44 Pages V « < 6 7 8 9 > »
> Andyrews Progress Thread, 1/16/22 A Trip to The Red Barn - Lets fab a Firewall!
rick 918-S
post Apr 25 2011, 12:22 PM
Post #124
Hey nice rack! -Celette
Looking good man! That fan should work nice.
Andyrew
post Apr 25 2011, 12:51 PM
Post #125
Spooling.... Please wait
QUOTE(tdgray @ Apr 25 2011, 11:07 AM) *
(IMG:style_emoticons/default/smile.gif) Been there done that... at least it wasn't in your clear coat... mine was (IMG:style_emoticons/default/sad.gif)
I was rushing myself.. Not enjoying the process because a friend of mine was pissing me off so I wasnt thinking.
When I spray I will have 2 others in the garage, one on each side of the car. Their whole job is to keep me from either leaning on the car, or keep the hose from touching the car.
Mike Bellis
post Apr 25 2011, 06:34 PM
Post #126
Resident Electrician
Awesome! I want to paint mine Now... (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/popcorn[1].gif)
Andyrew
post Apr 27 2011, 12:03 AM
Post #127
Paint is ordered.
One gallon of single stage with appropriate reducer and hardner. I also got a quart of primer sealer by direction of my paint buddies, apparently the primer I was using isnt actually a sealer. However he did tell me that what I should do is prep the body with 220 grit and lay down the primer sealer, Then while the primer is still wet (10 mins later), lay down the first coat of paint and then the subsequent layers of paint. He says that it just turns out amazing. I trust him, and I have plenty of paint to be able to make touch ups if I need to.
I sprayed the area's that I needed to finish, so the whole car, minus the front trunk is in final primer. I have some touch up pitting in the targa bar that i'll fix over the next week, and i'll get the front trunk done this weekend.
Once the paint comes in then I think i'll start by test spraying the targa top.
charliew
post Apr 27 2011, 12:14 AM
Post #128
I wouldn't paint over primer that hasn't dried. Non sanding sealer is good for at least 12 hours to recoat. But the data sheet doesn't say anything about painting over it before it dries. When you build up several coats of paint it can take weeks or months for the paint to dry completely. That will be where the shrinkage will show up.
Andyrew
post Apr 27 2011, 08:59 AM
Post #129
The primer that I bought is supposedly good for wet on wet application, AKA its built for this.
However I cant say that im more than skeptical, which is why I posted this.
This is what I got
http://www.tcpglobal.com/kustomshop/itemde...S+KIT-KEP505-QT
HOWEVER looking at it now I think I got the wrong thing.. This is epoxy primer/seal.. I believe I wanted Urithane epoxy/seal.. aka this stuff.
http://www.tcpglobal.com/kustomshop/itemde...o=KUS+KUP405-QT
Since I went with a urithane paint.. aka this
http://www.tcpglobal.com/restorationshop/i...SP+AU1805-KIT-M.
I was also told to spray the primer with a fast reducer (which I picked some of that up)..
I placed this on Monday, so im going to call and see if I can get them to change the order to urithane primer, not epoxy.
Andyrew
post May 3 2011, 12:26 AM
Post #130
OK so last weekend was a test on my part for painting and setting up the garage for painting. I learned that I need to either do a LOT more prep in the garage to prevent any dirt from getting in the paint and I also need to work on painting vertically as I had more runs than I was comfortable with. I also need to work on gun setup as I think I had to much paint spraying out of the gun, which contributed to the runs.
Today I sanded the targa top in 180 and layed 3 layers of primer on it. I am going to sand it down to 400 and practice spraying vertically on it this weekend.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304404009.1.jpg)
I sanded and sprayed the hood down, but its obvious to me it needs quite a bit of bodywork to be straight. This may take some time. Guide coat went on after.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304404010.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304404010.3.jpg)
I opened up my paint that I bought and compared it to the factory phoenix red. Almost an exact match, I stared at it for quite a while before I realized that the Hugger Orange was just a TAD more red. Which I am really happy with as I wanted it to be a tad more red!!! I also realized that I have a LOT of paint to spray this tiny car... The crown vic that I sprayed last weekend took 1/3 a gallon on 3 heavy coats. I am probably going to spray 7-10 coats on this car and still only use 1/3 of a gallon!! And this car should be a breeze compared to the big crown vic.
Andyrew
post May 3 2011, 12:31 AM
Post #131
(IMG:http://www.914world.com/bbs2/uploads_offsite/i124.photobucket.com-172-1304404300.1.jpg) Here is a pic of the crown vic 3 days later.
Andyrew
post May 3 2011, 01:04 PM
Post #132
Woo Hoo! Carpet kit came in! Cant wait to get it installed! Bought a cheap lightweight kit off ebay ($75 shipped after negotiation!). I'll be glueing it in after paint.
Andyrew
post May 4 2011, 11:49 PM
Post #133
Hey look.
I sprayed some orange!
Just as a preface, this was a test run. I had a lot more runs when I sprayed the crown vic last weekend than I wanted. So I went and practiced on the targa top this evening.
I went and sanded the top down to 320 and went ahead and sprayed it after degreasing it.
