Andyrews Progress Thread, 1/16/22 A Trip to The Red Barn - Lets fab a Firewall! |
Mueller |
Oct 13 2015, 12:20 AM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Neat drawing...looking forward to seeing this in person when you finish it.
Mike Bellis |
Oct 13 2015, 07:31 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I'm looking forward to Andrew actually driving his car... (IMG:style_emoticons/default/dry.gif)
Andyrew |
Oct 13 2015, 07:45 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Would be nice for sure (IMG:style_emoticons/default/smile.gif) I doubt I have more than 5k miles on the car in total (IMG:style_emoticons/default/sad.gif)
Andyrew |
Oct 18 2015, 08:15 PM
There Multiplying... (IMG:style_emoticons/default/blink.gif)
Delay in progress due to mini build on members car. http://www.914world.com/bbs2/index.php?showtopic=267385 Attached thumbnail(s) |
Andyrew |
Nov 6 2015, 10:04 AM
Happy Birthday to me! (IMG:style_emoticons/default/cheer.gif)
I received my new fuel setup in the mail. Very excited about this. Bosch 1000CC EV fuel injectors (Can run up to a 93% duty cycle reliably) This puts me right at 545HP max at E85 with 43.5psi. Fuel pump is the outstanding Bosch O44 which is one of the strongest and linear in the industry and can change the fuel pressure if I find that being required. Now here is the fun bit (IMG:style_emoticons/default/smile.gif) http://store.034motorsport.com/fully-enclo...-bosch-044.html Fuel surge tank. This encloses the Bosch 044 fuel pump and allows for it to be submerged constantly(Less noise and cooler running). The surge tank is primed by a carb low pressure fuel pump and remains full constantly effectively preventing any possibility of fuel starvation in corners. This also has the added benefit of allowing me to use the stock style fuel lines since they will be under zero pressure and allow for 100% flow of the lines. I will put this surge tank in the engine bay and it will keep my expensive high pressure lines very short and allow for no line pressure loss due to length (IMG:style_emoticons/default/smile.gif) Its a win win win! Presents from my wife. Ironically my wife checked out my amazon wish list and grabbed a couple items. 1.Low pressure fuel pump 2. Roller and corner roller tools for building the interior 3. Shades (Because you have to look cool) 4. Candy (IMG:style_emoticons/default/smile.gif) 5. Beer chiller Finally had some friendly competition between my car and her car with her driving on Forza! Very proud that she actually beat me when I was using a stock 914! |
Mike Bellis |
Nov 6 2015, 08:02 PM
turn up the pressure and turn down the duty cycle. I'm running at 4 bar (58.8 psi). 034 recommended my 330cc injectors at that pressure for my hp goal.
Andyrew |
Nov 7 2015, 11:15 AM
Really 330CC's? Im really surprised that your able to push those injectors that much... I had 440's that I maxed out and IIRC I was running a 4bar FPR, mind you I was making similar power that you are now. You sure your only on 330's?
And yes I don't plan on running my duty cycle that high, I'm just showing where the injectors currently are at the standard pressure. I am probably going to tune for 4bar FPR. Whatever my tuner thinks is the best for my needs (IMG:style_emoticons/default/smile.gif) |
Justinp71 |
Nov 16 2015, 02:57 PM
Senior Member Group: Members Posts: 1,602 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
With being a recent vw/audi owner (GTI), I am excited to watch this build. Andrew are you pulling the motor out of the A4? |
Andyrew |
Nov 16 2015, 03:56 PM
(IMG:style_emoticons/default/popcorn[1].gif) With being a recent vw/audi owner (GTI), I am excited to watch this build. Andrew are you pulling the motor out of the A4? A4 has been sold as a driver. My daily being my Fiesta ST has given me no need for the quattro... Motor I have is out of the junkyard. Im going to open it up to see if I want to built it. But I am keeping an eye out for a good usable motor. Maybe one with VVT so I can get some more low end. End goal is to build a motor with cams, ported, oversized titanium valves and springs, rods/ stroker/pistons. Build it to rev to 8500 and put a larger hot side if I feel it needs to breath better up top. That would give me well over 4k rpms of usable power. |
76-914 |
Nov 16 2015, 04:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,634 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
OT: Just saw your car in the calendar. Great shot! (IMG:style_emoticons/default/evilgrin.gif)
Andyrew |
Nov 16 2015, 05:35 PM
Last years calendar right? I specifically didnt enter this year as I was already in it last year and wanted to give more people an opportunity to pop in..
