914 Subaru EG33 engine and WRX transaxle conversion, Finally finishing up |
BIGKAT_83 |
Sep 9 2010, 10:22 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Cable shifter for sure. I don't have any pictures of my linkage handy. I'll get some up the next time I'm home.
I really think the transaxle is the best part of the whole car. It shifts just like a new import car. The gearing matches the engine with a useable first gear and gives the car a complete different feeling. Now I'm thinking audi/boxster transaxle for my LS1 car. Found a pix Bob |
Andyrew |
Sep 9 2010, 11:09 AM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Very nice looking shifter setup! Did you buy or make it? Cost?
Also it looks like you still have the tailpiece on the trani, you converted that to FWD after the pic, right? Or is it running like that? |
BIGKAT_83 |
Sep 9 2010, 11:34 AM
Very nice looking shifter setup! Did you buy or make it? Cost? Also it looks like you still have the tailpiece on the trani, you converted that to FWD after the pic, right? Or is it running like that? Andrew I built the set up myself. The shifter is a $10 part from the pick n pull. The cables and joints are what cost the money. I think they were about $150 The picture is before I removed the rear diff. Bob (IMG:style_emoticons/default/driving.gif) |
okieflyr |
Sep 9 2010, 01:32 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
Bob that is a really nice little sleeper, you should bring it down th MUSR/TOD!
Andyrew |
Sep 9 2010, 02:32 PM
Very nice looking shifter setup! Did you buy or make it? Cost? Also it looks like you still have the tailpiece on the trani, you converted that to FWD after the pic, right? Or is it running like that? Andrew I built the set up myself. The shifter is a $10 part from the pick n pull. The cables and joints are what cost the money. I think they were about $150 The picture are before I removed the rear diff. Bob (IMG:style_emoticons/default/driving.gif) Nicely done! Where did you get the cables and joints if you dont mind me asking? I'll need to get some for my Audi conversion regardless if I go automatic or manual. Toyota corolla shifter works eh? Gotta remember that the next time I scrounge for some honda parts. |
Drums66 |
Sep 9 2010, 02:45 PM
....Very well thought out...all the way live!
(goose it 1 more time!!!!!) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/bye1.gif) |
d914 |
Sep 9 2010, 03:02 PM
Advanced Member Group: Members Posts: 2,345 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
[/quote] The toyo corolla, mr2 and a honda accord (90ish) all work... I have the honda part. The cables bob got are bullet proof and $$$, for mine we are going to try summit cables.. A little lighter and cheaper.. The corolla part needs to have a reverse-er mechinism built in.. Bob did this with some added flexability thrown in for length of throw.. Wait until you see his dash and such.. more goodies to see.... |
andys |
Sep 9 2010, 03:52 PM
The MR2 shifter works out well because the cable bulkheads point to the rear; the Corolla/Celica stuff points forward though they can be turned around. Another shifter to add to the list is from an 80's-90's Mitsubishi. Whatever shifter you use, it may require translation to get the right direction of movement. I buy my cables from Control Cables, Inc. (Tuthill distributor) in SoCal. They'll make up any cable length, any end, any bulkhead all by phone and a credit card. McMaster-Carr can do it too, but it takes longer and they can't give you any technical advice.
Andys |
BIGKAT_83 |
Sep 9 2010, 04:18 PM
I did add a bell crank to reverse the shift movement. This way the cables do exit towards the rear. Also with the bell crank I could adjust the shift length. I did give this a 2 to 1 gain to give the shifter more travel.
Bob |
Zaney |
Sep 9 2010, 09:14 PM
Deuchland en der Haus Group: Members Posts: 461 Joined: 1-March 04 From: Engine 11 Redmond, WA Member No.: 1,738 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) (IMG:style_emoticons/default/biggrin.gif)
Especially, your tailshifter linkage! Many Suby Conversionites are looking for inspiration for a simple, clean cable shifter system! Awesome work Bob! Your car looks sweet! (IMG:style_emoticons/default/aktion035.gif) Nate |
charliew |
Sep 10 2010, 12:11 AM
tranny cable linkage pictures are in the thread Nate.
ghuff |
Sep 10 2010, 08:08 AM
This is certainly not what I expected down here. Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.icanhascheezburger.com-10389-1284127710.1.jpg)
That is some good work. I'm starting to lean the subaru way myself after buying one and feeling the transmission and motor. How is it compared to your LS1 car? I am thinking the boxer with the weight lower would be much nicer, closer to a stock type IV. |
d914 |
Sep 10 2010, 08:22 AM
im also building a suby, but that ls1 with 400hp looks soooo good back there.. His gray car will be amazing.. Its one of those cars you just keep looking at the details and saying wow..
Zaney |
Sep 10 2010, 12:51 PM
tranny cable linkage pictures are in the thread Nate. Sorry, I meant for some possible close ups and perhaps a source for the joint parts too. I am prying because I am ready to attempt this part on my build and I have Zero experience (IMG:style_emoticons/default/smile.gif) Thanks for all the posts! |
matthepcat |
Sep 10 2010, 03:25 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I called Renegade Hybrids about Subaru motor and transmission options.
This was there reply, "Thanks for asking. The Subie tranny does not fit in the 914. Sorry. We are going to offer another tranny with the all aluminum LS V8's very soon. This will be our best combination! " (IMG:style_emoticons/default/blink.gif) Umm yea....ok. (IMG:style_emoticons/default/confused24.gif) |
Andyrew |
Sep 10 2010, 03:40 PM
matthepcat |
Sep 10 2010, 03:43 PM
Are the 2wd Audi transmissions a more viable option for v8 or turbo Subaru?
Andyrew |
Sep 10 2010, 04:09 PM
They are pretty strong and would be a good option for the v8. They are basically the same trani as what is in the boxster. The tranis in AWD mode are fairly bulletproof, lots of drag guys are running them at rediculous HP numbers for years without fail. Replacements cost ~ 500 or less and are fairly availible.
No sense putting a Audi trani on a Subaru motor... For the cost of adaption you could have easily converted the 4wd to 2wd on the subi box. The thing about the Audi box is that it requires no work to run, If you mount it behind an Audi engine (such as a 1.8t or 2.8 or even 2.7t) its bolt on and all factory equipment will work. You just have to figure the linkage (Custom cable shifter) and CV joints (Custom half shafts, 914 cv one end, Audi CV inner), then a cradle mount like the subaru guys do. Im planning on doing a 2.8 v6 complete swap from a passat or Audi fwd (same setups). I'll be selling my v8 conversion to fund a parts car purchase so I can get going on it fairly shortly. |
sawtooth |
Sep 23 2010, 01:27 PM
Member Group: Members Posts: 297 Joined: 25-June 08 From: Boise, ID Member No.: 9,211 Region Association: Intermountain Region |
QUOTE what company did the axles for you? cant find a driveline shop in my area that will touch my setup x2 |
charliew |
Sep 24 2010, 01:17 PM
Check on rock crawler or offroad shops for resplinging axles.
Lo-Fi Version | Time is now: 11th January 2025 - 11:35 AM |
