Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
So far only 4 sets of cores have shown up. I'll have these ready next week.
hwgunner |
914 Parts @ Discount Prices 800.321.5432 ![]() ![]() ![]() Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None ![]() |
Shipped all the sets purchased from me 2 days ago. You should see them shortly.
jonathan (IMG:style_emoticons/default/beerchug.gif) |
Mikey914 |
The only other set of visors are too nice to cut up, but this is what we need when I say stripped. So, to strip the sunvisor, you just cut away the vinyl and padding and clean up the frame? I sort of hate to cut mine up since they are intact, but they need recovering. What is a good way to ship these to Mark? Will a pair fit in a large US Postal Service flat rate box which is $10.70. Should additional stiffening or padding be added to the visor frames? Thanks. Sory didn't answer the part with the shipping. These don't fit into a flat rate box very well, anything you can find to ship in is fine as they are lite. -Mark |
sawtooth |
Member ![]() ![]() Group: Members Posts: 297 Joined: 25-June 08 From: Boise, ID Member No.: 9,211 Region Association: Intermountain Region ![]() |
Any chance of still getting in on the group buy? Sent a pm. Thanks.
drken |
Newbie ![]() Group: Members Posts: 14 Joined: 13-November 10 From: Columbia, IL Member No.: 12,382 Region Association: None ![]() |
yellowporky |
Member ![]() ![]() Group: Members Posts: 427 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California ![]() |
I would like to get in on this also.
Thanks, Chris |
Rod |
Senior Member ![]() ![]() ![]() Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England ![]() |
I found a couple more sets of cores if any one is in need. $25/set shipped to Mikey914. (IMG:style_emoticons/default/beerchug.gif) If these are still availabe can I please take them? Can I have them made into a full blown leather set together with clips please mikey? (IMG:style_emoticons/default/smile.gif) |
Mikey914 |
PMs sent to all so far
rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
I haven't sent mine in yet due to the weather mess in the southeast. I hope to box them up this weekend. If we are going to use the existing pins that the visors pivot on should we send them so you can insert them in the new visors ? Or do we insert the pins once we receive the recovered visors ? Thanks
rfuerst911sc |
Stripped mine of the vinyl today.....WOW... the inside foam was just dust and powder. The one frame is a little rusty should I clean that up before shipping ? And do you need the pivot pins sent if we are using our old ones ? I hope to ship mine out Tuesday.
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,629 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
For those puzzling over the way to box these, what I did is to take two USPS flat rate boxes and cut the tabs off of one of the open ends. I closed up the other two ends and then put the visors inside one and pushed the other over the end of it. It helps if you use one Priority Mail box and the other Express Mail. The Express Mail are just slightly larger and that facilitates the slip over. The boxes I used are the flat ones about 3"X12"X15" or so. Of course, you have to then take brown paper grocery bags and cover this assembly as the PO will not ship it unless you do...
Mikey914 |
Stripped mine of the vinyl today.....WOW... the inside foam was just dust and powder. The one frame is a little rusty should I clean that up before shipping ? And do you need the pivot pins sent if we are using our old ones ? I hope to ship mine out Tuesday. Just knock the loose rust off to make sure the cores are solid (haven't found any that were not yet) I don't need the pivot pins as they are part of the visor clip mounts. You may want to check to make sure the pins fit in the mounts good enough to hold the visors. I do have the clips available if you need one or all. th eproblem is if you replace one it will look nicer than the others (IMG:style_emoticons/default/biggrin.gif) |
girellr |
Newbie ![]() Group: Members Posts: 31 Joined: 24-August 08 From: Anniston, Alabama Member No.: 9,453 Region Association: South East States ![]() |
I sent mine today via. UPS from Anniston/Oxford Alabama. I am pretty sure I wrote return address on envelope with check inside. If not just use address on check. Thanks Mikey914 and you can get me at rgirello@cableone.net.
Beach914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 970 Joined: 28-March 10 From: Aliso Viejo Member No.: 11,519 Region Association: Southern California ![]() ![]() |
Mike,
Am I too late to get in also? I picked up a set of cores yesterday at the Pomona swap meet. Thx David |
Mikey914 |
David,
PM sent - I did get a shipment if from GPR and I'm trying to mact up the following info- Stoneham- trying to macth with payment - and what "package" you want. Tamura- trying to macth with payment - and what "package" you want. Can be as simple as your paypal not listing your name. Please ler me know so I can process. I have more GPR cores coming later this week. |
rfuerst911sc |
I finally found a box suitable for shipping. I packed them up yesterday and they are on their way via UPS. Check is in the box in an envelope along with a note with return address and that I wan the " full up " visor treatment (IMG:style_emoticons/default/biggrin.gif) . Sorry for the delay in shipping these out. (IMG:style_emoticons/default/sad.gif)
Rod |
Please let me know when my cores have arrived with you and whether they are stripped or not?? Then I'll be able to get the paypal total to you..
I also need a new pair of roof holders in the trunk - both the ones I bought from you have broken (IMG:style_emoticons/default/sad.gif) |
Mikey914 |
If you are Stonham with cores coming from GPR, yes I ahve them, PM me the specifics of what you want and I'll get them rolling,
Mark |
Rod |
If you are Stonham with cores coming from GPR, yes I ahve them, PM me the specifics of what you want and I'll get them rolling, Mark They are coming from gpr, but I'm not stonham!! Will be marked with my username. Mine are going back to the UK, to Farnham Antique Carpets Ltd. |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Mark... can I send a set of visors in for the full treatment?
Lo-Fi Version | Time is now: 25th June 2024 - 06:19 PM |
