Andyrews Progress Thread, 1/16/22 A Trip to The Red Barn - Lets fab a Firewall! |
Andyrew |
Apr 17 2011, 02:18 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Im lazy (IMG:style_emoticons/default/smile.gif) The Christmas lights are stapled in (IMG:style_emoticons/default/ohmy.gif)..
computers4kids |
Apr 17 2011, 02:54 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Andrew, forget all the timing tweaks etc, just put a block of wood under the pedal (IMG:style_emoticons/default/biggrin.gif) V8 owners drive sensibly. (IMG:style_emoticons/default/piratenanner.gif)
Andyrew |
Apr 17 2011, 03:58 PM
1/2 throttle still pushes over 300lbs of tq to the wheels off idle.. Messing with the timing should help push the powerband up
Andyrew |
Apr 25 2011, 10:47 AM
Hows about an update?
Saturday morning I installed a 2500CFM fan in the garage! Picked it up for $100 from a body shop that decided to stop priming in their main shop. (original price was $260). Up and running in a hour! (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1303750060.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1303750061.2.jpg) Spent a bunch of time sanding the cowl area (read 4+ hours.. Apparently no one bothers to sand those vent holes and the wiper holes) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1303750062.3.jpg) Sanded and primed the rear as well (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1303750062.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1303750063.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1303750064.6.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1303750065.7.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1303750065.8.jpg) All went well till I went for a second layer of primer on the targa bar.. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1303750066.9.jpg) I was PISSED OFF... This was supposed to be the last final layer of primer on this side.. Damn. I sanded this all down last night and its ready for a second coat of primer fill on a couple area's. So i'll get the fender and those area's in primer tonight hopefully. Im ordering paint today FYI. (IMG:style_emoticons/default/smile.gif) |
tdgray |
Apr 25 2011, 12:07 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
(IMG:style_emoticons/default/smile.gif) Been there done that... at least it wasn't in your clear coat... mine was (IMG:style_emoticons/default/sad.gif)
rick 918-S |
Apr 25 2011, 12:22 PM
Hey nice rack! -Celette Group: Members Posts: 20,786 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Looking good man! That fan should work nice.
Andyrew |
Apr 25 2011, 12:51 PM
(IMG:style_emoticons/default/smile.gif) Been there done that... at least it wasn't in your clear coat... mine was (IMG:style_emoticons/default/sad.gif) I was rushing myself.. Not enjoying the process because a friend of mine was pissing me off so I wasnt thinking. When I spray I will have 2 others in the garage, one on each side of the car. Their whole job is to keep me from either leaning on the car, or keep the hose from touching the car. |
Mike Bellis |
Apr 25 2011, 06:34 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Awesome! I want to paint mine Now... (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/popcorn[1].gif)
Andyrew |
Apr 27 2011, 12:03 AM
Paint is ordered.
One gallon of single stage with appropriate reducer and hardner. I also got a quart of primer sealer by direction of my paint buddies, apparently the primer I was using isnt actually a sealer. However he did tell me that what I should do is prep the body with 220 grit and lay down the primer sealer, Then while the primer is still wet (10 mins later), lay down the first coat of paint and then the subsequent layers of paint. He says that it just turns out amazing. I trust him, and I have plenty of paint to be able to make touch ups if I need to. I sprayed the area's that I needed to finish, so the whole car, minus the front trunk is in final primer. I have some touch up pitting in the targa bar that i'll fix over the next week, and i'll get the front trunk done this weekend. Once the paint comes in then I think i'll start by test spraying the targa top. |
charliew |
Apr 27 2011, 12:14 AM
I wouldn't paint over primer that hasn't dried. Non sanding sealer is good for at least 12 hours to recoat. But the data sheet doesn't say anything about painting over it before it dries. When you build up several coats of paint it can take weeks or months for the paint to dry completely. That will be where the shrinkage will show up.
Andyrew |
Apr 27 2011, 08:59 AM
The primer that I bought is supposedly good for wet on wet application, AKA its built for this.
However I cant say that im more than skeptical, which is why I posted this. This is what I got http://www.tcpglobal.com/kustomshop/itemde...S+KIT-KEP505-QT HOWEVER looking at it now I think I got the wrong thing.. This is epoxy primer/seal.. I believe I wanted Urithane epoxy/seal.. aka this stuff. http://www.tcpglobal.com/kustomshop/itemde...o=KUS+KUP405-QT Since I went with a urithane paint.. aka this http://www.tcpglobal.com/restorationshop/i...SP+AU1805-KIT-M. I was also told to spray the primer with a fast reducer (which I picked some of that up).. I placed this on Monday, so im going to call and see if I can get them to change the order to urithane primer, not epoxy. |
Andyrew |
May 3 2011, 12:26 AM
OK so last weekend was a test on my part for painting and setting up the garage for painting. I learned that I need to either do a LOT more prep in the garage to prevent any dirt from getting in the paint and I also need to work on painting vertically as I had more runs than I was comfortable with. I also need to work on gun setup as I think I had to much paint spraying out of the gun, which contributed to the runs.
