New digital distributor?, Has anyone seen this? |
KaptKaos |
Oct 24 2010, 05:34 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
http://www.vwparts.net/CB2014.html
Saw this new over at the Samba. Anyone seen this? Any idea if it works on a type4 or if it's worth it? |
Jake Raby |
Oct 24 2010, 05:53 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I acquired one last week. Results will be posted on my forum in the next couple of months.
Jacob |
Oct 24 2010, 06:08 PM
Member Group: Members Posts: 131 Joined: 12-February 08 From: Mansfield, Oh Member No.: 8,705 Region Association: Upper MidWest |
CB performance has a reprint of an article that appeared in Hot VWs:
http://www.cbperformance.com/Sep2010.asp |
KaptKaos |
Oct 26 2010, 09:12 PM
gothspeed |
Oct 27 2010, 10:34 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
WOW I am glad I have not bought a dizzy yet! I really think this new system is awesome (IMG:style_emoticons/default/biggrin.gif)!!!!
JamesM |
Oct 29 2010, 12:42 AM
Advanced Member Group: Members Posts: 2,023 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
This looks very interesting, cant wait to see the results of the tests.
I would love to see more details on the triggering mechanism and how accurate it is compared to points or a pertronix setup. Also, is that programing cable the same as the one used to program the LC-1 wideband? It would be very cool if it is as the LC-1 cable is what i have adapted my megasquirt setups to work with. 21x21 is a HUGE spark table to work with! |
Cap'n Krusty |
Oct 29 2010, 09:36 AM
This looks very interesting, cant wait to see the results of the tests. I would love to see more details on the triggering mechanism and how accurate it is compared to points or a pertronix setup. Also, is that programing cable the same as the one used to program the LC-1 wideband? It would be very cool if it is as the LC-1 cable is what i have adapted my megasquirt setups to work with. 21x21 is a HUGE spark table to work with! Reading the ad, as I did, will reveal that the "cable is proprietary to the distributor". Too bad it won't work with D-jet. The Cap'n |
mskala |
Oct 29 2010, 10:17 AM
R Group: Members Posts: 1,927 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
QUOTE Reading the ad, as I did, will reveal that the "cable is proprietary to the distributor". Too bad it won't work with D-jet. The Cap'n From the picture, the cabling they are using is a simple stereo-style plug to rs-232 connector, and a standard rs-232 to USB serial port. Unless they go to the bother of enumerating the USB port as something weird, it will just be an interface to any generic PC terminal program. |
mskala |
Oct 29 2010, 10:19 AM
Also, I've seen ads for this place 123 ignition which seems to have both a mappable and a 'select various stock curves' model. |
mikea100 |
Jan 25 2011, 10:23 PM
Member Group: Members Posts: 180 Joined: 28-December 09 From: Edison, NJ Member No.: 11,182 Region Association: North East States |
KaptKaos |
Jan 26 2011, 08:41 PM
I almost forgot about this. Thanks for the bump.
Jake Raby |
Jan 26 2011, 08:59 PM
I never received it.. I need to call them and ask where its at.
Mark Henry |
Jan 27 2011, 08:47 AM
If you read info it says the cable is included, but then it's you'll need the cable.
I really hate that, if you need the cable than it should be included, $28 for a $5 cable turns me off. Might be one of the reasons, in all the years I've been into VW's and all the parts I've sold, I've only ever bought one set of lowered spinals from CB. |
Lo-Fi Version | Time is now: 26th December 2024 - 05:14 PM |