Besides I voted for the hillside shot of the "multiple" cars, my Fiesta ST is actually hiding in the back (IMG:style_emoticons/default/smile.gif) |
Andyrew |
Nov 23 2015, 12:06 AM
Gotta get back on the horse!
Engine shelf removed/trimmed. Test mounted the engine/trans then test set it in the engine bay. Looks like to make the axles level the pass side needs to be 1/2" higher than the drivers side when its on the movers dolly. Simple enough (IMG:style_emoticons/default/smile.gif) |
Andyrew |
Nov 23 2015, 12:10 AM
Im still positioning the setup left,right, up, down, tilt, back. In my head the setup needs to come back an inch and up 2-3, or tilted forward about 5-10 deg to get the trans tucked up a bit more and the axles more level with the suspension. I'd like to get the axles almost level when the car is in its resting position.
Hard to see in this photo, but the trans is about 1" forward of the axles when the engine is touching the firewall. And finally, started reinforcing the rear shock tower for my brace. I am going to remove the firewall where the blue tape is (did get a full pic of it) and rebuild/box it about 6" back where the shocks are. I'm going to have a local metal shop bend up some steel similar to the 914 humps for strength and weld it in to the 1" bar brace I weld in between the towers. I am going for a near factory look when done. |
rightpedal |
Nov 23 2015, 05:48 AM
rightpeda; Group: Members Posts: 60 Joined: 6-September 15 From: annapolis Member No.: 19,133 Region Association: MidAtlantic Region |
Are you going to add more support in the front corners of the engine bay? I ask because we were looking at my build car (cut out engine tray) and the parts car (tray intact) thinking that's a fair amount of triangulation/support. Just looking to what others are doing in that arena.
Steve |
Andyrew |
Nov 23 2015, 09:17 AM
Its a fair amount of triangulation to the firewall which is essentially non structural.
That being said yes there is some additional reinforcements to come in the rear suspension console. Specifically the typical firewall to rear suspension ear. I am debating how exactly I am going to do my engine bar at this point, so I want to make sure everything is as strong as possible. |
Mike Bellis |
Nov 23 2015, 09:48 PM
I think you will end up cutting out the battery tray. There is very little room once you get everything bolted on. My turbo is smaller than yours... (IMG:style_emoticons/default/sawzall-smiley.gif)
Andyrew |
Nov 23 2015, 10:50 PM
My manifold is more compact (IMG:style_emoticons/default/smile.gif)
Ill test mount it after I cut the firewall and see. |
Mike Bellis |
Nov 23 2015, 10:54 PM
My manifold is more compact (IMG:style_emoticons/default/smile.gif) Ill test mount it after I cut the firewall and see. I'm running the smallest T3 manifold I could find. Ended up being the cheapest too. |
Andyrew |
Nov 26 2015, 12:34 AM
It fits just fine (IMG:style_emoticons/default/smile.gif) in fact the manifold is about an inch away from the head so itll suck in more.
Also I got my water to air intercooler. Big hunking thing, a full 20lbs. |
Mike Bellis |
Nov 26 2015, 05:27 PM
It fits just fine (IMG:style_emoticons/default/smile.gif) in fact the manifold is about an inch away from the head so itll suck in more. Also I got my water to air intercooler. Big hunking thing, a full 20lbs. That turbo sites nice and low! More pics please... |
Lo-Fi Version | Time is now: 26th November 2024 - 12:53 AM |
