914 Subaru EG33 engine and WRX transaxle conversion, Finally finishing up |
JRust |
Jan 21 2011, 02:36 PM
914 Guru Group: Members Posts: 6,313 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Any idea on the wieght of the EG33 complete with all it's parts? What does your car weigh with it installed? Thanks (IMG:style_emoticons/default/biggrin.gif)
BIGKAT_83 |
Jan 21 2011, 06:38 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Any idea on the wieght of the EG33 complete with all it's parts? What does your car weigh with it installed? Thanks (IMG:style_emoticons/default/biggrin.gif) I think the engine is 350lbs. I also have a EZ30 engine now and it is 75lbs lighter than the EG33 and 6inches shorter. Planning to see you at Medford this summer. Bob |
SpecialK |
Jan 21 2011, 09:26 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
Probably not too far off with your 350lb. est., one site states the EG33 long block @ 255lbs. Pretty impressive internals too...7 main bearings!
475 hp....norm. asp. ! |
JRust |
Jan 21 2011, 11:31 PM
BIGKAT_83 |
Jan 22 2011, 07:56 AM
I think the engine is 350lbs. I also have a EZ30 engine now and it is 75lbs lighter than the EG33 and 6inches shorter. Planning to see you at Medford this summer. Bob Whats the plan with the ez30? It just replacing the eg33? No don't plan to replace the EG33. The EZ was just a great buy. Bob |
SpecialK |
Jan 22 2011, 03:24 PM
I think the engine is 350lbs. I also have a EZ30 engine now and it is 75lbs lighter than the EG33 and 6inches shorter. Planning to see you at Medford this summer. Bob Whats the plan with the ez30? It just replacing the eg33? No don't plan to replace the EG33. The EZ was just a great buy. Bob They do have one of the cooler looking intakes I've seen....kinda like a 928 junior. (IMG:style_emoticons/default/alien.gif) |
wobbletop |
Jan 22 2011, 11:57 PM
Member Group: Members Posts: 382 Joined: 8-December 06 From: Ontario, Canada Member No.: 7,335 Region Association: Canada |
Bob,
Very very nice car! What did you do for cooling? I don't see the normal cutouts in the front. thanks! |
bfrymire |
Feb 23 2011, 08:32 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Forgive me for my ignorance about the SVX motor. From what I have read, they are all automatics. Are they drilled for a pilot bearing? Or did you have to drill the crank?
-- brett |
BIGKAT_83 |
Feb 24 2011, 12:59 AM
bfrymire |
Feb 24 2011, 01:38 AM
Great! Thanks for the info. Looks like I am going the SVX route also.
-- brett (Just checked the adapter in the garage... Didn't notice before there was a pilot bearing there! Doh.) |
69dblcab |
Feb 25 2011, 06:09 PM
Vanagons with Subie motors. Group: Members Posts: 3 Joined: 25-February 11 From: Providence NC Member No.: 12,755 Region Association: None |
Where did you get your flywheel? Thanks |
BIGKAT_83 |
Feb 25 2011, 06:40 PM
Thanks for the info. Where did you get your flywheel? Thanks That's not my flywheel. It's just a picture of one I got off of the for sale ads on a Subaru site. Bob (IMG:style_emoticons/default/driving.gif) |
bfrymire |
Feb 25 2011, 07:25 PM
d914 |
Feb 25 2011, 07:53 PM
Advanced Member Group: Members Posts: 2,345 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
I believe Bob started with my flywheel and then changed to his or at least my hardware... The flywheel from a 2.0 will work.. remember subies are like lego's... the parts for the most part interchange.. Fly wheel from a manual 4 cyl will bolt to the 6.
charliew |
Jul 31 2016, 06:38 PM
I like this thread and I'm gonna bump it because this is a nice combo.
partwerks |
Aug 15 2022, 08:03 PM
Senior Member Group: Members Posts: 1,599 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
The MR2 shifter works out well because the cable bulkheads point to the rear; the Corolla/Celica stuff points forward though they can be turned around. Another shifter to add to the list is from an 80's-90's Mitsubishi. Whatever shifter you use, it may require translation to get the right direction of movement. I buy my cables from Control Cables, Inc. (Tuthill distributor) in SoCal. They'll make up any cable length, any end, any bulkhead all by phone and a credit card. McMaster-Carr can do it too, but it takes longer and they can't give you any technical advice. Andys So the MR2 shifter would already be oriented in the correct direction, where as the other, would have to be revamped? |
Lo-Fi Version | Time is now: 11th January 2025 - 10:02 AM |
