Trailing a 914 WITHOUT a trailer?????, How to do it??? plus or negatives?? |
Howard |
Apr 30 2004, 12:57 AM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Thanks for the kind words.
John, I did look at the Cayenne, but the Hyundai came with a better CD ($50,000+ (IMG:style_emoticons/default/biggrin.gif) ) Paul, guess you figured that out, too. I have the 2.7, and while it does pull OK, bet the 3.5 with its low speed peak torque would do much better. Installation was just drilling 4 1/2" holes. Piece of cake. Reaching behind to tighten the nuts was interesting, but doable. Here's the link to the kit. $45 plus shipping. Nicely made, and nice people. To rave about the Santa Fe a bit, it has the best build quality I've ever seen. No Porsche, MB or BMW comes close. And for a POS Korean car, it has everything from leather to bun warmers to traction control to a 4cam 24valve motor that sings. Don't know how they do it at the price. And no comments about the license plate? Attached image(s) |
Rgreen914 |
Apr 30 2004, 01:12 AM
Member Group: Members Posts: 285 Joined: 20-October 03 From: West Covina, Ca. Member No.: 1,266 |
Somebody please explain this "flat-towing" rage that has you guys in it's grip; yeah, I know, we're supposed to be cheap bastards. Now I don't tow a race car but if I did, I would most certainly use a trailer; the only time I had to tow our teener, I used a trailer. I've seen these guys in their multi-megabucks motor homes go cheap and flat-tow their car/jeep/SUV and cannot believe they would skimp in that regard! For safety concerns alone, I would use a trailer, not to mention what would happen if the car became damaged at the track which rendered it un-towable!
Kevin@ojai.net |
Apr 30 2004, 01:40 AM
Member Group: Members Posts: 158 Joined: 9-July 03 From: Ventura & Chico, CA Member No.: 899 |
I haven't flat towed since this: (IMG:http://ojai.net/kevin/towbar.jpg). I'll tell the story if it sparks any ones interest. I think I did on Rennlist back when it happened, but I might not have...
-Kevin |
STL914 |
Apr 30 2004, 05:42 AM
Senior Member Group: Members Posts: 1,183 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
Howard,
It all looks simple enough. I went to the link you posted. This auction is for the complete package, including mounting hardware? Only drawback I see is the fact you can not have fog/driving lights installed. |
URY914 |
Apr 30 2004, 07:27 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 124,451 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Rgreen914,
A trailer can be a PITA. You have to maintain it (lights/tires), store it, get a tag for it, deal with the ramps, etc, etc, etc. I know because I have a car I can only trailer. For a autox car, flat towing makes at lot of sence. Pull two pins and your ready to drive. For the RV crowd it is the same issues. Flat towing or using a dolly is simple. Paul |
Demick |
Apr 30 2004, 08:31 AM
Hope you put some backing plates behind those brackets. Even with backing plates, I'd be a little nervous that the sheetmetal in that area isn't strong enough. But I haven't looked at it recently. You probably looked over it closely and determined it is fine.
Demick |
JWest |
Apr 30 2004, 08:47 AM
I built one that bolts to the front suspension mounting points (you have to remove the valance to use it).
I made a cross bar with brackets that pick up the three mounting points for the front of the a-arm on each side. The "protector" bracket on the front bolt also has to come off. I used a universal tow bar with U-brackets that just bolt to the cross bar I made. I can install it in about 10 minutes. Very solid and I have towed with it quite a bit. |
Demick |
Apr 30 2004, 09:27 AM
QUOTE(Howard @ Apr 29 2004, 04:27 PM) Can I tap into the 914 tail and brake lights? Tapping into the lights should be easy. You will need to tap into lights for turn signals, brakes, and running (parking) lights. But you should be able to do this without having to run wires all the way to the back of the car. For running lights, you can splice into the wires at the front turn signal buckets. Splicing into the wire for the right running light will also power the right side marker, and the right rear running light. Then splice into the equivalent wire on the left side of the car. For turn signals, it's the same deal. Splice into the wire for the right front turn signal, and that will power the right rear turn signal light as well. Same on the left side of the car. For the brakes, the easiest way would be to run the wire to the brake pedal switch (running wires from the front trunk to the passenger compartment is easy), and splice into the side of the switch that only gets power when the brake pedal is depressed. That will power both brake lights. Should be really easy. Running wires from the passenger compartment to the rear trunk is tough, and this method avoids that alltogether. Demick |
porschenut |
Apr 30 2004, 10:58 AM
Member Group: Members Posts: 83 Joined: 15-April 04 From: Chalfont, PA Member No.: 1,929 |
I am setting up a 76 for flat tow, I welded the bumper shocks solid and after removing the bumper, attach to them.
Used the same setup on my 924 and towed it with a '76 GMC motorhome. worked great, should be even better with the 914 as its lighter. Putting the bumper back on is a 10 minute job. I flat tow'cause its cheaper! |
Mueller |
Apr 30 2004, 12:17 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
I already have a trailer, it's a storage issue for me, I don't want to make my nieghborhood look like cr@p, so no storing the trailing in front of my house for extended periods of time.(no room on the side either)
Currently I keep my trailer at my job which is 50 miles away, and it's inconvient on the weekend or if I wanted to trailer the car unplanned and then I'd have to do a 100 mile round trip (IMG:style_emoticons/default/sad.gif) To me it has nothing to do with cost, you buy it once and it's done, it's the storage that is a PITA |
Howard |
Apr 30 2004, 12:34 PM
No replacement for a trailer, but it is handy. I'd like to have a nice transporter (with 962 or RSK, please) but for now the flat tow and the 914 will have to do.
Demick, thanks, sounds good. Would I then be charging the battery in the towed car? |
Otmar |
Apr 30 2004, 02:02 PM
2000 Amps in a 914 Group: Members Posts: 174 Joined: 3-March 03 From: Corvallis, OR, USA Member No.: 387 |
I'm surprised, I thought it was only the Electric Vehicle guys who obsessed about tow bars.
I set up a tow bar on mine, it's also 3000lb and I've heard that torsion bar mounts crack anyway so I made mine extra strong, I've got a picture here somewhere I'm sure... First the frame to make sure it stays attached to the car, this was then welded in place. (IMG:http://evcl.com/914/Batbox/photos/IM0017.jpg) From the outside: (IMG:http://evcl.com/914/Batbox/photos/IM0006.jpg) And on the car (bad angle, I know) (IMG:http://evcl.com/914/Pics/OATvsConesSm.JPG) As for towing with them, I now only do local. I've flat towed to Vegas and Portland (from the Bay Area) but I get the feeling it's a bit hard on the car. Though really it should be no worse than driving that distance. Warning! Tow in neutral with the parking brake off and the ingition unlocked. Put the key in, turn it on, just barely turn it off and do not pull the key out. I wired my lights direct. All the wires are available up front drivers side where the gas tank was except the brake light which I connected to the brake switch down by the pedal. hth, |
Lo-Fi Version | Time is now: 4th January 2025 - 07:48 PM |
