Official Sasquatch build thread Part 1, Cosmo Rotary Turbo... Then boom... |
strawman |
Nov 22 2010, 03:02 PM
Senior Member Group: Members Posts: 885 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
When I was into MR2s (albeit the early models, not the turbo models), most guys were hot-n-heavy on single vs. twin turbos. I came to understand that the twin sequential turbos were overly complicated, but my memory ain't what it used to be...
Mike Bellis |
Nov 22 2010, 03:36 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
When I was into MR2s (albeit the early models, not the turbo models), most guys were hot-n-heavy on single vs. twin turbos. I came to understand that the twin sequential turbos were overly complicated, but my memory ain't what it used to be... Agreed, but for my target HP # the twins should work fine. If I decide to exceed this level, I will look at a single or making the twins Non-sequencial. |
Andyrew |
Nov 22 2010, 04:08 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
200ft lbs at what RPM?
How much tq will you have at 2k rpm's? Curious how it will feel like in 2nd gear at ~ 15mph if you got on it.. However that boost rush will be AWESOME... |
Mike Bellis |
Nov 22 2010, 05:34 PM
200ft lbs at what RPM? How much tq will you have at 2k rpm's? Curious how it will feel like in 2nd gear at ~ 15mph if you got on it.. However that boost rush will be AWESOME... These little 1.3L turbos have more torque than you think. 200 ft lbs at 4000k. It is still more that a type 4 and same gearing. Who drives 15 mph in second gear? If I romp on it at 15 mph, I'll be in 1st! and rev it to 6k then shift. By that time I'll be doing 60mph as I shift to 2nd. I had a NA rotary in my VW Bus. It was stupid fast with all that wieght and no turbo. I'll let you drive it Andrew, then you can decide. |
Andyrew |
Nov 22 2010, 05:59 PM
Wait, your using the 901 as a 4 speed or 5 speed?
1st gear in a 901 wont net you 60mph.. At least to my knowledge. 2nd gear could do it. By no means am I saying its not going to be fast, My fear is how usable/predictable it will be with that lag on mountain roads. However max torque @ 4k rpms with a 7.5k redline is still pretty darn good. Thats just about what my Audi is.. except my Audi has a its torque a bit lower and about 300rpm smaller redline.. And I will say that it is 100% usable from 3k on up. |
Mike Bellis |
Nov 22 2010, 07:23 PM
Here's some stock specks from turborx7.com
" The system operates off one turbo during lower RPM's (after 2,000 RPM) and the secondary turbo spools up after the engine reaches the 5,000 RPM level. "... " The tiny 1.3 liter (two 654cc displacing rotors) power plant put out an incredible 255-hp, and 217 lbs/ft of torque, with the help of twin Hitachi HT12 turbos. " This the US spec with all the smog equipment. When you remove the Ac, air pump, radiator fan, open the exhaust, improved intercooler, improved air cleaner... etc... I should hit my HP goal with little work. I will try not to port the engine as this will decrease to torque and raise the peak HP higher in the RPM range. With these stock numbers, the car will be faster than my V8. (IMG:style_emoticons/default/cheer.gif) Don't forget, I removed an 800 lb engine and I'm replacing it with a 350 lb engine with more HP. The key is power to weight ratio. It should also be very nimble in corners. As far as mountain twisties? Keep the RPMs up, keep the turbo spooled. (IMG:style_emoticons/default/driving.gif) |
Lennies914 |
Nov 22 2010, 07:25 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
Mike,
Do you already have a motor? There was a guy in San Rafeal on CL last month with 2 of them for sale. $350 for both. One complete and one short block. Also one in Hollister for $100 w/engine stand. I may still have email addy's if interested. |
Mike Bellis |
Nov 22 2010, 07:30 PM
Mike, Do you already have a motor? There was a guy in San Rafeal on CL last month with 2 of them for sale. $350 for both. One complete and one short block. Also one in Hollister for $100 w/engine stand. I may still have email addy's if interested. (IMG:style_emoticons/default/drunk.gif) It's on its way. I bought this one because it is complete with all the electronics. |
Andyrew |
Nov 22 2010, 08:32 PM
Thats the way to go.. Hack up the ECU yourself so you have only yourself to blame..
