6 Pages V « < 2 3 4 5 6 >
> My 72 3.0 progress thread: Project F-914, Adding transmission cooler.
Krieger
post Dec 9 2011, 07:50 PM
Post #61
Almost forgot. The MSD 6AL box is wired into the harness along with the tach adapter. All I need is a couple of ends installed.
Jeffs9146
post Dec 9 2011, 11:33 PM
Post #62
Ski Bum
What year 3.0L is it? I didn't need a tach adapter for my MSD6AL on a 3.0L! My motor is an '83sc with a '79 tach! (IMG:style_emoticons/default/confused24.gif)
I didn't think the 4 cylinder tach will work even with the adaptor...maybe I am wrong?
EdwardBlume
post Dec 10 2011, 06:45 AM
Post #63
QUOTE(Krieger @ Dec 9 2011, 05:46 PM) *
What you see of the wiper system is all there is...
Vent delete looks cool! How did the dash install go?
Krieger
post Dec 10 2011, 09:05 AM
Post #64
The engine is from a 78. The tach is from an unknown 911. If I need to I could always cut that tach adapter out. I needed a tach adapter for my 4 cylinder 75 with MSD6 box.
Rob the dash was easy to install. I used the two bolt holes on the top center. Then large (maybe 1/8") sheet metal screws on each side into the cage
Krieger
post Dec 24 2011, 03:26 PM
Post #65
Here is a close up of the paint, er glass beaded aluminum finish! Well the wiper nuts are glass beaded aluminum!
Randal
post Dec 24 2011, 05:13 PM
Post #66
QUOTE(Krieger @ Dec 24 2011, 01:26 PM) *
I really like the paint. Super cool.
Randal
post Dec 24 2011, 05:16 PM
Post #67
QUOTE(Krieger @ Sep 26 2010, 08:49 AM) *
I have some more time to post pictures correctly. The car was painted last month a matte metalic silver. This paint is a polyurethane and looks awsome in the sun. In the garage it looks a little dull. Basically it looks like glass beaded aluminum! The paint is from TCP Global in San Diego. Hot Rod Flats is the color line.
Did you paint it yourself?
Krieger
post Dec 24 2011, 06:03 PM
Post #68
I had someone spray it in my garage. I'm good with a spray can though!
Krieger
post Apr 20 2012, 11:18 PM
Post #69
Got my oil lines and fuel system done! Mazda RX-7 cooler and Holley red fuel pump. Stainless fuel lines courtesy of Tangerine Racing. I have both installed even though I only am using one now.
Krieger
post Apr 20 2012, 11:21 PM
Post #70
I ran the lines in the long and wrapped them with a heat insulating material. A little bit of work with a hole saw and grinder.
Krieger
post Apr 20 2012, 11:24 PM
Post #71
The left engine compartment view. Yes the line is run over the stock 6 engine mount, then fastened to the brake dampner. GT style engine mount bracing encouraged by Mr. Eric Shea.
Krieger
post Apr 20 2012, 11:31 PM
Post #72
Here is the right side detail. with my home grown battery tray....wait till you see my "hot rod' style battery hold down. All the ignition components are wired into the body harness.
Krieger
post Apr 22 2012, 08:06 PM
Post #73
A better view of oil thermostat and line routing.
Krieger
post Jun 24 2012, 12:27 PM
Post #74
Carbs done! I did the float bowel mod to keep the mains fed in corners.
Krieger
post Jun 24 2012, 12:28 PM
Post #75
Engine/trans going in!
Krieger
post Jun 24 2012, 12:30 PM
Post #76
Bingo!! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) Note the fancy puke bottle set up pirated from one of the guys here.
Krieger
post Jun 24 2012, 12:52 PM
Post #77
MSDS 1 1/2" headers ceramic coated. I am using the stock SC muffler for now. Bungs added for an oxygen sensor in both.
Krieger
post Jun 24 2012, 12:57 PM
Post #78
I came up with a creative solution for an oil tank drain plug. I ordered the factory oil lines from the the tank to the cooler. It came with a union. I had a face machined then drilled and tapped it for a drain plug. I drilled the plug so I could safety wire it. This is one of many parts my pal Dean machined for me.
Krieger
post Jun 24 2012, 01:01 PM
Post #79
Installed. I welded in a bracket to support the set up. One large adele clamp to hold it.
Krieger
post Jun 24 2012, 01:05 PM
Post #80
Sir Andy style axles. I needed loger CV bolts than the 45mm units that came with the 944 cvs. These are 55mm and need to be trimmed so they didn't interfere with the trailing arm. Not an issue on the trans flange side. I couldn't find appropriate 50mm bolts. Also note Sir Andy inspired picture quality. (IMG:style_emoticons/default/biggrin.gif)
- Lo-Fi Version Time is now: 3rd April 2025 - 01:12 AM
