Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,003 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
You are not normal...but in a great way!
Hontec |
I see things..... ![]() ![]() Group: Members Posts: 261 Joined: 23-September 10 From: Netherlands Member No.: 12,210 Region Association: Europe ![]() |
You are not normal...but in a great way! Whahaha thanks, come to think of it: ....that's what my wife says too..... (IMG:style_emoticons/default/dry.gif) |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
very little rust! you must be a happy man (IMG:style_emoticons/default/laugh.gif)
nathansnathan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None ![]() |
Wow deja vu with the fender removal - not too many people willing to get into that madness (IMG:style_emoticons/default/biggrin.gif).
It is weird that must have changed how the striker plate mounts - mine was attached to the door jam itself where yours is attached to that bracket that is attached to the inner fender. You can see my version of the right rear fender removal on my build thread deja vu I've been following your thread, truly inspiring. The last post currently, last picture in my thread I was thinking of you as I took it, Hontec. -I had to climb up a ladder and hold my camera up to the ceiling as I don't have a loft (IMG:style_emoticons/default/biggrin.gif) ode to hontec (IMG:style_emoticons/default/happy11.gif) |
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
Hontec |
Powdercoating is really thick. Are you concerned about that added thickness affecting how your jigs fit? I would think plating would be preferable because of that. (IMG:style_emoticons/default/confused24.gif) Problem solved: normally they blast, then coat a primer and then coat a color. For these kind of things they only blast and put on a very thin coat to keep it from rusting again..... So minimal thickness added.... |
plymouth37 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest ![]() ![]() |
Amazing work as usual, you just got me motivated to get some work done on mine today!
Hontec |
Amazing work as usual, you just got me motivated to get some work done on mine today! Thanks man, that's the same effect your work has on my motivation! (IMG:style_emoticons/default/smile.gif) |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,003 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Wow!
If anyone ever asks me how these cars are put together, I'm just going to point them to this thread and these amazing pictures... --DD |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,602 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Where did you get those wheels for the table?
Are they adjustable in very small degrees to level it on an uneven floor? Rich |
Hontec |
Where did you get those wheels for the table? Are they adjustable in very small degrees to level it on an uneven floor? Rich they are standard front wheels as used on trailers over here, they can be adjusted about 8 inches in height (IMG:http://www.914world.com/bbs2/uploads_offsite/tanyaveronica.web-log.nl-12210-1297453864.1.jpg) |
nathansnathan |
nice! It looks relatively good in there. Mine was seriously nasty. (IMG:style_emoticons/default/barf.gif)
link to pic (not for the faint of heart) Any sort of plan on what metal you'll put back in there? ... I'm a bit stumped on that part myself (IMG:style_emoticons/default/blink.gif) |
Hontec |
nice! It looks relatively good in there. Mine was seriously nasty. (IMG:style_emoticons/default/barf.gif) link to pic (not for the faint of heart) Any sort of plan on what metal you'll put back in there? ... I'm a bit stumped on that part myself (IMG:style_emoticons/default/blink.gif) Wow! yours looks quite bad compared to mine! Put metal back? Fender wise? Mmmmm I'm going to use fiberglass complete fenders Gt width and have them made in dry carbon.. |
nathansnathan |
that sounds like a good plan. [gross understatement]
(IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/drooley.gif) |
Smitty911 |
Member ![]() ![]() Group: Members Posts: 294 Joined: 19-March 08 From: La Mirada, Ca Member No.: 8,830 Region Association: Southern California ![]() |
WOW, best hour I've spent in a long time.
Truley amazing work. Based on the quality of your work, I'd fly to the North Pole in a Paper Airplane with you. FYI - You don't have OCD, if you did it would be CDO - That's alphabetical. Smitty |
Hontec |
WOW, best hour I've spent in a long time. Truley amazing work. Based on the quality of your work, I'd fly to the North Pole in a Paper Airplane with you. FYI - You don't have OCD, if you did it would be CDO - That's alphabetical. Smitty Thanks for the compliments and confidence! Lol about the CDO.... (IMG:style_emoticons/default/biggrin.gif) |
ottox914 |
The glory that once was. ![]() ![]() ![]() Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest ![]() ![]() |
Good Sir, you have re-defined insanity.
I completely approve. Amazing craftsmanship. Keep up the good work and the pics. If you are married, your wife should be sainted for putting up with your new obsession. |
Hontec |
Good Sir, you have re-defined insanity. I completely approve. Amazing craftsmanship. Keep up the good work and the pics. If you are married, your wife should be sainted for putting up with your new obsession. Thanks! gave my wife a horse....that levels it out pretty much timewise..... (IMG:style_emoticons/default/biggrin.gif) |
Gudhjem |
Member ![]() ![]() Group: Members Posts: 133 Joined: 29-March 07 From: Castro Valley, CA Member No.: 7,629 Region Association: Northern California ![]() |
Amazing stuff. (IMG:style_emoticons/default/cheer.gif)
Those pics of the fender-cowl area are the best I've seen. I've been struggling to figure out exactly how the pieces fit together there as I repair mine (I'll be using metal). |
Lo-Fi Version | Time is now: 7th July 2024 - 03:27 PM |
