44 Pages V « < 22 23 24 25 > »
> Andyrews Progress Thread, 1/16/22 A Trip to The Red Barn - Lets fab a Firewall!
76-914
post Dec 26 2015, 09:04 AM
Post #459
Cool presents. Hopefully we can all get kitchen pass' to work on our cars this weekend. (IMG:style_emoticons/default/beerchug.gif)
Andyrew
post Dec 26 2015, 06:57 PM
Post #460
Spooling.... Please wait
I got a pass to go for a drive with my cousin which was really nice so I call that a win (IMG:style_emoticons/default/smile.gif)
I think I will be able to find some time this week to finally weld in the mounts for the engine/trani. Thats my goal, Not sure if I can get it done but it will be a HUGE step forward if I can get it mounted.
Andyrew
post Jan 1 2016, 12:26 PM
Post #461
My final update for December 2015 is below (IMG:style_emoticons/default/smile.gif)
Guess who welded up the engine/trani mounts for their final position?
I'll add one support to this, I dont have any bolts on the trani closer up top that will triangulate this for load so I am going to use the hoist hole for one.
This is immediately after tack welds, They are all 90% welded now, but will finish that up in January. I was able to remove the 8 bolts holding it all together (4 up front and the 4 trani bolts for the oem mounts) and raise the car up in a couple minutes. Really happy with how that turned out (IMG:style_emoticons/default/smile.gif)
post Jan 1 2016, 02:34 PM
Post #462
Muy congrats, Andrew. Question. In your last pic, I see you cut out the piece adjacent to the trunk light and then welded a piece back in the same spot? Re-enforcement or change of plans? More pics, pls. (IMG:style_emoticons/default/beerchug.gif)
Andyrew
post Jan 1 2016, 02:42 PM
Post #463
That 1' cutout is for the distributor on a SBC conversion. Different clearancing is needed for the Audi engine.
dan10101
post Jan 1 2016, 03:03 PM
Post #464
TORQUE-o-holic
Looking good. Progress!
Mike Bellis
post Jan 1 2016, 09:17 PM
Post #465
Resident Electrician
Andyrew
post Jan 2 2016, 11:49 AM
Post #466
From yesterday, Finished off the welding on the body and the mounts, added the support, cutoff the excess and welded plugs to prevent rusting.
Bench tested my boost controller finally and its bad.... (IMG:style_emoticons/default/headbang.gif) Trying to get a refund from ebay but the guy that sold it to me didnt sell me the wiring harness (he played stupid in his auction, stating it was something else...) so I had to wait for a harness from China to come in and when I tested it well... ya. Dead LCD.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.usrallyteam.com-172-1451756993.1.jpg)
So there happens to be a sale going on right now for another EBC that I am interested in. 6 settings (Which I like....) and its programed via computer. Gear based, RPM based, speed based, and can control my water injection as well (awesome!) Its very small so it would fit with my dash layout much better than the other one as well which I like.
http://www.usrallyteam.com/index.php?main_...roducts_id=2017
paroxysm
post Jan 2 2016, 09:19 PM
Post #467
Not trying to hijack your thread
It looks very similar to my build, but for my rear tranny mount I just built an adapter.
I certainly need to upgrade my shifter assembly to be more rugged like yours mine was just some spare VW mk3 parts I had laying around.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i106.photobucket.com-1888-1451791151.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i106.photobucket.com-1888-1451791151.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i106.photobucket.com-1888-1451791151.3.jpg)
I hope to just finish this car enough to drive the bugs out of it this year. Anyone know if I can drive on a base stage 3 big turbo tune? Or should I try and dyno tune this thing without any of the bugs worked out?
Andyrew
post Jan 2 2016, 10:51 PM
Post #468
Awesome!
Do you have an active build thread on here? If not you should really make one, your build looks interesting! I think you have your engine about 2" forward of mine, do you have any cv issues and what cvs are you using?
What turbo are you using and what turbo is your stage 3 file for? I ran my turbo on my apr stage 3 file(made for a gr28rs) and didnt have any issues at 10psi but I was getting stuttering above that. You can get it tuned by some online tuners that give you a base tune and then fine tune it from logs you run.
paroxysm
post Jan 3 2016, 12:17 PM
Post #469
QUOTE(Andyrew @ Jan 2 2016, 08:51 PM) *
Awesome!
http://www.914world.com/bbs2/index.php?sho...0stuka&st=0
This should be my build thread.
The turbo is a gt28rs, my program is revo stage 3 for the turbo. My motor is an AWW 2001 with only 7000 kilometers on it, I paid $1200 for it.
The motor came with a electronic boost controller(not hooked up yet), walboro fuel pump, wideband O2 sensor, genesis 500cc fuel injectors, all new never used.
