carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 124,582 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
I kept the Gotti's, Sold them with my 74 Carrera, bought them back & sold them again - the 10"s wouldn't fit anything I had. I have 2 sets of 9"s with Tires - BBS & Fuchs
On the Beck - the tire was petrified, no valve stem and the sidewalls were like a rock ![]() After Refinishing ![]() |
carr914 |
She stayed in the (somewhat) Air-Conditioned Garage today
Got everything disconnected for the 4-cylinder engine drop ( probably Sunday or Monday as I'm off to Sebring tomorrow) Also went to the Engine Builders to drop off Air Shroud, Ignition, & Oil-bypass pieces. The New Swiss Valves arrived while I was there. Should be done by the end of the weekend ![]() ![]() |
carr914 |
Crazy putting a $40K engine in a $5K car (IMG:style_emoticons/default/confused24.gif) - I'll let you know, but this was no ordinary $5K car
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,791 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
TC what chain housings are you going to use ?
carr914 |
Well, when I started to make a Leather Dash for the GT, I had an extra cracked dash laying around so I made two.
This car has a dash-cap that I hope is not to much of a bitch to get off - I'm sure somebody can use it. ![]() ![]() |
carr914 |
Four No Mour
![]() I need to put the tools away, but my Favorite beverage awaits (IMG:style_emoticons/default/beer3.gif) ![]() |
carr914 |
Got Nothing today
I just went to the Bank with the Stack o Benjamins from my engine sale, to make sure they were real. ![]() They were, so I can buy more parts (IMG:style_emoticons/default/idea.gif) |
carr914 |
Starting from the Passenger side, Today I installed outside mirror, RamMat'd the P/S Door, installed vapor shield and installed Door Panel
carr914 |
Installed Near Perfect Rear Hella Lenses, Gave the others away
![]() Garold, Mom's Service Cover looks Great against a Yellow car. I don't know that these are still available, But they are the BEST - Thanks Millie. I bought 2 and can't wear the 1st out. ![]() |
carr914 |
Ferg |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None ![]() ![]() |
Wow, Cool, so glad you bought that car.
Ferg |
carr914 |
Fitted an Outside mirror on the Driver's Side. It was Bondo'd over & Painted. I had to chisel out the filler, punch from Top & Bottom.
![]() RamMat'd the D/S Door, Put Vapor Barrier & mounted Door Panel (4 Friggin Times til I got it the way I wanted it). The RamMat does add weight, but the "real carr" door thud is cool ![]() |
Eric Taylor |
Senior Member ![]() ![]() ![]() Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 ![]() |
Great project! I have always loved this particular car. It's been all over! Now a six.
Great carbon cannondale rush in the background! |
carr914 |
The CannonDale is my Engine Guys Trail-Rider - Pretty Cool bike
This is the perfect example of the car Newbies should Buy. Solid as a Rock. Most New Guys think if they buy a $500 car they can fix it. Then it sits on JackStands til they give it away. This was an under $5K car delivered, I've sold off a lot of what I didn't want. Now it is good platform for what I want to do |
JimmyG |
Member ![]() ![]() Group: Members Posts: 146 Joined: 10-September 04 From: Birmingham, AL Member No.: 2,730 Region Association: South East States ![]() |
That is going to be a great car when you get finished!
Your right about the newbies.although I think they need to stick with the 4 banger. Pretty intense doing the conversion for a fist timer. I will not have my car together for Petit Le Mans this year. Hopefully next year. Will enjoy watching your progress! Jimmy |
carr914 |
Jimmy, that was my intention for the newbies - buy a car like this and drive the snot out of it vs buying a $1500-2000 car that "needs a little fixing up" that turns into a $8000 car overnight
I bought it for the value - the value it has for me as a super solid that I can turn into a track car quickly And the value of the parts I knew I could sell (motor, carbs, both gone, Center Console, suspension & brakes, wheels, etc) |
carr914 |
Removed what must be the most cracked Dash Top and put in the Leather
What a Pain in the Ass - I led the league today in cuss words ![]() ![]() It started getting dark, so I called it a day, will put the Glove box & lower dash pad back in tomorrow ![]() |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,121 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
Removed what must be the most cracked Dash Top and put in the Leather What a Pain in the Ass - I led the league today in cuss words ![]() ![]() It started getting dark, so I called it a day, will put the Glove box & lower dash pad back in tomorrow ![]() You could probably sell that dash as having a rare antiqued finish. (IMG:style_emoticons/default/happy11.gif) |
carr914 |
Too late. the Keith Richards dash is in the trash and awaiting pickup
carr914 |
Today, I buttoned the dash back together and put the Interior TargaBar trim in. Someone had installed the rear Targa latches on the wrong sides - it took me a few minutes to figure out why things were not fitting
Lo-Fi Version | Time is now: 20th April 2025 - 05:38 AM |