How many miles are on that engine? Im curious how long the "little" turbo lasts.. It would be pushed past its efficiency range with the big turbo... |
jmmotorsports |
Nov 22 2010, 10:14 PM
Member Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest |
Here's some stock specks from turborx7.com " The system operates off one turbo during lower RPM's (after 2,000 RPM) and the secondary turbo spools up after the engine reaches the 5,000 RPM level. "... " The tiny 1.3 liter (two 654cc displacing rotors) power plant put out an incredible 255-hp, and 217 lbs/ft of torque, with the help of twin Hitachi HT12 turbos. " This the US spec with all the smog equipment. When you remove the Ac, air pump, radiator fan, open the exhaust, improved intercooler, improved air cleaner... etc... I should hit my HP goal with little work. I will try not to port the engine as this will decrease to torque and raise the peak HP higher in the RPM range. With these stock numbers, the car will be faster than my V8. (IMG:style_emoticons/default/cheer.gif) Don't forget, I removed an 800 lb engine and I'm replacing it with a 350 lb engine with more HP. The key is power to weight ratio. It should also be very nimble in corners. As far as mountain twisties? Keep the RPMs up, keep the turbo spooled. (IMG:style_emoticons/default/driving.gif) What V8 that will fit in a 914 weigh's 800 pounds ? Jerry |
Mike Bellis |
Nov 22 2010, 10:24 PM
matthepcat |
Nov 23 2010, 05:41 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Right on Mike!
I would recommend muffling the waste gate!!! Have you heard an open waste-gate? ouch ouch loud. http://www.youtube.com/watch?v=GS2AnGXfkw0 |
Mike Bellis |
Nov 23 2010, 05:50 PM
Right on Mike! I would recommend muffling the waste gate!!! Have you heard an open waste-gate? ouch ouch loud. http://www.youtube.com/watch?v=GS2AnGXfkw0 Thanks Matt. Where you been? Did the car sell on CL? |
matthepcat |
Nov 23 2010, 06:16 PM
No that was a moment of weakness. I have been lurking.
Let me know if you need a hand with your project. How about a Lexus ISF motor? http://cgi.ebay.com/ebaymotors/2009-lexus-...=item35aba3673d (IMG:style_emoticons/default/aktion035.gif) J/k Right on Mike! I would recommend muffling the waste gate!!! Have you heard an open waste-gate? ouch ouch loud. http://www.youtube.com/watch?v=GS2AnGXfkw0 Thanks Matt. Where you been? Did the car sell on CL? |
Mike Bellis |
Dec 11 2010, 06:40 PM
Not much to update. I've been collecting parts. Here's a pic of the cleaned and painted engine. I put my Iphone in the pic to give an idea of just how small these engines are. Picture a type 4 without heads and cylinders. This little turbo engine will make 350hp at 15 psi with 250 ft lbs @ 4k
GT35R Ball bearing Turbo- oil and water cooled HKS cast iron exhaust manifold Haltech ECU HKS Blow off Valve HKS wastgate HKS Boost controller 2000cc injectors (x4) Areomotive fuel regulator Custom Rails 4" exhaust Aero Turbine Muffler Frozen Boost air to water intercooler Damn this conversion is getting expensive! |
RJMII |
Dec 11 2010, 10:20 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
QUOTE GT35R Ball bearing Turbo- oil and water cooled HKS cast iron exhaust manifold Haltech ECU HKS Blow off Valve HKS wastgate HKS Boost controller 2000cc injectors (x4) Areomotive fuel regulator Custom Rails 4" exhaust Aero Turbine Muffler Frozen Boost air to water intercooler So are you switching to single turbo with the ball bearing unit? |
Mike Bellis |
Dec 11 2010, 11:08 PM
So are you switching to single turbo with the ball bearing unit? Yes, Single. with new manifold. The stock twin turbos are nice in stock configuration but the single is far less complicated and will yeild more power. The turbo I'm using can get me up to 450-500hp @ 25+psi but I want the engine to remain reliable hence the 17psi max plan. It will look similar to this one... |
Andyrew |
Dec 11 2010, 11:12 PM
I still think your going to be pushing way more HP than that on a GT35R.... I guess at 15psi maybe... but that turbo is made to be pushed to like 35psi...
Mike Bellis |
Dec 11 2010, 11:23 PM
I still think your going to be pushing way more HP than that on a GT35R.... I guess at 15psi maybe... but that turbo is made to be pushed to like 35psi... My boost controller allows a scramble mode and a dual boost setting. I may push it a little. The 2000cc injectors are big enough to support over 700hp. They were recommended by Turblown. The ball bearing should help it spool and the water cooling will help keep it from burnig up. It will definitely be capable of higher hp numbers than I plan to run normally. |
Andyrew |
Dec 12 2010, 03:17 PM
Holy Shit, 2000CC? how many do you use? for the A4, 4ea 1k CC injectors an push 700hp..
HKS boost controller? Which one? We have an Apexi AVC-r boost controller on the 951 and the A4. Old technology but it works like a dream.. |
Lo-Fi Version | Time is now: 25th November 2024 - 11:26 PM |
