Andyrews Progress Thread, 1/16/22 A Trip to The Red Barn - Lets fab a Firewall! |
Mike Bellis |
Oct 24 2011, 07:08 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Is there a 914 caravan to the wedding? (IMG:style_emoticons/default/poke.gif)
Andyrew |
Oct 27 2011, 10:52 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
There is a 914 going FROM the wedding (IMG:style_emoticons/default/smile.gif)
Update on the car, Going in for a dyno tune tomorrow. Im looking for 225whp and 250wtq. (I have to consider that I have 100lbs in wheels and tires in the back) but most importantly im looking for smooth tq curve, smooth power through the powerband, better cruising (it never was that bad..), better cold starts, and better gas mileage. |
arkitect |
Oct 27 2011, 11:38 PM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
Andrew,
Good looking picts. Great idea!!!!!!!!! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) Dave |
Andyrew |
Oct 28 2011, 02:18 PM
Dyno tune is done. Found a couple of problems and fixed them (Mostly I was running without the secondary's... Vacuum pod had a solid gasket instead of an O ring. ). I need to figure a bigger air cleaner system as thats witholding some power, and I also need to go a general tuneup (wires, plugs, ect).
Overall it pushed out 235whp and 295wtq. It made at least 250wtq from 2k-5k rpms. I havent gotten to drive it yet but I am sure looking forward to it! Its supposedly very smooth and sounds really good. |
ewdysar |
Oct 28 2011, 03:03 PM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
Dyno tune is done. Found a couple of problems and fixed them (Mostly I was running without the secondary's... Vacuum pod had a solid gasket instead of an O ring. ). I need to figure a bigger air cleaner system as thats witholding some power, and I also need to go a general tuneup (wires, plugs, ect). Overall it pushed out 235whp and 295wtq. It made at least 250wtq from 2k-5k rpms. I havent gotten to drive it yet but I am sure looking forward to it! Its supposedly very smooth and sounds really good. Is that still carb'ed or did you switch back to the FI setup? |
Andyrew |
Oct 28 2011, 03:05 PM
Still carbed. I have to build a megasquirt or pay 1500 for a computer to go back to FI.
Andyrew |
Oct 28 2011, 03:47 PM
Heres the dyno. Red line is current. Blue line is 2005 dyno. Dont know why they didnt rev it past 5k but thats ok.
Keep in mind blue line is with 16" fuch's and 225 50 tires, red line is with 18" turbo twists with 285 35 tires. I estimate 26% drivetrain loss due to the tires, since Jake Raby estimates 25% typical loss with the 901. This puts me right around 300HP and 375lbs tq. Attached thumbnail(s) |
dan10101 |
Oct 28 2011, 09:28 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
I was at the dyno shop about 4 hours (on my day off). The day started with a BANG. A flash grenade went off about 20 minutes after I arrived about a block away. The cops were crashing someones gang/drug party at 8:30 in the morning. Another one a few minutes later. The dyno tune process is always interesting. If anyone is looking for this, Oakdale is a great shop with many skills. Besides that, it's a toy shop. I took a few pictures while I was there.
http://s719.photobucket.com/albums/ww198/d...o%20Day%202011/ Andrews car drives much better. It's amazing how quick it was on only the front 2 bb. It still made 220 hp in it's weakened state. I really should have checked the vacuum pod when I rebuilt the carb, but never thought it was a problem since it held vacuum. The tuner guy said it was a great way to keep the power down on my Son's hot rod. Just so I don't forget all the tuner guy told me, here it is.. After correcting the vacuum pod, (he found it because he was putting a lighter spring in it so it would open sooner), He did a few other things. Larger squirter for the accelerator pump to cure a dip in the power when the secondaries opened. Larger secondary main jets, was 75 now 82. Since it was lean under full throttle higher rpm. Adjusted the timing more advanced. (By ear, He really didn't like doing that) Then retarded it when it wouldn't crank over. We need to mark this and get it so we know for sure. He suggested a Van timing mark. I'm thinking there is a vibration from the crank. Maybe a self balancing harmonic balancer with a mark that we can see. (drill a hole in the firewall?) Finally, on the last run he removed the air filter. (I think he forgot to put it back on), But as with many accidents, we discovered that the HP went up 5HP with no other changes. He suggested an aircleaner with the top lid that breathes. Open on the side and top. So maybe with a few tune up parts, air cleaner, Choke kit, an a harmonic balancer the engine may finally be done, for this year. He's going to have to change those seats if he want's his wifey to be to be confortable sitting there in her wedding dress. I'm pretty sure I posted the picture of my wife and I escaping on our wedding night in HER 914. Always fun hanging out at a hot rod shop. And I think I may have sold my Gear Vendors Underdrive unit. (IMG:style_emoticons/default/cheer.gif) |
Andyrew |
Nov 3 2011, 08:55 AM
Big thanks to Dad for taking his day off on my 914!
I just picked up a couple more pictures and I just had to post a couple. There are some AMAZING ones that I am holding off showing you guys. Im just posting a couple that I dont think Jerika will care to much about me sharing. So far I have about 60 edited photo's. (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
McMark |
Nov 3 2011, 11:17 AM
Those are some great shots. You did a great job on the car, can't wait to see it in person.
BTW, did you ever pull off the transfer paper on your 914World Sticker? The clear sheet isn't part of the sticker. (IMG:style_emoticons/default/wink.gif) Attached image(s) |
orange914 |
Nov 3 2011, 12:36 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Big thanks to Dad for taking his day off on my 914! So far I have about 60 edited photo's. (IMG:style_emoticons/default/biggrin.gif) I'm not sure if you mean your dad's time off "FROM" you 914 or take these great photo's. (IMG:style_emoticons/default/biggrin.gif) The 3rd (last picture) was really cool of your faded 914 with the focused near range ground... and by the way the oil drop ties the 914 theme in together... (IMG:style_emoticons/default/beerchug.gif) |
Andyrew |
Nov 3 2011, 12:41 PM
My dad didnt take the pictures, he went to the dyno.
Ya I thought it was pretty cool about the oil drop. Oddly enough the 914 doesnt drip a single drop of oil! Mark, Ya I removed the sticker shortly after that the day that photo was taken |
Mike Bellis |
Nov 13 2011, 11:02 PM
Cool Pics!
rnellums |
Nov 14 2011, 08:29 AM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
(IMG:http://www.914world.com/bbs2/uploads/post-172-1320331510.jpg)
Amazing Pic! |
computers4kids |
Nov 14 2011, 08:42 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Those are great...my favorites are when you both are sitting on the road leaning against your car door.
Cool (IMG:style_emoticons/default/piratenanner.gif) Mark |
914.SBC |
Nov 14 2011, 03:56 PM
Member Group: Members Posts: 248 Joined: 12-December 10 From: CORONA, CA Member No.: 12,479 Region Association: None |
You know my daugheter is getting married in 5 months. She is a pro golfer and I suspect she will have similar pics in the sense that you captured both of your true loves. GREAT PICS.... (IMG:style_emoticons/default/beerchug.gif)
Well done... |
matthepcat |
Nov 15 2011, 01:12 AM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Andrew,
What carb are you using for that latest dyno graph? |
Andyrew |
Nov 15 2011, 01:16 AM
600 or so holley single pumper, I know with fuel injection i can hit 350hp and well over 400lbs of tq.
matthepcat |
Nov 15 2011, 01:27 AM
Lo-Fi Version | Time is now: 22nd December 2024 - 05:16 PM |
