hot_shoe914 |
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,806 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None ![]() |
I know why you can't get it fixed. Because you are in here playing on the damned (IMG:style_emoticons/default/type.gif) instead of being outside working on the dang car! (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/poke.gif) Now quit (IMG:style_emoticons/default/sheeplove.gif) around and go (IMG:style_emoticons/default/smash.gif) the blasted thing!
poorsche914 |
T4 Supercharged ![]() ![]() ![]() ![]() Group: Members Posts: 3,130 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States ![]() |
I currently have no way to do electrical tests. With so much not working it has to be a common feed or relay or something (IMG:style_emoticons/default/dry.gif) just gotta figure it out ( sent from my android ) (IMG:style_emoticons/default/dry.gif)
dvtorr |
Newbie ![]() Group: Members Posts: 16 Joined: 5-September 10 From: Colorado Member No.: 12,138 Region Association: None ![]() |
is it a click or more like a clunk sounds? Same thing happened to me and Idk if my motor is seized up or not. Right now Im stuck on this.. Figuring out the problem isnt easy! what is a BFH treatment for the starter? For me, it was a click at the starter. I removed the starter and gave it the BFH treatment which is banging on it with a hammer. Whatever was stuck came unstuck and it has been working ever since. (IMG:style_emoticons/default/confused24.gif) As far as my electrical issue - hooked up the center console gauges and none of them work. Well, except for the clock (IMG:style_emoticons/default/blink.gif) Any idea what one main thing might be keeping all the gauges and blinkers and dash lights from working? As an added note, the hazard lights work but does not show on the indicator on the tach. Did you ever try to push start your car before you gave it the BFH treatment? |
hot_shoe914 |
I currently have no way to do electrical tests. With so much not working it has to be a common feed or relay or something (IMG:style_emoticons/default/dry.gif) just gotta figure it out ( sent from my android ) (IMG:style_emoticons/default/dry.gif) Make a test light. All you need is a small lightbulb, an ice pick, some tape, elctrical wire and an alligator clip. |
poorsche914 |
poorsche914 |
After mulling this over and searching the forums for hints, (IMG:style_emoticons/default/head_hurts_kr.gif) I still don't know why the gauges, wipers, turn signals, etc do not work.
The car starts and runs but the gauges do not work (IMG:style_emoticons/default/hissyfit.gif) Hazard switch works but the indicator on the tach does not blink. The turn signals do not work. The wipers do not work. The A/C fan does not work. The fuel gauge & low fuel light do not work. These all worked when I first put a battery in the car a few months ago. For a period of time recently, I noticed when I activated the turn signals, they only caused a bzzzzz noise and no indicator light. I have not messed with the wiring beyond replacing the FI harness and the relay board. Swapped out four different boards. Could the ignition switch be faulty? Thanks for any suggestions, etc. |
hot_shoe914 |
After mulling this over and searching the forums for hints, (IMG:style_emoticons/default/head_hurts_kr.gif) I still don't know why the gauges, wipers, turn signals, etc do not work. The car starts and runs but the gauges do not work (IMG:style_emoticons/default/hissyfit.gif) Hazard switch works but the indicator on the tach does not blink. The turn signals do not work. The wipers do not work. The A/C fan does not work. The fuel gauge & low fuel light do not work. These all worked when I first put a battery in the car a few months ago. For a period of time recently, I noticed when I activated the turn signals, they only caused a bzzzzz noise and no indicator light. I have not messed with the wiring beyond replacing the FI harness and the relay board. Swapped out four different boards. Could the ignition switch be faulty? Thanks for any suggestions, etc. (IMG:style_emoticons/default/confused24.gif) |
jt914-6 |
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,787 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States ![]() |
Check all the large guage wires, four, that connect to the large battery cable on the positive battery terminal. Those four power all the guages, fuse panel, ect. Make sure they have a good solid connection to the battery. One or so may have a bad connector end.....check them one by one.....remove from battery connection and check....
