 04:05 PM
I put together an install video,,, http://www.youtube.com/watch?v=hxFRQTWLetw There is a still image where I show a drill, WD-40 and the stock grommet. You only need this if you are using a 9.5mm return line. what happened to your video? I contacted youtube and as of today 5/17/2016 the video seems to work,,, with sound too! |
ndfrigi |
May 17 2016, 04:19 PM
Advanced Member Group: Members Posts: 2,959 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
I put together an install video,,, http://www.youtube.com/watch?v=hxFRQTWLetw There is a still image where I show a drill, WD-40 and the stock grommet. You only need this if you are using a 9.5mm return line. what happened to your video? I contacted youtube and as of today 5/17/2016 the video seems to work,,, with sound too! Hi Robert, you tube video still not working. |
Rotary'14 |
May 24 2016, 04:12 PM
I put together an install video,,, http://www.youtube.com/watch?v=hxFRQTWLetw There is a still image where I show a drill, WD-40 and the stock grommet. You only need this if you are using a 9.5mm return line. what happened to your video? I contacted youtube and as of today 5/17/2016 the video seems to work,,, with sound too! Hi Robert, you tube video still not working. Thanks Noel,,,, OK,,, I am sure the video works now,,,, cool music is gone and slow soothing music is now in it's place. At least the video is watch-able again. |
rhodyguy |
May 25 2016, 01:36 PM
Worked for me.
Mueller |
Jun 1 2016, 10:53 AM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Video works....now reply to my PM so I can send you some money for parts!
(IMG:style_emoticons/default/smile.gif) |
Mueller |
Jun 25 2016, 11:15 AM
Got the parts, they look great and packaged perfectly.
thanks |
Papermaker |
Jul 23 2016, 05:29 AM
Newbie Group: Members Posts: 35 Joined: 19-January 04 From: Custer WI. Member No.: 1,578 |
Hi Rotary '14--
PM sent. --Papermaker |
Optimusglen |
Jul 23 2016, 10:41 AM
Senior Member Group: Members Posts: 921 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
I'm interesred in a single fuel line for the tunnel. Running carbs and no return line.
jacquot |
Jul 27 2016, 03:08 PM
Member Group: Members Posts: 59 Joined: 12-March 15 From: Huntington Beach / Paris Member No.: 18,512 Region Association: Southern California |
Hi Robert,
Finally got around to replacing my cracked original fuel lines and installing the new fuel lines I bought from you, as I now have the engine and fuel tank out of the car. Perfect fit, grommets and lines went in very easily, less than 10 min, with no muss, no fuss. Thanks again, Jacquot |
Rotary'14 |
Jul 28 2016, 03:05 PM
Hi Robert, Finally got around to replacing my cracked original fuel lines and installing the new fuel lines I bought from you, as I now have the engine and fuel tank out of the car. Perfect fit, grommets and lines went in very easily, less than 10 min, with no muss, no fuss. Thanks again, Jacquot I am glad to hear that you found it so easy! |
mmascari |
Aug 21 2016, 05:14 PM
Member Group: Members Posts: 322 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
Bump on great product. Easy install and look great!
jet1 |
Aug 25 2016, 05:39 PM
Member Group: Members Posts: 311 Joined: 16-June 04 From: Accord,NY Member No.: 2,213 Region Association: North East States |
The lines arrived today and look very nice. I can't wait to get them installed. Thanks for the great communication and fast shipping.
Keith |
fullerton914 |
Oct 23 2016, 08:03 PM
Newbie Group: Members Posts: 3 Joined: 29-August 13 From: fullerton, ca Member No.: 16,323 Region Association: Southern California |
Robert:
I spoke with you today at Bruce's swap met. I bought a set of your ss fuel line about a year ago - still have not installed yet. I am ready now . the video is helpful I want to purchase your rubber firewall grommets. Please provide instructions at your convenience so I can complete the transaction Thanks Steve |
Rotary'14 |
Oct 25 2016, 10:20 AM
Robert: I spoke with you today at Bruce's swap met. I bought a set of your ss fuel line about a year ago - still have not installed yet. I am ready now . the video is helpful I want to purchase your rubber firewall grommets. Please provide instructions at your convenience so I can complete the transaction Thanks Steve Hey Steve,,, I sent you a PM and an email. |
morsmanlaw |
Dec 26 2016, 10:18 PM
Newbie Group: Members Posts: 39 Joined: 27-August 13 From: Jenks, OK Member No.: 16,308 Region Association: Southwest Region |
PM sent.
peetgee |
Dec 27 2016, 02:07 PM
Newbie Group: Members Posts: 2 Joined: 16-March 16 From: Belgium Member No.: 19,759 Region Association: Europe |
Pm sent
Lo-Fi Version | Time is now: 26th November 2024 - 11:29 AM |
