6 Pages V < 1 2 3 4 5 > »
> My 72 3.0 progress thread: Project F-914, Adding transmission cooler.
Krieger
post Nov 4 2010, 09:23 PM
Post #41
Got the cover made and riveted in place. I used seam sealer on the inside between the cover and the dash to fill any gaps an hold it in place from vibrating.
Krieger
post Nov 4 2010, 09:25 PM
Post #42
Bird's eye. (IMG:style_emoticons/default/biggrin.gif) I have a can of krylon wrinkle paint for the gauge plate and dash!
SGB
post Nov 5 2010, 07:16 AM
Post #43
just visiting
the coolness of simplicity.
So minimalist.
Great.
tdgray
post Nov 5 2010, 09:14 AM
Post #44
Really Neat... like what you are doing.
Krieger
post Dec 12 2010, 10:47 PM
Post #45
Dash pic added. Wrinkle finished failed large flat surface area. My Webpage Painted SEM Tirm Black.
Krieger
post Dec 12 2010, 11:22 PM
Post #46
Got the engine lid finished. Home depot handle and pins to locate on the fire wall. Hood pins will hold it on to body
Krieger
post Dec 9 2011, 06:30 PM
Post #47
So I have been working on my car and its been nearly a year since I've updated. My new economy throttle linkage. $15 for two of the ball joints that the cable goes to (one spare). My goal was to get rid of the monkey motion, use a stock throttle cable and not spend much. I am using an aftermarket 914/6 cable from Patrick motorsports $50. I bought two so I'd have a spare. This set up has been tested with the engine rolled under the car and the cable installed in the car with the pedal assembly. I get full throttle and still have some adjustment that I can make to the rod lengths, cable length or bracket position.
Krieger
post Dec 9 2011, 06:34 PM
Post #48
I need to rebuild the carbs still. The bracket on the shroud is made from a recycled chunk of steel I cut out of the rear bumper of my 75 when I was lightening it. So there is some value to those big bumpers!
Krieger
post Dec 9 2011, 06:41 PM
Post #49
Since this car is such a mix of parts I needed to make my own wire harness. I also wanted to eliminate the relay board. This is not a fancy connector. I found it was a big hassle trying to find just one male/female connector. I called JEGS and ordered a weather pak unit.
Krieger
post Dec 9 2011, 06:52 PM
Post #50
Here is the rest of the harness. Most of my supplies came from a local electronics supply. For the actual wires within the harness I cut the rear half of the wire harness from a 914 that was at my local pick n pull. It was in great shape. I used these wires in my new engine harness so they would match the wires in my body harness when pluggen in. Hi torque starter. Ottos built trans. I put the heavy cable from the battery to the starter in the harness as well.
Krieger
post Dec 9 2011, 06:57 PM
Post #51
Here is one of my rebuilt Ferrari rear calipers. All I need for the rears are pads!
Krieger
post Dec 9 2011, 07:02 PM
Post #52
Front sway bar and heavy A calipers. When I learn how to drive I will replace the A's with something better. I need to run brake lines and add master cylinder.
Krieger
post Dec 9 2011, 07:08 PM
Post #53
Something simple, cheap, light and fun. If you were in a US made jet and wanted to get out of a plane in a hurry you'd reach up above your head and grab yellow/black cable like this to punch out. Home Depot special $9. Eject label from office label maker free. Effect...priceless (IMG:style_emoticons/default/biggrin.gif)
Krieger
post Dec 9 2011, 07:13 PM
Post #54
I didn't want to do this project. I'm getting tired of projects and I just want to drive this freakin car. Oh well, it was pretty easy with my drill and jig saw. I also had some aluminum left over from making the dash. I forget how cool it is to work with aluminum. I welded nuts on the engine compartment side of the firewall to hold it down.
Krieger
post Dec 9 2011, 07:16 PM
Post #55
One of my "buddies" conviced me I needed to do the access panel. Just to the left you can see the bolt heads I tacked in place to mount the coil in the engine compartment.
Krieger
post Dec 9 2011, 07:22 PM
Post #56
Here is the engine compartment with my new connector eliminating the use of the relay board. I shortened a good amount of the original harness to put the plug in this location. The voltage reg was the only "compromise" if you want to call it that. I have the bracket for the engine mount temporarily mounted to help me with figuring out the oil line routing. My coil is wired in to the body harness and so is the distributor pick up lead.
Krieger
post Dec 9 2011, 07:28 PM
Post #57
Oil line routing in front trunk. The lines are going in the passenger long, then into the passenger compartment. Through the front bulkhead to the cooler. (IMG:style_emoticons/default/sawzall-smiley.gif)
Krieger
post Dec 9 2011, 07:32 PM
Post #58
Passenger side. Hole saws courtesy my pal Marty. (IMG:style_emoticons/default/sawzall-smiley.gif)
Krieger
post Dec 9 2011, 07:37 PM
Post #59
Windshield from that same doner car at pick n pull. It has a couple of small scratches otherwise awesome shape. I got it out, home and installed without breaking it! Rubber seal/butyl from Mikey. 3m black primer.
Krieger
post Dec 9 2011, 07:46 PM
Post #60
I liked the look of the original chrome wiper harware.
- Lo-Fi Version Time is now: 2nd April 2025 - 02:07 AM