Now for the CV passenger side is a stock 911 with a empty CV case from a passat B5 used as a spacer, drivers side is a bmw 540i that was the correct length. Don't know how long they last but I had to go cheap for now and that setup only cost $10.
Only problem I've been experiencing is sometimes the car refuses to shut off, place the key in the off position car tries to shut down but then it revs up and continues running, also if I put the car in reverse with the ignition off the backup lights are on.
Andyrew
post Jan 3 2016, 01:22 PM
Post #470
Ill continue this post on your thread (IMG:style_emoticons/default/smile.gif)
Justinp71
post Jan 5 2016, 12:05 AM
Post #471
(IMG:style_emoticons/default/aktion035.gif)
Andyrew
post Jan 5 2016, 08:33 AM
Post #472
Separated the engine from the trans last night and removed the intake and cylinder head
It appears as if the valves have been in contact with the pistons, you can see the mark on the piston in the center and 4 small nicks on the corners (think a square)
The engine builders are telling me to grind off the nicks and use the pistons but the valves need to be gone through.
Im going to take the cams off and do a leakdown on the valves then determine how much valvework I want to do. I have a line on titanium valves and springs that will help me push up the rev limiter to 9k but the turbo will die off after 8k(unless I put a larger exhaust housing on it..)
Trying to keep my engine work under 1500, but I am not sure if I will make it.
Andyrew
post Jan 10 2016, 10:18 PM
Post #473
Finalized the disassembly of the engine and dropped off the engine at the engine shop.
Work to be done by the engine shop:
Clean block/head
Surface block/head
Hone cylinders
Install H beam rods on factory forged pistons
Balance Rotating assembly
Polish crank
Should be done in about 2-3 weeks. I will assemble the engine at that point.
Also BIG thanks to Mike Bellis for stopping by today and dropping off these MUCH NEEDED 100mm stub axles!
Dion
post Jan 11 2016, 04:55 PM
Post #474
RN
Andrew, wow! Just wow. Impressive project. Keep going, baby.
Having seen what goes into bodywork in person with 914Daves project,
I've a new appreciation for anyone who tackles bodywork that doesn't do it for a living
and does it properly. Very nice.
Andyrew
post Jan 16 2016, 03:19 AM
Post #475
Progress:
Mounted my intercooler and one of my tanks.
Machine shop kicked it up a notch and pushed the engine assembly out in a week!
Got it back today and everything looks so clean! (IMG:style_emoticons/default/biggrin.gif)
Andyrew
post Jan 16 2016, 03:23 AM
Post #476
More of all the bits.
Removed the valves and cleaned up all the carbon deposits the hot tank didnt take off.
Removed the casting marks from the exhaust side, I'll hit the intake side this weekend.
Mmm looks so nice!
Andyrew
post Jan 24 2016, 04:44 PM
Post #477
All the casting marks are removed from both intake/exhaust side (IMG:style_emoticons/default/smile.gif)
Not sure it'll do anything but its at least a step forward on the head build. In a couple years when I build a full stroker motor I'll do a full blown port + polish head.
My Supertech high spring pressure valves and nitrite coated exhaust valves came in! However I had one hickup. I picked up this set new in bag from a Audi community member, apparently it had swapped hands quite a bit and the original owner back in ~08-09 was going to put it in his race car 914 1.8T swap! I have a feeling it was the white race car that was in Excellence mag.
I lapped all the valves just for safety and everything seemed just perfect. Then I replaced all the valve guide seals and started to install all the valve springs.
So onto the valve spring hiccup. I went to install all the springs (If you've done this on an OHV head you'll notice the TINY amount of room on the intake valves... This task took me hours.... Ugh, tiniest of screwdrivers and ~ 1/4" room to work in at a severe angle) and when I got to the exhaust side I noticed that one of the exhaust inner springs was sitting a bit taller than the rest, took it out and I think the manufacturer packaged it wrong and put an intake spring instead of an exhaust inner spring (IMG:style_emoticons/default/dry.gif).
Quick email to Supertech and after $12 for the spring and shipping I had it the next day! (IMG:style_emoticons/default/cheer.gif)
Finalized the install on the valves and springs and went to put in the stock hydraulic lifters but noticed that a few of the lifters wouldnt spring very well even though they had been sitting for a week. I let them sit in some ATF to try and loosen them but no luck. So a quick youtube search lead me here.
https://www.youtube.com/watch?v=ySf0r8GGMOY
So I went and disassembled all my problem lifters and any I thought were not perfect, Labeled them in a bag per lifter hole and let them soak for 6 hours in some Purple Power.
After 6 hours the lifters themselves were very clean and I could see gunk floating at the top of the bags. Cleaned everything up and lubed them with some ATF and sunk them back in the holes they are for.
Andyrew
post Jan 24 2016, 04:45 PM
Post #478
Oh and the tool I made for the valve guide seals.
- Lo-Fi Version Time is now: 25th November 2024 - 10:35 AM
