Andyrews Progress Thread, 1/16/22 A Trip to The Red Barn - Lets fab a Firewall! |
matthepcat |
Aug 5 2015, 03:27 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Put the motor on ebay/ craigslist before you go too low on price.
Mike Bellis |
Aug 5 2015, 04:14 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
If I still had my El Camino, I'd be all over that motor! (IMG:style_emoticons/default/aktion035.gif)
Chris H. |
Aug 5 2015, 05:28 PM
Senior Member Group: Members Posts: 4,048 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Yeah it may be time to separate that setup if no one wants to pay up. It's a damn good engine. Needs a wider audience.
BTW why does every car comment remind me of a movie? https://www.youtube.com/watch?v=tWTjf0-GBQQ This was my 2am college move go-to. Hollywood Knights. |
mgp4591 |
Aug 5 2015, 05:33 PM
914 Guru Group: Members Posts: 5,483 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Yeah it may be time to separate that setup if no one wants to pay up. It's a damn good engine. Needs a wider audience. BTW why does every car comment remind me of a movie? https://www.youtube.com/watch?v=tWTjf0-GBQQ This was my 2am college move go-to. Hollywood Knights. (IMG:style_emoticons/default/agree.gif) "this punch does have a little WHANG to it..." (IMG:style_emoticons/default/lol-2.gif) |
Chris H. |
Aug 5 2015, 11:29 PM
"Good though...." (IMG:style_emoticons/default/lol-2.gif)
Maltese Falcon |
Aug 6 2015, 12:01 AM
Advanced Member Group: Members Posts: 4,851 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Remember this Cobra in the movie?
The only way they could get it into the scenes was to allow its actual owner to do the driving. So the owner/driver picks my friend and body+paint man Jack Kimoto to sit shotgun during the street race scenes. How cool is that ? (IMG:style_emoticons/default/aktion035.gif) |
mgp4591 |
Aug 6 2015, 12:24 AM
Remember this Cobra in the movie? The only way they could get it into the scenes was to allow its actual owner to do the driving. So the owner/driver picks my friend and body+paint man Jack Kimoto to sit shotgun during the street race scenes. How cool is that ? (IMG:style_emoticons/default/aktion035.gif) And going up against someones "rail job", basically a slightly lengthened frame with a '23 t-bucket dropped on it. I'd take the Cobra anyday... If you need a good example of a real Cobra accelerating, check out the Gumball Rally sequence toward the end when the Cobra and the Daytona Ferrari exit the LA river and hit the surface streets- the Daytona moves out fast but the Cobra literally LEAPS from gear to gear as the exhaust sound explodes from the pipes. The sound may have been file audio but it's one of the greatest examples of power to weight ratios in film IMHO... (IMG:style_emoticons/default/shades.gif) |
Andyrew |
Sep 7 2015, 02:02 AM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Well... Lots of little things have been happening. Nothing Huge BUT lets to a rundown.
Interior is stripped, and I finally threw some galvanized paint on my longitudinal reinforcements since they were bare. Next big thing to figure out on the interior is the steering column. It looks like I need to cut the dash up to mount the column. Then I need to find some way of adapting the column to the 914 shaft. In the mean time I have been acquiring quite the parts collection. Steering column and wheel Body wiring harness |
Andyrew |
Sep 7 2015, 02:44 AM
Dash wiring harness (There are 2 dash wiring harnesses in the picture)
Engine harness (Bought it a while ago, but here it is laid out on plywood for storage and sorting) ABS module/block/sensors and pump for stability control (brake assisted) 240MM 12lb flywheel for the 1.8T engine, 6 puck disk and standard pressure plate. |
Andyrew |
Sep 7 2015, 03:05 AM
Ac/Heater box complete
AC Heater box cut in half (removed fan) and opened up. Fan in mock up position Ac/Heater box in mock up position. Yes this will kill half the front trunk but I still have plenty of space for a medium sized suitcase up front and this gives me much more legroom in the cabin. This position was suggested by my Jerika (my wife) and after looking at it, it make a lot of sense! And yes it is upside down, I dont have a good photo of the mock up position. The heater core connection lines will be cut short and the AC lines might get bent just to get a bit more room. And yes I will cut some holes to run the ducting to the cabin. |
Andyrew |
Sep 13 2015, 10:56 PM
Steering column is mounted and moved back.
