Valve cover gasket glue, what do you use |
Krieger |
Dec 18 2010, 08:54 PM
Advanced Member Group: Members Posts: 4,766 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I went in asking for Gask-a-cinch and the oldtimer at my favorite flaps told me this is the stuff to have: a tube of 3M Super Weatherstrip and Gasket Adhesive. Any experience with this stuff? What do you fellas use?
Jake Raby |
Dec 18 2010, 09:01 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
The 3m works well.. Just use it on the valve cover side, then grease the side that fits to the head.
I didn't change the valve cover gaskets on my 912E engine over 160K miles using this method. |
charliew |
Dec 18 2010, 09:14 PM
I always used the 3m but it is a job putting on new gaskets and cleaning the 3m off. What about using a silicon adhesive on the valvecover side? I would think it would clean off a lot easier.
quadracerx |
Dec 18 2010, 09:15 PM
Member Group: Members Posts: 427 Joined: 3-July 06 From: WA Member No.: 6,366 Region Association: Pacific Northwest |
Yea it works REALLY GOOD....used to call it "Yellow Gorilla Snot" be careful with it..it tends to get everywhere you dont want it to....and its kinda like welds stuff together...LMAO
Good Luck.... Steve |
Krieger |
Dec 18 2010, 09:18 PM
The 3m works well.. Just use it on the valve cover side, then grease the side that fits to the head. I didn't change the valve cover gaskets on my 912E engine over 160K miles using this method. Thanks Jake. I don't think I've changed out my gaskets in 8-9 years. 10k miles in that time. Its time to check the valves and I figured while I was in there maybe its time. I have 0 leaks. What do you think Jake do it or not? I probably won't get in there for another 2 years to check vavle lash. |
mrbubblehead |
Dec 18 2010, 09:23 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i use gask-a-cinch on the cover side. dry on the head side.
Krieger |
Dec 18 2010, 09:26 PM
sww914 |
Dec 18 2010, 09:37 PM
Contact cement on the cover side, dry on the head side. They last a long time.
Jake Raby |
Dec 18 2010, 10:15 PM
I didn't have to change the gaskets in 8 years/ 160,000 miles.
If its not leaking, then don't worry about sealing them. |
mrbubblehead |
Dec 18 2010, 10:21 PM
i use gask-a-cinch on the cover side. dry on the head side. I could not find the gask a cinch. probably illegal in california. i live in california, maybe try napa. i think kragens carries it. i coat one side of the gasket with it and then the valve cover. let it dry for about 5 minutes and stick them together. you need to be accurate when you join them together because you only get one shot at it. once the gasket touches the valve cover theres no repositioning it. the reason i like gask-a-cinch over the 3m is when its time for new gaskets they come of with a putty knife with minimal prep. usually a wire brush will do. the 3m takes alot of work to get off. IMO. not near as messy also. |
VaccaRabite |
Dec 19 2010, 09:20 AM
En Garde! Group: Admin Posts: 13,615 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I use the 3M stuff too. A very thin smear on the valve cover side. Almost never have to swap out gaskets.
Zach |
StratPlayer |
Dec 19 2010, 11:10 AM
StratPlayer Group: Members Posts: 3,299 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
davesprinkle |
Dec 19 2010, 11:16 AM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
We're talking about the cork seals, right? Why do you use sealer? I've just greased both sides with no leaks.
Bartlett 914 |
Dec 19 2010, 12:59 PM
Advanced Member Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
We're talking about the cork seals, right? Why do you use sealer? I've just greased both sides with no leaks. So the gasket will stay in place better when you install the valve cover. By not sealing the engine side, the gasket can slide a little against the head without moving the gasket out of place. |
NC_Colfax |
Dec 19 2010, 07:38 PM
Member Group: Members Posts: 130 Joined: 26-July 10 From: North Carolina Member No.: 11,982 Region Association: South East States |
I used a couple of drops of super glue. Worked very well for me under the car.
Pat Garvey |
Dec 19 2010, 07:43 PM
VaccaRabite |
Dec 20 2010, 06:52 AM
We're talking about the cork seals, right? Why do you use sealer? I've just greased both sides with no leaks. So the gasket will stay in place better when you install the valve cover. By not sealing the engine side, the gasket can slide a little against the head without moving the gasket out of place. With mine, I bought a lot of the cork gaskets at once one day, and they are kinda warped. If I put the gasket on w/o sealant on the cover, it will not lay flat and I get a huge leak. A super thin smear of sealant to glue it to the valve cover, and it is good to go for a LONG time. If grease is working for you, great! Will save you time cleaning up the sealant when the gasket has to finally be retired. Zach |
stugray |
Dec 20 2010, 07:07 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I will probably get flamed for this, but here is what I did on my ghia & previous 914:
I used blue RTV to glue the gasket into the valve cover, put it in place and "slightly" clamped it in place. This guarantees it drys flat. Once that was dry I put a very thin film of RTV on the head side and let it dry. They never leaked again after that and lasted for years. Stu |
VaccaRabite |
Dec 20 2010, 08:02 AM
But, how did you check your valves?
Zach |
stugray |
Dec 20 2010, 09:08 AM
The RTV was allowed to dry before replacing the covers, so they went on & off with no trouble.
It just made the cork gasket more "silicone like". Stu |
Lo-Fi Version | Time is now: 22nd December 2024 - 12:00 AM |
