> 2.0 Engine weight
abnrdo
post Feb 19 2011, 11:21 AM
Anyone know what a 73 2.0 engine weighs? I am considering all my options.
Originally I was looking at a LS1 or LS2 conversion, which I really like. My 75 (IMG:style_emoticons/default/wub.gif) is very rust free, so I am not sure about cutting such a nice chassis. There is a parts car close to me:
http://kansascity.craigslist.org/cto/2191962145.html
Thoughts???
-Jim
detoxcowboy
post Feb 19 2011, 11:48 AM
Region Association: Africa
Porsche 2.0 Liter Engine
Total weight, dry approx. 146 kg / 321 lb
http://www.pelicanparts.com/914/technical_..._tech_specs.htm
And for the Porsche 1.7 & 1.8 Engines
Total weight, dry approx. 126 kg/277 lb
orange914
post Feb 19 2011, 12:19 PM
http://5starmediaworks.com/index.html
QUOTE(detoxcowboy @ Feb 19 2011, 09:48 AM) *
44 lbs. differance between 1.7/1.8 and 2.0?
brp986s
post Feb 19 2011, 01:48 PM
It would be a shame to hack up a rare good chassis for something like that. More hp is not always better. There was a recent poll here where most said 150 - 200 hp is best for a 914. Save your time and money for those guys in the pic above. Or buy a car already converted. For sure you can find one cheap relative to the cost of construction. Why? Filling the trunks with miscellaneous engine junk makes the car less useful, but more expensive. Kind of like an upside-down mortgage. Thinking about it, buying parts - thats fun. Finding time and doing the actual work - PITA and BTDT. Just my opinion.
Kraftwerk
post Feb 21 2011, 09:16 PM
So, I am saving 44 LBS. with my 1.7!!
I am actually quite pleased with the pep of the 1.7..fun!
But are you saying a 2.0 conversion requires cutting up the engine tin or bay?
Woody
post Feb 21 2011, 09:44 PM
Sandbox Rabblerouser and head toilet scrubber
2 liter will bolt right in but the tins are different from the 1.7 and 1.8 due to different spark plug angles. Don't know where the extra 44 pounds comes from though.
Rand
post Feb 21 2011, 09:56 PM
Cross Member
QUOTE(Kraftwerk @ Feb 21 2011, 07:16 PM) *
No. The 2.0 bolts in with no mods. [edit]oops, aside from minor holes in tin for spark plugs[/edit]
The LS1/LS2 is an aluminum block Chevy v8 with 300+ more hp than a 2.0 and doesn't weigh more than a Porsche 6. That conversion requires a small notch in the rear trunk wall for the distributor. And a radiator in the front trunk.
abnrdo
post Feb 23 2011, 10:28 AM
QUOTE(Rand @ Feb 21 2011, 09:56 PM) *
No notch for the LS1/LS2 only if your using the heavier LT1 motor. Still havent decided. 3.2 conversion is more expensive than a Renegade system.
Root_Werks
post Feb 23 2011, 10:31 AM
Village Idiot
Still.....44lbs diff between a 1.7-1.8 and 2.0, that seems like a lot.
McMark
post Feb 23 2011, 10:53 AM
914 Freak!
Especially considering the 2.0 has a slightly lighter crank and slightly lighter rods. Perhaps the stock 2.0 flywheel is lighter? I never noticed a difference, but it could be true. PET doesn't show different part numbers... (IMG:style_emoticons/default/confused24.gif)
I call bogus...
- Lo-Fi Version Time is now: 26th December 2024 - 02:15 PM