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,145 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Could the ignition switch be faulty? Thanks for any suggestions, etc. It could be the ignition switch but then you don't want to start changing parts without testing them. Electrical problems can be cured many times by cleaning the contacts on the fuses, checking, cleaning and tightening the ground points. The number of times you will have electrical problems is somewhat proportional to how long you own your 914. I suggest buying a volt-ohm-meter. You will need it over and over again with your 914. There have been times with my 914 and my 911 where I carried my volt meter with me while diagnosing intermittent problems. For us to help you, many times we will need to check voltages or resistance at different places. You can find them at Home Depot, Radio Shack, Frys, any electrical supply store for anywhere from $10 to $200+. $25 to $50 will buy you a usable VOM. Buy one or borrow one and you can start checking voltages in different places. It's a lot easier than guessing. |
poorsche914 |
jt - will check those wires tomorrow. Thanks for the suggestion.
spoke - I plan on buying a volt/ohm meter soon. The car has been sitting for probably 20 years since it operated correctly. I have noticed some cut wires. Who knows what all the PO did to this car. Looks like I may have to give up on having it roadworthy by MUSR and instead plan on going through the electrical and other systems in the coming months. I just wanna (IMG:style_emoticons/default/driving.gif) |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,224 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Bring it to MUSR and I will take a look at it for you. I am fairly good with electrical stuff.....
We can have a tech session on it. |
poorsche914 |
Bring it to MUSR and I will take a look at it for you. I am fairly good with electrical stuff..... We can have a tech session on it. |
poorsche914 |
Long story short, I had swapped out the fuel pump because I thought the old one was leaking. Haven't been able to get it running since the swap but did find a split fuel line (cause of the leak).
This morning, swapped the original pump back in and it fired right up but now... when I turn the key OFF the engine keeps running!!! The fuel pump is hot wired to the coil (PO) so I pull that and it quits. Plug it back on and the pump doesn't run until I turn the key. (IMG:style_emoticons/default/confused24.gif) Any ideas what may be causing this? |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
Just a guess, but your turn signal/emergency flasher that doesn't work the indicator lights and the "buzzing" sounds like the flasher relay/unit doesn't work. I'd also like to know why the engine keeps running after the key is turned off.
poorsche914 |
Just a guess, but your turn signal/emergency flasher that doesn't work the indicator lights and the "buzzing" sounds like the flasher relay/unit doesn't work. I'd also like to know why the engine keeps running after the key is turned off. OK, I am officially declaring my 914 will not be at MUSR. (IMG:style_emoticons/default/sad.gif) Started it, drove it up and down the driveway a couple times, turned it off. Now it won't start. Fuel pump is intermittent (powered off the coil) when key is ON. Sounds like bzzt bzzt bzzt. I need to go through the electrical system and find out what is going on. (IMG:style_emoticons/default/headbang.gif) Looks like I will be bumming a ride with someone (IMG:style_emoticons/default/dry.gif) At least I can take a ton of pictures while riding shotgun (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/driving.gif) |
jt914-6 |
Trailer it down if you can....as Clay said...there will be enough brain power to fix your problems...and enough jack stands.... (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/beerchug.gif)
poorsche914 |
Trailer it down if you can....as Clay said...there will be enough brain power to fix your problems...and enough jack stands.... (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/beerchug.gif) I was hoping to at least have it running and roadworthy to get it there for others to look at. Unfortunately, no trailer or vehicle to pull it with. (IMG:style_emoticons/default/sad.gif) |
jt914-6 |
How far away are you from Knoxville/Vonore???
poorsche914 |
poorsche914 |
Started swapping out relays on the board to see what would happen. Not sure if that was it or not but it did start up and ran for a couple minutes several different times. But each time the fuel pump seemed to get weaker and weaker until it finally died (IMG:style_emoticons/default/sad.gif)
Lo-Fi Version | Time is now: 2nd April 2025 - 11:40 PM |
