A&PGirl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None ![]() |
A&PGirl |
A&PGirl |
A&PGirl |
A&PGirl |
A&PGirl |
A&PGirl |
1970-1973 Porsche 914-6 & 914 Fog Light Grill Hardware Kits
-ZINC (REPLICA)- Attached thumbnail(s) ![]() |
A&PGirl |
A&PGirl |
A&PGirl |
So, I walked back through the thread and looked over the Poll results. Here are the fulfilled Post Requests & Poll Results. In addition, I have also received requests over pm & email by interested parties. Everyone is more than welcome to post or send me their requests for parts & hardware. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving-girl.gif)
(IMG:style_emoticons/default/silver914.jpg) (IMG:style_emoticons/default/aubergine914.jpg) (IMG:style_emoticons/default/grasshopper914.jpg) (IMG:style_emoticons/default/red914.jpg) (IMG:style_emoticons/default/irish914.jpg) (IMG:style_emoticons/default/blue914.jpg) Post Requests sww914 - Rockers Yellow & Stainless rick 918-S - Rockers " " PM Requests Pending - Black Pending - Yellow & Stainless Pending - Stainless Poll Results Door Latch, Front latch, Rear latch & Engine latch -Yellow & Stainless Interior (divided into 1, 2, 3, etc) - Yellow, Stainless & Black (some kits) 914-4 Engine Tin - Yellow & Stainless 914-6 Engine Tin - Yellow Fog Lights - Yellow & Stainless Fog Light Grills - Zinc, Stainless & Black Horns - Yellow & Stainless Clutch 1.7/1.8/2.0 - Yellow Valances - Yellow & Stainless 914-6 & 914 Bumper - Yellow & Stainless Headlight - Yellow & Stainless Front Sway Bar - Yellow Other Requests Valance Spacers Rocker Spacers Headlight Bushings Long E-Brake Boot Rear Hub Pins - Yellow Ball Joint Pins - Yellow CV Joint Axle Locating Pins - Stock/Standard Black Schnorr Washers - From Schnorr Black/Stainless European Hose Clamp Kits 74-76 Engine Carrier Hardware Kit - Yellow 914-4 Engine Case Hardware - Yellow 914-4 Engine Oil Systems Hardware - Yellow & Stainless 914-4 Cylinder Head Hardware - Yellow 914-4 Impeller Hardware - Yellow 914-4 Fan Housing Air Flow - Replica Side Shift Seal Kit Tail Shaft Oil Seal Speedometer Drive Shaft Oil Seal |
914_3.0 |
Newbie ![]() Group: Members Posts: 49 Joined: 8-January 14 From: Central Cal Coast Member No.: 16,856 Region Association: Central California ![]() |
I only have the drive gear left in mine. Just getting a slow but constant drip-drip. Do you or anyone else know if this will seal the penetration without the right-angle part of the mechanism in place? It looks like it may. If not, I'll probably go with machining an additional gland into my plug and two fresh o-rings. Thanks! - Todd ![]() |
A&PGirl |
Todd-
Thank you for question. I can't tell from your picture, but do you have the intermediate piece between the right and what looks like a tube? The intermediate piece kind of looks like a threaded hex pipe plug that threads on to the right angle drive then threads internally into the case. The oil seal goes is inside case as seen below. The intermediate piece is the red arrow. The location of the oil seal is the green arrow. EDIT: It looks like you have the might have the remains of the oil seal in your picture. ![]() |
914_3.0 |
Todd- Thank you for question. I can't tell from your picture, but do you have the intermediate piece between the right and what looks like a tube? The intermediate piece kind of looks like a threaded hex pipe plug that threads on to the right angle drive then threads internally into the case. The oil seal goes is inside case as seen below. The intermediate piece is the red arrow. The location of the oil seal is the green arrow. EDIT: It looks like you have the might have the remains of the oil seal in your picture. ![]() Thanks for the quick reply! I haven't had it out yet, but I think the last of what you see in the photo is #23 in the schematic. My first 901, and I've only had it since just before x-mas so total rookie yet. What I think I've got is this.... with the plug sitting on what is showing in my first photo. It must be the intermediate piece you are talking about just before the right-angle. ![]() |
bulitt |
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States ![]() |
This looks to be a hydraulic rod seal (used in a hydraulic cylinder). Normally, hydraulic fluid under pressure forces the seal to expand against the rod, sealing it from fluid loss. It may work for your application. Hard to see it, it may simply be a rod wiper used to scrape debris on the rod so it is not carried into the seal.
(IMG:http://www.914world.com/bbs2/uploads/post-5367-1392153939_thumb.jpg) In this photo the drive on the right is a stock 901 drive with single o-ring. The one on the left has the machined second o-ring. It is the way to go to stop oil leakage. McMark will fix you up with one of these. (IMG:http://www.914world.com/bbs2/uploads/post-16856-1392926310.jpg) |
914_3.0 |
Thanks both for your help. Just ordered from McMark. You've got lots of great offerings, I'm sure I'll be back for something else. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 19th April 2025 - 07:48 AM |
