To re-ring ot not re-ring?, Need some advice |
krazykonrad |
Feb 23 2011, 03:50 PM
Senior Member Group: Members Posts: 1,141 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
Long story short, the engine is out of the car. Loose head/cylinder studs are the suspected culprit. I'm planning on pulling the cylinders to lap them into the heads before I put it all back together. Will this necessitate re-ringing? The rings have about 8,000 miles on them.
Thanks for y'all's help! Konrad |
Dr Evil |
Feb 23 2011, 04:29 PM
Send me your transmission! Group: Members Posts: 23,034 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
10Kmi is the recommended interval that I have read in the manuals. It is not expensive, and "while you are in there" you might as well. Hone the cylinders, though or they wont seat.
Feb 23 2011, 04:32 PM
914-6 GT in waiting Group: Members Posts: 19,647 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Buy the girl a new ring/don't use the old one. Woops, wrong thread. (IMG:style_emoticons/default/confused24.gif)
TheCabinetmaker |
Feb 23 2011, 05:33 PM
I drive my car everyday Group: Members Posts: 8,325 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
If ya use new rings, you should at least hone the cyls
Woody |
Feb 23 2011, 05:38 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
10Kmi is the recommended interval that I have read in the manuals. It is not expensive, and "while you are in there" you might as well. Hone the cylinders, though or they wont seat. Wait did you just say that 10,000 miles is the recomended interval to replace the piston rings? |
Cap'n Krusty |
Feb 23 2011, 06:29 PM
Ring it if they're worn out, and hone the cylinders if you ring it. DO NOT USE A BALL HONE!!! I suspect the rings will be fine at 8K miles, unless they got really hot. Have the heads surfaced if they're the least bit "iffy". Lapping them in is a joke, and lapping them without milling the surface is downright criminal. When you cut the heads, shim the cylinders to compensate for the cut. Loose head studs are rare on a T4 unless they've gotten REALLY hot, and even then it hardly ever happens.
The Cap'n |
VaccaRabite |
Feb 23 2011, 07:31 PM
En Garde! Group: Admin Posts: 13,616 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
What is the issue that you were having?
If you are rebuilding the top end, it would be silly NOT to hone and re-ring. its so easy on these cars since you can just slip the jugs out and hone them. Zach |
Dr Evil |
Feb 23 2011, 07:37 PM
IF the jugs are pulled, the recommended interval is 10Kmi. I see where that could be confusing how I stated it before. You do not need to change the rings on an engine that is assembled every 10Kmi (IMG:style_emoticons/default/biggrin.gif)
John, why not use a ball hone? |
Cap'n Krusty |
Feb 23 2011, 07:59 PM
What is the issue that you were having? If you are rebuilding the top end, it would be silly NOT to hone and re-ring. its so easy on these cars since you can just slip the jugs out and hone them. Zach A good machinist will set the cylinders up in a fixture to assure the hone is centered, round, and even. Not all that easy. The Cap'n |
krazykonrad |
Feb 23 2011, 10:28 PM
Here's the background:
The driver's side lost compression on both cylinders. The head checks out ok, no dropped/burnt valves. No apparent cracks or voids. This leads me to believe that the studs have backed out a little. They are not loose by hand, but I suspect they have turned enough to break the seal between the cylinder and head. The motor is a 2.0 Porsche case with 2.0 bus heads. My plan is to use this as a weekend driver until I can put a 6 in it, so I want to have a reliable engine, but without putting a whole lot of $$$ into it. Konrad |
Cap'n Krusty |
Feb 23 2011, 11:34 PM
How much compression? What was the leakdown, and where did it go? Are the valves seating? What do the gaskets look like (if there were any)? Was there any popping or other noise before you tore it down? Did it get hot? How hot, and for how long? If the loss was from the head/cylinder interface, you'd hear it and you could see where it was going.
The Cap'n |
krazykonrad |
Feb 24 2011, 12:16 AM
The leakdown cold went to 0 almost immediately. When it was warm, it would intermittently hold compression, but no leakdown was done while it was warm, so I don't have any numbers for you. I don't remember any popping sounds, but this was about 2 years ago. It definitely didn't sound like it was running right. It never got hot. I don't have any numbers, but my melt-off warranty tag has always been in place.
Thanks for your help Capt'n! |
krazykonrad |
Feb 24 2011, 12:18 AM
How much compression? What was the leakdown, and where did it go? Are the valves seating? What do the gaskets look like (if there were any)? Was there any popping or other noise before you tore it down? Did it get hot? How hot, and for how long? If the loss was from the head/cylinder interface, you'd hear it and you could see where it was going. The Cap'n Also, valves are seating fine. The gaskets, around the combustion chamber (if they are gaskets and not shims) have some carbon build-up but aren't scored or torn up. |
VaccaRabite |
Feb 24 2011, 09:14 AM
If you suspect head studs, did you re-torque and try the tests again?
Zach |
Feb 24 2011, 09:26 AM
Custom Member Group: Members Posts: 24,658 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
to answer the original question.
re-ring it...hone the cylinders and do it. Simpler now than later. Rich |
Lo-Fi Version | Time is now: 26th December 2024 - 07:05 AM |