Unlike Mike my steering column was not surrounded with steel it was surrounded with aluminum (IMG:style_emoticons/default/dry.gif). So I first had to build a steel enclosure for that and then mount that to the 914 body. I decided to weld it and bolt the Audi column to it. (Secured with 8 1/4x20 bolts and an extremely tight fitting enclosure, Hammer required) |
Andyrew |
Sep 13 2015, 10:59 PM
Andyrew |
Sep 13 2015, 11:02 PM
Before all the way up and tilted down.
After all the way up and tilted down. It only moved it away from the driver maybe 1/2 an inch, but I think it made a big difference in the driving position. I am very happy with it where it is. Now I will modify the steering shaft and get all that squared away! |
mgp4591 |
Sep 14 2015, 12:39 AM
So are you going to have a fixed seat or adjustable like stock? I agree that getting the column just right is essential for any mods- I'm planning on that using the stock SVX steering column but I've got tilt and telescopic, however not much in the latter. I'm getting all kinds of ideas from your last few pictures and getting antsy sitting in this frickn' wheelchair- I want to start working on stuff!! (IMG:style_emoticons/default/headbang.gif)
Andyrew |
Sep 14 2015, 08:34 AM
Drivers seat is on forward and back rails as low as possible. Passenger seat is on stock 914 rail.
I am 6'0 with a lot of mid body height. The Audi steering wheel is quite a lot bigger than the Momo I had in there previously. I'll keep looking around for a factory Audi wheel that is smaller and possibly pushed back , if I can find something then I think it'll help quite a bit as well. |
Andyrew |
Sep 14 2015, 11:58 AM
I might have found a solution that will push the steering wheel back some more.
The Audi steering wheel is VERY profiled. It is a good 4" in profile. This NRG adapter is low profile, say 1 1/2", Combine that with a nice flat steering wheel and not only do I get to actually use the telescoping feature, I can get a smaller steering wheel. Need to measure to ensure that the stalks are not going to get in the way. http://thmotorsports.com/nrg-innovations/n...h/i-286499.aspx |
Andyrew |
Sep 21 2015, 01:16 PM
Steering column is done (IMG:style_emoticons/default/smile.gif)
Lots of mods to the steering linkage, but its very solid and seems smooth enough. Its also in the original position that the 914 steering knuckle was so that's a plus. Modifications to the steering knuckle and column moved the knuckle assembly forward almost an inch. |
Andyrew |
Sep 21 2015, 01:37 PM
Gotta love those Germans.... Audi apparently individually wraps and connects all their different wiring harnesses separately.. They also have white ID tags on all their harnesses with part numbers that I can look up (most of the time) and ID what exactly they are for! So I took the big chassis wiring harness (You remember, this one..) (IMG:http://www.914world.com/bbs2/uploads/post-172-1441612878_thumb.jpg) And I removed all the wiring harness looms that I will not be using in the car.. And we made... Note I did remove one harness after this pic, and I havent touched the engine side (Note not engine harness, just all the wires on the engine side you can see they all have black plastic shrouding) So it will likely be a bit smaller all said and done. And we got this left over! Total weight of the removed wiring was ~ 20lbs! If I ever need to I can add the harnesses back relatively easy! Next is to go through the dash harness and remove the similar wires that I dont need. |
Andyrew |
Sep 21 2015, 01:47 PM
I only have 2 harnesses left interior side of the chassis harness. the "body" which is basically all the lights, and "ABS" which houses all the stability control stuff and the abs stuff.
76-914 |
Sep 21 2015, 03:53 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,634 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
My OG plan was to do as you have done Andrew, albeit Subaru. Then I realized that I may not live long enough to see it to completion, (IMG:style_emoticons/default/hissyfit.gif) . You however, have time on your side and I like your approach. WORD: don't drink or smoke anything when messing with the electrical. Your brain is left scrambled after a few hours of re-wiring anyway so there is no sense in starting out that way. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/wacko.gif) I notice you try to work on it a little every day. Smart, if only for 1/2 hour at a time! At this rate you will be back on the road before Christmas. (IMG:style_emoticons/default/beerchug.gif) Kent
Lo-Fi Version | Time is now: 25th November 2024 - 04:25 PM |
