NC_Colfax |
Member ![]() ![]() Group: Members Posts: 130 Joined: 26-July 10 From: North Carolina Member No.: 11,982 Region Association: South East States ![]() |
Do they have a conversion for the Type IV to use an upright cooling fan like the 911 or Type 1?
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Do they have a conversion for the Type IV to use an upright cooling fan like the 911 or Type 1? Do it yourself Joe cali conversion. http://www.nextgen-usa.com/ DTM by Massive type4 (Jake Raby) Many 911 types, I like sharpbuilt for this type. This is the forum you want: http://www.shoptalkforums.com/viewforum.ph...569d953418bcb1d |
Mark Henry |
The DTM is the fastest/least work.
RFoulds |
914Rennsport ![]() ![]() ![]() Group: Members Posts: 850 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region ![]() ![]() |
Whats the advantage of doing this??
Mark Henry |
NC_Colfax |
I was looking at using it in the 914 for better cooling.
Is it worth it in the 914 ?? |
904svo |
904SVO ![]() ![]() ![]() Group: Members Posts: 1,124 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 ![]() |
This is what I build.
Mark Henry |
I was looking at using it in the 914 for better cooling. Is it worth it in the 914 ?? IMHO no it's not worth the bother, maybe if you're tracking it and looking for every ounce in weight savings and any advantage however small to cooling. . Jake has a DTM for the 914 it has no oil cooler provision so you have to do a whole cooler set up, lose the rain tray...etc |
RFoulds |
Thats why I was confused. I see it for a transplant to a Beetle, but not in a 914.
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Before making a REALLY big change to this, please take the time to do some evaluation of what's really the problem and what possible solutions are out there. Are you measuring head temps? Are you measuring oil temp? Do you have a larger displacement motor? Turbo? Hot cam? Or is the motor just tired? Or does the timing just need to be set? Or is it running lean? As you can see, there are a TON of questions that need absolute, definitive answers before a swap of the cooling system would be justified.
Mark Henry |
Before making a REALLY big change to this, please take the time to do some evaluation of what's really the problem and what possible solutions are out there. Are you measuring head temps? Are you measuring oil temp? Do you have a larger displacement motor? Turbo? Hot cam? Or is the motor just tired? Or does the timing just need to be set? Or is it running lean? As you can see, there are a TON of questions that need absolute, definitive answers before a swap of the cooling system would be justified. (IMG:style_emoticons/default/agree.gif) If you are thinking over do this for an overheating issue it's a band-aid on your elbow for a cut on your knee. Find the real problem not the symptom. |
NC_Colfax |
I am having no real issues I just really asked as a point of reference as 914 world provides good answers and subjective opinions.
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
The stock cooling system is effective to around 210HP, around 52HP per cylinder when fitted to a properly configured and blueprinted engine.
Want to run cool? Build the engine efficiently. That comes from a guy that would love to sell you a 914 DTM, but knows you don't need it.. |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
this is a jake raby dtm sample
Attached thumbnail(s) ![]() |
sean_v8_914 |
911 type cooling
sean_v8_914 |
another 911 style fan, different
IMO they are a waste of time in a 914. strickly bling. great way to put a type 4 in a bug. big jump in power for a bug Attached image(s) ![]() |
Bills914-4 |
Member ![]() ![]() Group: Members Posts: 313 Joined: 1-March 08 From: suburbs of Miami FL. Member No.: 8,762 Region Association: South East States ![]() |
DO NOT go with the 911 style shroud , I made that mistake back 2004 , I've
had my share of issue's ( mainly unbalanced temps between cylinders ) , I didn't do my reserach & I chose because of the LOOK's & the COOL factor , I didn't think much about the IMPORTANT part , the FUNCTION of it (IMG:style_emoticons/default/sad.gif) , If I was to do it over I would go with the DTM v2 ( 914 version ) or possibly a horizontal style ,again must do reserach . Ok confession over (IMG:style_emoticons/default/biggrin.gif) Bill D. Attached image(s) ![]() |
Mark Henry |
All of those 911 pic's show why if I was inclined to do a 911 fan in a bug it would be a Sharpbuilt.
Number one reason is not one of those would the hood close in a bug, maybe even a teen would have issues, they are all too tall. The sharpbuilt also has some vanes to direct the air better. DTM or Joe Cali would be my picks and I've installed all three (plus a 911 FAT) types over the years. |
McMark |
Another 911 shroud conversion...
Lo-Fi Version | Time is now: 22nd April 2025 - 03:57 AM |
