Engman Fuse Panel Group buy, (a couple more were made available!) see page 5. |
Krieger |
Dec 29 2010, 05:38 PM
Advanced Member Group: Members Posts: 4,769 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
So what are the advantages of this outside of the new style fuses? The one on my 75 is great. I am going to start on the wiring for my 72.
Mike Bellis |
Dec 29 2010, 07:25 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
So what are the advantages of this outside of the new style fuses? The one on my 75 is great. I am going to start on the wiring for my 72. The advantage is the contact point of the fuse. Early German fuses are notorious for corrosion build up. Some times you can spin the fuse and make it work again. The ATC style fuse has a positive mechanical contact point. The stock spring copper mounting tabs for the fuse are exposed and can break. If you bump the stock panel with your leg, the fuses will fall out. This is bad while driving. There is higher resistance on the stock fuse panel, this can lead to excessive heat build up. |
jeffdon |
Dec 30 2010, 09:38 AM
I'm in.
Jerry75914 |
Dec 30 2010, 11:21 AM
Member Group: Members Posts: 124 Joined: 13-October 08 From: Half Moon Bay, CA Member No.: 9,640 Region Association: Northern California |
I'm in for one. This has been on my wish list for a long time, thanks!
saigon71 |
Dec 30 2010, 06:15 PM
Advanced Member Group: Members Posts: 2,006 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
In for one. Thanks for setting this up.
bigkensteele |
Dec 30 2010, 10:02 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Count me in for one.
rfuerst911sc |
Dec 31 2010, 06:37 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
Can payment be done by a check ?
Cairo94507 |
Dec 31 2010, 08:53 AM
Michael Group: Members Posts: 10,130 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
OK; I need one of these too. Is it safe to assume the is no difference for a factory six? I want one of these so please let me know where to send the $.
Thanks, Michael |
RJMII |
Dec 31 2010, 07:02 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
QUOTE OK; I need one of these too. Is it safe to assume the is no difference for a factory six? Thanks, I'll look into it. I wish I could just look under my dash... (IMG:style_emoticons/default/biggrin.gif) I don't have a real six, though. |
sixgt |
Dec 31 2010, 07:12 PM
Member Group: Members Posts: 70 Joined: 14-November 07 From: left coast Member No.: 8,337 |
I'll take one. Thanks!
Daiberl |
Jan 1 2011, 11:20 AM
Senior Member Group: Members Posts: 574 Joined: 22-June 09 From: Seattle, WA Member No.: 10,497 Region Association: Pacific Northwest |
I'm in for one.
Mr.242 |
Jan 1 2011, 11:49 AM
May your glass be smaller so it's always FULL! Group: Members Posts: 1,079 Joined: 10-June 08 From: Seattle Member No.: 9,160 Region Association: Pacific Northwest |
+1 too!
Happy New Year to me! Resolution done already? (IMG:style_emoticons/default/piratenanner.gif) (set the bar low everytime and I feel like I accomplish something) |
rfuerst911sc |
Jan 1 2011, 04:32 PM
Maybe I can get an answer in 2011 (IMG:style_emoticons/default/dry.gif) ......can I pay by check ?
Engman |
Jan 1 2011, 04:57 PM
Zoisite Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
Thanks for all of the responces - I will try to answer your questions
1< Yes you can pay by check. 2< Yes it will work on the 914-6 models. I orginally made this for my car, others members saw it and thus the product was born. I hated knocking out the cover and fuses with my feet and I had some copper corrosion issues that needed to be addressed. I do include detailed installation instructions along with wire markers for the swap. As far as timeline - expect it to take about a month after I have collected the fee. It may be sooner or a liltle later depending on when the parts arrive. Thanks Mark |
gothspeed |
Jan 1 2011, 05:05 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Does it have spade connectors for the fuses on the topside like the factory version?
I gather those bigger holes are for the rubber relay sockets? Any room for extra fuse circuits? If so I will take one (IMG:style_emoticons/default/smile.gif)! |
Engman |
Jan 1 2011, 05:11 PM
Does it have spade connectors for the fuses on the topside like the factory version? I gather those bigger holes are for the rubber relay sockets? Any room for extra fuse circuits? If so I will take one (IMG:style_emoticons/default/smile.gif)! Plug and play - no sodering or wire cutting. Uses spade connectors. The larger holes are indeed for the relays. Thanks Mark |
gopack |
Jan 1 2011, 05:36 PM
CHEESEHEAD in CA, MARK Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
Please let me know when and where to send the check. In for one.
TurboWalt |
Jan 2 2011, 12:11 AM
Member Group: Members Posts: 157 Joined: 14-March 10 From: Chattanooga, TN Member No.: 11,463 Region Association: Northern California |
moparrob |
Jan 2 2011, 12:37 AM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
Count me in. One more thing to add to the list for 2011....
leebenedi |
Jan 2 2011, 05:41 AM
Newbie Group: Members Posts: 43 Joined: 21-April 09 From: Los Hueros Member No.: 10,284 Region Association: Spain |
Hi Mark. What are the shipping costs to Spain?
Lo-Fi Version | Time is now: 26th December 2024 - 11:46 PM |
