5 Pages V « < 3 4 5
> 914 Subaru EG33 engine and WRX transaxle conversion, Finally finishing up
BIGKAT_83
post Feb 24 2011, 12:59 AM
Post #81
QUOTE(bfrymire @ Feb 23 2011, 09:32 PM) *
Forgive me for my ignorance about the SVX motor. From what I have read, they are all automatics. Are they drilled for a pilot bearing? Or did you have to drill the crank?
-- brett
The pilot bearing is mounted to the fhywheel on a Subaru.
bfrymire
post Feb 24 2011, 01:38 AM
Post #82
Salsaholic
Great! Thanks for the info. Looks like I am going the SVX route also.
-- brett
(Just checked the adapter in the garage... Didn't notice before there was a pilot bearing there! Doh.)
69dblcab
post Feb 25 2011, 06:09 PM
Post #83
Vanagons with Subie motors.
Where did you get your flywheel?
Thanks
BIGKAT_83
post Feb 25 2011, 06:40 PM
Post #84
QUOTE(69dblcab @ Feb 25 2011, 07:09 PM) *
Thanks
That's not my flywheel. It's just a picture of one I got off of the for sale ads on a Subaru site.
Bob (IMG:style_emoticons/default/driving.gif)
bfrymire
post Feb 25 2011, 07:25 PM
Post #85
Salsaholic
QUOTE(69dblcab @ Feb 25 2011, 04:09 PM) *
Thanks
Mine is different from Bob's. I got mine from Renegade Hybrids.
-- brett
d914
post Feb 25 2011, 07:53 PM
Post #86
I believe Bob started with my flywheel and then changed to his or at least my hardware... The flywheel from a 2.0 will work.. remember subies are like lego's... the parts for the most part interchange.. Fly wheel from a manual 4 cyl will bolt to the 6.
charliew
post Jul 31 2016, 06:38 PM
Post #87
I like this thread and I'm gonna bump it because this is a nice combo.
partwerks
post Aug 15 2022, 08:03 PM
Post #88
QUOTE(andys @ Sep 9 2010, 01:52 PM) *
The MR2 shifter works out well because the cable bulkheads point to the rear; the Corolla/Celica stuff points forward though they can be turned around. Another shifter to add to the list is from an 80's-90's Mitsubishi. Whatever shifter you use, it may require translation to get the right direction of movement. I buy my cables from Control Cables, Inc. (Tuthill distributor) in SoCal. They'll make up any cable length, any end, any bulkhead all by phone and a credit card. McMaster-Carr can do it too, but it takes longer and they can't give you any technical advice.
Andys
So the MR2 shifter would already be oriented in the correct direction, where as the other, would have to be revamped?
5 Pages V « < 3 4 5
- Lo-Fi Version Time is now: 19th April 2025 - 12:25 PM
