Reinstalling inner CV, With engine and tranny in car |
jeffdon |
Feb 20 2011, 02:38 PM
Trying to put my inboard CV joint back on the splined end of the axle with everything in the car. I got it about 1/8" onto the spline, and now it seems to be calling for some tapping with a hammer to get it on the rest of the way. However, i have no clearance to swing a hammer, and the tranny is in the way of a long punch.
Anyone got a trick for doing this? |
Andyrew |
Feb 20 2011, 03:11 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Take it out and inspect the splines. Inspect the hub. Clean with sandpaper and a knife if gummed up or dirty. It should slide in and out fairly easy, a little forcing may be necessary, but no hammer IIRC.
jeffdon |
Feb 20 2011, 03:55 PM
Take it out and inspect the splines. Inspect the hub. Clean with sandpaper and a knife if gummed up or dirty. It should slide in and out fairly easy, a little forcing may be necessary, but no hammer IIRC. That helped....just trying to get it the last 1/8" or so.... |
Andyrew |
Feb 20 2011, 06:30 PM
Put the nut on and tighten it on.
type47 |
Feb 21 2011, 01:26 PM
Feb 21 2011, 01:41 PM
Custom Member Group: Members Posts: 24,659 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
did this once in the car, it sucked getting that clip on...
It can be done, clean them again. Rich |
Andyrew |
Feb 21 2011, 07:12 PM
I was thinking outer hub.. my bad
Lo-Fi Version | Time is now: 26th December 2024 - 01:52 PM |
