Hontec |
I see things..... ![]() ![]() Group: Members Posts: 261 Joined: 23-September 10 From: Netherlands Member No.: 12,210 Region Association: Europe ![]() |
Crap, way better than I had hoped for ( the interlocking plates and back did their job well in preventing warpage) Run-out compared to the hubmount only a minor 0,01mm (0,01 mm = 0,000393700787 inch) (IMG:style_emoticons/default/piratenanner.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i854.photobucket.com-12210-1317327210.1.jpg) |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,280 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Sorry... I used the wrong terminology when I said hub.
I should have said 911 bearing housing not 911 hub. A later (1974) 911 bearing housing could be cut and welded on exactly like what was done with the 914 housing. It would give you a larger bearing (for the wider tires 911's were starting to get at that time) and give you the robust handbrake stop tab, allowing the use of 911 handbrake assemblies. I believe 911/930 and 928 cars used a very similar handbrake setup on all... similar if not virtually identical. Here's the 911 bearing housing (this is a 70ish but a 74 would look very similar): ![]() And here are examples of handbrake assemblies that would bolt on: ![]() Keep up the great fab work!! (IMG:style_emoticons/default/smilie_pokal.gif) |
Hontec |
Thanks for the clarification Eric!!
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
Don't you have to have a special rotor for that though(internal parking brake)? Kinda eliminates the option of doing a nice aluminum hat. The hot ticket is is a mechanical spot caliper. The Audi R-8 uses one the CGT used one, it wouldn't be that hard to fit the Dynalite Mechanical spot caliper for use with a disk setup.
http://www.wilwood.com/Calipers/CaliperLis...ame=Mech%20Spot Several companies offer them though. |
Hontec |
Don't you have to have a special rotor for that though(internal parking brake)? Kinda eliminates the option of doing a nice aluminum hat. The hot ticket is is a mechanical spot caliper. The Audi R-8 uses one the CGT used one, it wouldn't be that hard to fit the Dynalite Mechanical spot caliper for use with a disk setup. http://www.wilwood.com/Calipers/CaliperLis...ame=Mech%20Spot Several companies offer them though. Correct but if I use the 930 turbo disc (309x28) instead of the 928S4 disc (304x31) I have the correct bellhousing for the parking brake backplate. With the 930 turbo disc I can still use the brembo 4-pots and I Will also make provisions for à separate parking brake caliper, just to have the option to change if needed.. |
Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
Don't you have to have a special rotor for that though(internal parking brake)? Kinda eliminates the option of doing a nice aluminum hat. The hot ticket is is a mechanical spot caliper. The Audi R-8 uses one the CGT used one, it wouldn't be that hard to fit the Dynalite Mechanical spot caliper for use with a disk setup. http://www.wilwood.com/Calipers/CaliperLis...ame=Mech%20Spot Several companies offer them though. Correct but if I use the 930 turbo disc (309x28) instead of the 928S4 disc (304x31) I have the correct bellhousing for the parking brake backplate. With the 930 turbo disc I can still use the brembo 4-pots and I Will also make provisions for à separate parking brake caliper, just to have the option to change if needed.. Amazing work so far Randall. When you finish that beauty bring it over here and we'll find some Oregon or Idaho Hill Climbs to run. |
Hontec |
Don't you have to have a special rotor for that though(internal parking brake)? Kinda eliminates the option of doing a nice aluminum hat. The hot ticket is is a mechanical spot caliper. The Audi R-8 uses one the CGT used one, it wouldn't be that hard to fit the Dynalite Mechanical spot caliper for use with a disk setup. http://www.wilwood.com/Calipers/CaliperLis...ame=Mech%20Spot Several companies offer them though. Correct but if I use the 930 turbo disc (309x28) instead of the 928S4 disc (304x31) I have the correct bellhousing for the parking brake backplate. With the 930 turbo disc I can still use the brembo 4-pots and I Will also make provisions for à separate parking brake caliper, just to have the option to change if needed.. Amazing work so far Randall. When you finish that beauty bring it over here and we'll find some Oregon or Idaho Hill Climbs to run. That would sure be nice, I am a huge hillclimb fan!!! |
Hontec |
Some people expressed concerns regarding welding the cast iron flange, well I'm not quite sure if it is cast iron and in the stock trailing arm, these flanges are also welded on the tube by Porsche itself, so my filosofy is: if they can weld it, I can too
explanatory pics: (IMG:http://www.914world.com/bbs2/uploads_offsite/i854.photobucket.com-12210-1317364356.1.jpg) (IMG:http://i854.photobucket.com/albums/ab101/randallenabe/porsche%20914/porsche914608.jpg) |
Brett W |
Pretty sure they are cast steel, not cast iron, so they should be fine when welding. I have welded on a few and they are pretty clean so I see no issues there.
Eric_Shea |
Agree... Very weldable as noted, that's exactly how the factory did it.
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
The larger 911 bearing (513180), according to my bearing chart, goes back to 1978 but I'm not be sure which bearing was used before that on the 911....perhaps my chart in incomplete?
For my custom training arms, I machined my own bearing carriers but frankly it was a lot of work. It would be much easier to adapt an exising carrier. Andys Attached image(s) ![]() |
Brett W |
For reference. The 02 GT2 uses an 85mm rear wheel bearing. The 89 930 uses two 82mm taper roller bearings, 78-89 911 uses an 80mm bearing in the rear, the 987/997 uses an 80mm bearing all the way around, the 986/996 use a 75mm bearing all the way around, the 914-4 uses a 75mm wheel bearing. I am pretty sure it is the same bearing as the Boxster and 996 use.
Hontec |
Thanks guys for all the input, work Will continue Next tuesday when I'm back from my visit to China
@ Andys: those hubs look mighty Nice!!! |
nsr-jamie |
914 guy in Japan ![]() ![]() ![]() Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None ![]() |
Wow! Looking good !! Glad to see updates on this project and thread....nice Mistutoyo gauge too, I have the same one.
China?? Come to Japan!! Those are beautiful welds !! |
Hontec |
BKLA |
Really old member ![]() ![]() ![]() Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest ![]() ![]() |
that's just sweet!
Eric_Shea |
There ya go! (IMG:style_emoticons/default/smilie_pokal.gif)
MDG |
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None ![]() |
(IMG:style_emoticons/default/smilie_pokal.gif) That is so good. Like mad scientist good.
moparrob |
Senior Member ![]() ![]() ![]() Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None ![]() |
Lo-Fi Version | Time is now: 2nd July 2024 - 04:38 PM |
