44 Pages V « < 17 18 19 20 > »
> Andyrews Progress Thread, 1/16/22 A Trip to The Red Barn - Lets fab a Firewall!
Mike Bellis
post Jun 1 2015, 11:15 PM
Post #347
Resident Electrician
Steam Punk! (IMG:style_emoticons/default/smilie_pokal.gif)
(IMG:http://www.914world.com/bbs2/uploads/post-172-1433219330_thumb.jpg)
Mike Bellis
post Jun 1 2015, 11:17 PM
Post #348
I have a better set of 100mm axle flanges for you. Fully round without the flat spot.
Andyrew
post Jun 6 2015, 06:52 PM
Post #349
Spooling.... Please wait
QUOTE(Mike Bellis @ Jun 1 2015, 10:15 PM) *
Hahaha just saw this (IMG:style_emoticons/default/smile.gif) Very true
I've been spending a bunch of time working on my excel sheet and getting all my purchases in order.
Did some research on my water pump and decided on the Davies Craig pump and electronic controller.
http://www.amazon.com/Davies-Craig-Metal-E...ds=davies+craig
I am considering the new LCD display as well just because, but its going to get hidden behind my dash so I am not really that sure if I want it..
https://daviescraig.com.au/switches-controllers
Heres some info on the pumps and their research. Combined with their controller I think it would be a pretty efficient system..
https://www.youtube.com/watch?v=nrfux_-6RVw
https://www.youtube.com/watch?v=ia4BQR23r4I
Mike Bellis
post Jun 6 2015, 07:07 PM
Post #350
I highly recommend this pump/ It's a little cheaper too.
http://www.summitracing.com/parts/emp-e389a-bk14
I considered the davis pump but this one runs silent and is mounted in line. Works great on the 1.8t also most davis pumps ship without fittings. So there is an extra cost.
Andyrew
post Jun 6 2015, 08:15 PM
Post #351
Mike does that come with a controller like the davis pump? Because the davis pump itself is only 225, the controller is another 225/200
Mike Bellis
post Jun 6 2015, 08:27 PM
Post #352
QUOTE(Andyrew @ Jun 6 2015, 07:15 PM) *
It does not have an LCD unit. It has some kind of controller bolted to it. I simply run a relay and have it start with the fuel pump. It starts slow and ramps up to full speed in a minute or so. Only way to hear it run is with your ear stuck to it.
It also pumps 55gpm. I could not find a rating on the davies unit.
Andyrew
post Jun 6 2015, 08:57 PM
Post #353
David unit is 30 or 40 depending on the model. (Im thinking 30, they actually reccend smaller for a 1.8
Check out that first video its got some amazing test results showing how the speed did not have that much affect on actual cooling ability as it allowed the radiator to do more cooling.
The swcond vid ahows how interesting the controller is and the main reason why I want to try this system
Mike Bellis
post Jun 6 2015, 09:19 PM
Post #354
Hopefully it will work well. One this to consider is most cars also have air flow over the engine to take away heat as well. The 914 conversions don't.
I found the 1.8t mechanical pump could not flow well enough to keep my engine cool.
You will be making a lot of HP which equals heat. I want to see this pulsating pump in action.
Andyrew
post Jun 6 2015, 10:12 PM
Post #355
Mike, Are you still running the stock water pump as well, just without a thermostat?
Mike Bellis
post Jun 6 2015, 10:20 PM
Post #356
QUOTE(Andyrew @ Jun 6 2015, 09:12 PM) *
Stock pump is there with no belt and spinning freely. I have the thermostat with three 1/8" holes drilled in it.
Andyrew
post Jun 7 2015, 10:10 PM
Post #357
Mike,
I think I'll take you up on those axle flanges, I have some bus axles and adapters that I can probably just use as spacers (Or sell and make spacers) depending on my requirements there. Combine this with some 944 turbo axle stubs and it should be a relatively bolt in system..
Im still thinking I need to utilize the spacers as my ABS sensor or build the sensors on the back side of the flanges. This would take some real custom machining but I think its 100% doable. (I might enlist some help from guys with many more tools than I (IMG:style_emoticons/default/smile.gif))
Onto this weekends progress... I fabricated the base of the engine mount. I could have made this level and had the bar go across all the way but that would require a lot of measuring and the engine in place. Heck I may still do that. BUT This gets me a low clearance bar that I can tie into. Bar is 1 1/2" DOM and is pretty overkill when you really look at it. I left an extra 10" overhanging total and will just use that for the real fabrication points of the chassis to the engine and cut off the excess. I am using the stock motor mount brackets and motor mounts themselves (The one's I am currently using are racing motor mounts and a very high density, I might switch one out for a stock mount to eliminate some vibration).
Mike Bellis
post Jun 7 2015, 10:34 PM
Post #358
How are you going to clock the transaxle so the shafts are level? (IMG:style_emoticons/default/blink.gif)
I'll dig the flanges out for the next time I see you.
Andyrew
post Jun 7 2015, 11:13 PM
Post #359
I'll just adjust the engine/trans so the shafts are level. Im really not anticipating a huge issue here. Since the engine can be relatively anywhere within about 15 degrees I'll just move it forward/back left/right till the shafts are equal. The shafts will be the largest priority for the engine placement. I'll find the location that puts the trans at the right height and the shafts at an appropriate angle at right height and pivot the engine till it clears as much as possible with the largest ground clearance. I think I am going to place the engine while its on 3 small jacks and just build the mount around that.
Mike Bellis
post Jun 7 2015, 11:15 PM
Post #360
QUOTE(Andyrew @ Jun 7 2015, 10:13 PM) *
That's basically what I did. I put a level on the tranny since the motor has no real level parts.
Andyrew
post Jun 11 2015, 08:50 PM
Post #361
Got a box of goodies today!
Gonna spend quite some time identifying everything... BUT
Top box is engine harness
Bottom box is dash harness plus the gas pedal (DBW)
To the right from the top down is: Ecu, Coils, Throttle body, MAF
Not pictured is alternator, and the dash cluster itself is on its way.
What I need now is the body harness itself. So that will be difficult/fun. I've got a couple local guys parting their cars out but I havent been able to convince them to let me at their parts car with three guys for a day... I can do pick and pull but Id rather have most of the stuff ripped out by someone else (IMG:style_emoticons/default/biggrin.gif)
Mike Bellis
post Jun 11 2015, 09:18 PM
Post #362
All you need is the ECU harness, Dash cluster and harness, gas pedal and ODB plug. Everything else is extra. Wait, are you still going with the CCU?
Andyrew
post Jun 11 2015, 09:38 PM
Post #363
Yup.. Doing the whole shebang. ABS, traction control, ect. So I want to pick up a body harness to replace all of my current wiring. Whatever I dont use will either be unplugged/coded out/resistors. I'll have my tuner just remove everything I dont need.
Mike Bellis
post Jun 12 2015, 06:31 PM
Post #364
I'll be watching your wheel speed sensor solution... (IMG:style_emoticons/default/idea.gif)
Andyrew
post Jun 12 2015, 08:14 PM
Post #365
My understanding is that the speed sensor is based on the abs sensor. My plan is 944 turbo front abs sensors and custom rear to match my overzised rear tires.
Andyrew
Post #366
Oh and the rear will be on the cv adapter trans side.
- Lo-Fi Version Time is now: 26th November 2024 - 09:22 AM