I spoke with my paint shop next door to my work and he said that he reduces the single stage only 10% even if it calls for 25% on the sheet. I went ahead and reduced it to about 17.5 as I wanted to actually get some practice laying the coats a little thinner so I could improve my technique. I sprayed the top almost completely vertical. First coat went on with no problem and no runs. Second coat I couldnt see very well and obviously overlapped more than I should have and caused runs. I believe I went to slow in the spraying of the paint as well.
Anyways Here are some pics of this gorgeous color! I am really liking this paint from TCPGlobal. Its a bit thin, but it really has a nice shine for 110 bucks a gallon (with reducers and hardners).
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304574564.1.jpg)
One coat
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304574564.2.jpg)
Two coats
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304574632.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304574564.4.jpg)
Shot of the runs
I will be sanding this down (I will practice wet sanding and buffing, then i'll sand it down to 400) and respraying it for more practice.
I did not prep the garage at all and so there is a bit of dust, but even worse there are a TON of bugs in the paint.... I did NOT have this issue with the Crown Vic. Granted it is night and I sprayed the crown vic around noon. The bugs came in about an hour after spraying, It didnt help that I let the paint dry horizontally...
shoguneagle
post May 5 2011, 12:47 AM
Post #134
shoguneagle
Andrew,
Great job in painting and preparation. It is nice that you are finally seeing the car completed as you dreamed when you started several years ago. I will definitely come by and see the car if available during June when we are on our way to Oregon. We are going to look at property, not the West Coast meet. We are going to go to the Parts Heaven Parts Swap on I believe the 5th. Getting rid of my extra parts left over from the car build.
Keep up the good work. Since you are painting your car, I think I will consider doing mine. Will be talking to you.
Again, Great Job.
Steve Hurt
Andyrew
post May 6 2011, 09:45 AM
Post #135
Steve,
I will not be going to the parts heaven swap meet, unfortunately I have way to much going on this month and next in preparation for my GF's graduation and for a local car show (where I will be "unveiling" the car)
I've got a lot of thoughts on the DIY'er paint job.
Andyrew
post May 6 2011, 09:54 AM
Post #136
So.. I liked it so much on Wed that I decided to do it again! (IMG:style_emoticons/default/smile.gif)
I tried to do the setup that was told to me by my paint guy.
I sanded down to 220. I then primered it with primer sealer (This was epoxy primer/hardner.. And I reduced it with urethane reducer.. Again I bought the wrong primer...) On a fast reducer. Then 10 mins later I hit it with the first coat. I also only reduced the paint down 10% with medium reducer. I hated it, It was so thick and unworkable. Spray pattern was a lot worse this way as well. I think it layed out very dry. So on the next coats I added more reducer and the last coat I added even more reducer.
Here is another thing I noticed. With the light grey primer, I had full coverage in 2 coats. With the grey epoxy primer underneath, I didnt even get full coverage after 4 coats.
One thing I did notice is that most of the scratches were hidden. I think I thinned the epoxy primer to much so I didnt have the hide that I really could have had, but regardless. It was certainly a learning curve.
Less bugs this time as well, I shut the back door this time (IMG:style_emoticons/default/smile.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304697293.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304697293.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304697293.3.jpg)
dlo914
post May 6 2011, 10:29 AM
Post #137
Whatchu' lookin' at?!?!
Awesome job on painting! I wish i had the patience for painting. :\ Also the shaved targa sail looks very nice, i've been debating on doing that for our car as well to eliminate a bit of chrome from our car. Keep up the good work!
Mike Bellis
post May 6 2011, 08:42 PM
Post #138
Great progress. Keep it up! (IMG:style_emoticons/default/beer.gif)
Andyrew
post May 7 2011, 02:19 AM
Post #139
3rd day in a row? Whats wrong with me?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304756392.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304756393.2.jpg)
Practiced thinner applications of the paint. Also used 25% reducer.
I did NOT go with the epoxy primer base. I noticed some tiny 'cuping' or little dents in the paint which i would think would be some chemical reaction, say vapors not releasing or so on the trunk. I will NOT be spraying the epoxy down as a base on the body. I am going to go over the primer I have for the chemical reaction reason and because it lays down VERY nice over the base. Great coverage.
Engine lid came out nice. I did very little work on this and it shows, couple of dents that I didnt notice it till final sanding (at which I had already told myself I was painting tonight).
arkitect
post May 7 2011, 08:39 AM
Post #140
Great job Andrew! Nice to see some color going on. In the past I've painted both ways over primer and over a sealer. It seamed that when I went over primer I had less issues because I was doing it in the garage too with all the bugs and dust. My biggest help was laying down some water on the concrete floor to keep the dust down and painting before the evening. Even with lights at night its nice to be able to see by natural light as your painting.
Can't wait to see it. Dave
FourBlades
post May 7 2011, 10:41 AM
Post #141
From Wreck to Rockin
That is a great looking color.
You are getting a lot of good practice in, which seems like the only way to learn
to paint.
Can't wait to see the car reassembled.
John
Spoke
post May 8 2011, 05:04 AM
Post #142
Jerry
Love the color. My first new car was a 1974 Dodge (Mitsubishi) Colt and I painted it orange and about the same shade as yours.
arkitect
post May 8 2011, 08:53 AM
Post #143
Andrew,
Are you painting today?
- Lo-Fi Version Time is now: 30th December 2024 - 11:06 AM
