DAPO Pictures, Things that make you go hummmmm!!!!!! |
windforfun |
Jun 10 2021, 06:36 PM
Senior Member Group: Members Posts: 1,985 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Go San Jose!!! I used to live in Santa Clara.
AZBanks |
Jun 10 2021, 09:18 PM
Senior Member Group: Members Posts: 1,063 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
Jwjwjw |
Jun 11 2021, 04:57 PM
Newbie Group: Members Posts: 25 Joined: 22-May 20 From: Hanover, Pa Member No.: 24,296 Region Association: North East States |
Jwjwjw |
Jun 11 2021, 04:58 PM
ejm |
Jun 12 2021, 06:27 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,703 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Spent some time today helping a fairly new owner sort out some issues. Removed front and rear hard wired radar detectors and a satellite radio system with Bluetooth leaving just the am/fm/cd head installed to fill the hole in the dash. (IMG:style_emoticons/default/biggrin.gif) Pulled out 6 feet of antenna cable and other wiring that was wrapped around the steering column by the upper flex joint and other remnants from an ?alarm system?. In the engine compartment were two pull knob choke cables hooked to the heater boxes even though the stock cable were still there and working. (IMG:style_emoticons/default/huh.gif) But the best DAPO WTF was the 50+ pound steel ring bolted to the floor of the trunk to center the spare tire. (IMG:style_emoticons/default/screwy.gif) Next thing to sort out is fuel pump toggle switch hanging under the dash and slop in the shifter.
bkrantz |
Jun 12 2021, 08:04 PM
914 Guru Group: Members Posts: 8,154 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Spent some time today helping a fairly new owner sort out some issues. Removed front and rear hard wired radar detectors and a satellite radio system with Bluetooth leaving just the am/fm/cd head installed to fill the hole in the dash. (IMG:style_emoticons/default/biggrin.gif) Pulled out 6 feet of antenna cable and other wiring that was wrapped around the steering column by the upper flex joint and other remnants from an ?alarm system?. In the engine compartment were two pull knob choke cables hooked to the heater boxes even though the stock cable were still there and working. (IMG:style_emoticons/default/huh.gif) But the best DAPO WTF was the 50+ pound steel ring bolted to the floor of the trunk to center the spare tire. (IMG:style_emoticons/default/screwy.gif) Next thing to sort out is fuel pump toggle switch hanging under the dash and slop in the shifter. Ballast? |
Front yard mechanic |
Jun 12 2021, 08:50 PM
Senior Member Group: Members Posts: 1,230 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Spent some time today helping a fairly new owner sort out some issues. Removed front and rear hard wired radar detectors and a satellite radio system with Bluetooth leaving just the am/fm/cd head installed to fill the hole in the dash. (IMG:style_emoticons/default/biggrin.gif) Pulled out 6 feet of antenna cable and other wiring that was wrapped around the steering column by the upper flex joint and other remnants from an ?alarm system?. In the engine compartment were two pull knob choke cables hooked to the heater boxes even though the stock cable were still there and working. (IMG:style_emoticons/default/huh.gif) But the best DAPO WTF was the 50+ pound steel ring bolted to the floor of the trunk to center the spare tire. (IMG:style_emoticons/default/screwy.gif) Next thing to sort out is fuel pump toggle switch hanging under the dash and slop in the shifter. Ballast? 4cents a pound at the scrap yard you just scored 2 bucks |
euro911 |
Jun 25 2021, 10:45 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,858 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Back in the 60s, one of my brother's friends had a Corvair. He wanted to lower the front end, so they snatched a manhole cover from somewhere and tossed it in the frunk (IMG:style_emoticons/default/laugh.gif)
Apparently, these days, some people are stealing them for scrap value - not for lowering their cars https://www.nytimes.com/2012/05/04/nyregion...ole-covers.html |
914werke |
Jun 25 2021, 12:41 PM
"I got blisters on me fingers" Group: Members Posts: 10,951 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
914werke |
Jun 25 2021, 12:44 PM
Ive got a lot more from this poor car. (IMG:style_emoticons/default/sad.gif)
Attached thumbnail(s) |
930cabman |
Jun 25 2021, 01:44 PM
Advanced Member Group: Members Posts: 3,699 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I wonder how many of us have a background in VW ownership... When I was buying and selling bugs, all that stuff was par for the course. You expected to see something hacked up. +100% at least. Thanks moderator for bringing this in view. Good for a few laughs and maybe even learn a thing or two. |
Root_Werks |
Jun 25 2021, 04:00 PM
Village Idiot Group: Members Posts: 8,486 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Rich, that white 914 has some bizarre stuff going on!
914werke |
Jun 25 2021, 06:48 PM
Thats just the tip of the iceburg (IMG:style_emoticons/default/icon8.gif)
Superhawk996 |
Jun 25 2021, 09:00 PM
914 Guru Group: Members Posts: 6,529 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
When I see the stuff done to these cars, I’m not sure if it is a testament to how desperately folks want to keep them on the road, or just how many people have no clue about what they are doing.
930cabman |
Jun 26 2021, 08:07 AM
Some of this stuff is just plain scary. I guess a little knowledge can be a dangerous thing holds true.
Think: Rube Goldberg |
Jett |
Jun 26 2021, 09:39 AM
Senior Member Group: Members Posts: 1,670 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Jett |
Jun 26 2021, 09:40 AM
When I see the stuff done to these cars, I’m not sure if it is a testament to how desperately folks want to keep them on the road, or just how many people have no clue about what they are doing. I bet if we look under the car that the two black plastic wind flaps have been taken off. |
Jett |
Jun 26 2021, 09:42 AM
I like the custom PORSCHE layout! |
JeffBowlsby |
Jun 26 2021, 09:50 AM
914 Wiring Harnesses Group: Members Posts: 8,747 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Reminds of the only rear engine 914…where is that photo?
sixnotfour |
Jun 26 2021, 12:10 PM
914 Wizard Group: Members Posts: 10,640 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Lo-Fi Version | Time is now: 26th November 2024 - 04:40 PM |