Today I sanded the targa top in 180 and layed 3 layers of primer on it. I am going to sand it down to 400 and practice spraying vertically on it this weekend. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304404009.1.jpg) I sanded and sprayed the hood down, but its obvious to me it needs quite a bit of bodywork to be straight. This may take some time. Guide coat went on after. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304404010.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304404010.3.jpg) I opened up my paint that I bought and compared it to the factory phoenix red. Almost an exact match, I stared at it for quite a while before I realized that the Hugger Orange was just a TAD more red. Which I am really happy with as I wanted it to be a tad more red!!! I also realized that I have a LOT of paint to spray this tiny car... The crown vic that I sprayed last weekend took 1/3 a gallon on 3 heavy coats. I am probably going to spray 7-10 coats on this car and still only use 1/3 of a gallon!! And this car should be a breeze compared to the big crown vic. |
Andyrew |
May 3 2011, 12:31 AM
(IMG:http://www.914world.com/bbs2/uploads_offsite/i124.photobucket.com-172-1304404300.1.jpg) Here is a pic of the crown vic 3 days later.
Andyrew |
May 3 2011, 01:04 PM
Woo Hoo! Carpet kit came in! Cant wait to get it installed! Bought a cheap lightweight kit off ebay ($75 shipped after negotiation!). I'll be glueing it in after paint.
Andyrew |
May 4 2011, 11:49 PM
Hey look.
I sprayed some orange! Just as a preface, this was a test run. I had a lot more runs when I sprayed the crown vic last weekend than I wanted. So I went and practiced on the targa top this evening. I went and sanded the top down to 320 and went ahead and sprayed it after degreasing it. I spoke with my paint shop next door to my work and he said that he reduces the single stage only 10% even if it calls for 25% on the sheet. I went ahead and reduced it to about 17.5 as I wanted to actually get some practice laying the coats a little thinner so I could improve my technique. I sprayed the top almost completely vertical. First coat went on with no problem and no runs. Second coat I couldnt see very well and obviously overlapped more than I should have and caused runs. I believe I went to slow in the spraying of the paint as well. Anyways Here are some pics of this gorgeous color! I am really liking this paint from TCPGlobal. Its a bit thin, but it really has a nice shine for 110 bucks a gallon (with reducers and hardners). (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304574564.1.jpg) One coat (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304574564.2.jpg) Two coats (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304574632.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304574564.4.jpg) Shot of the runs I will be sanding this down (I will practice wet sanding and buffing, then i'll sand it down to 400) and respraying it for more practice. I did not prep the garage at all and so there is a bit of dust, but even worse there are a TON of bugs in the paint.... I did NOT have this issue with the Crown Vic. Granted it is night and I sprayed the crown vic around noon. The bugs came in about an hour after spraying, It didnt help that I let the paint dry horizontally... |
shoguneagle |
May 5 2011, 12:47 AM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Andrew,
Great job in painting and preparation. It is nice that you are finally seeing the car completed as you dreamed when you started several years ago. I will definitely come by and see the car if available during June when we are on our way to Oregon. We are going to look at property, not the West Coast meet. We are going to go to the Parts Heaven Parts Swap on I believe the 5th. Getting rid of my extra parts left over from the car build. Keep up the good work. Since you are painting your car, I think I will consider doing mine. Will be talking to you. Again, Great Job. Steve Hurt |
Andyrew |
May 6 2011, 09:45 AM
Steve,
I will not be going to the parts heaven swap meet, unfortunately I have way to much going on this month and next in preparation for my GF's graduation and for a local car show (where I will be "unveiling" the car) I've got a lot of thoughts on the DIY'er paint job. |
Andyrew |
May 6 2011, 09:54 AM
So.. I liked it so much on Wed that I decided to do it again! (IMG:style_emoticons/default/smile.gif)
I tried to do the setup that was told to me by my paint guy. I sanded down to 220. I then primered it with primer sealer (This was epoxy primer/hardner.. And I reduced it with urethane reducer.. Again I bought the wrong primer...) On a fast reducer. Then 10 mins later I hit it with the first coat. I also only reduced the paint down 10% with medium reducer. I hated it, It was so thick and unworkable. Spray pattern was a lot worse this way as well. I think it layed out very dry. So on the next coats I added more reducer and the last coat I added even more reducer. Here is another thing I noticed. With the light grey primer, I had full coverage in 2 coats. With the grey epoxy primer underneath, I didnt even get full coverage after 4 coats. One thing I did notice is that most of the scratches were hidden. I think I thinned the epoxy primer to much so I didnt have the hide that I really could have had, but regardless. It was certainly a learning curve. Less bugs this time as well, I shut the back door this time (IMG:style_emoticons/default/smile.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304697293.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304697293.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304697293.3.jpg) |
dlo914 |
May 6 2011, 10:29 AM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
Awesome job on painting! I wish i had the patience for painting. :\ Also the shaved targa sail looks very nice, i've been debating on doing that for our car as well to eliminate a bit of chrome from our car. Keep up the good work!
Mike Bellis |
May 6 2011, 08:42 PM
Great progress. Keep it up! (IMG:style_emoticons/default/beer.gif)
Lo-Fi Version | Time is now: 26th November 2024 - 09:31 PM |
