> Removing Rear View Mirror, Adhesive is strong
turnaround89
post Feb 23 2011, 09:36 PM
So i accidentally hit my rear view mirror while working in my car and it snapped off, the screw sheared and just the little block is attached to the windshield. I would like to replace the mirror, but can't with the black block in the way. Any tips on how to remove that, the adhesive is wicked strong?
Thanks everybody
ConeDodger
post Feb 23 2011, 09:42 PM
Apex killer!
Heat activates most adhesives... I am not suggesting though that you heat up just that spot of the windshield. Hot day, sharp - sharp blade.
turnaround89
post Feb 23 2011, 09:43 PM
little cold here is rockford to try that, but when it warms up, i will definitely give that a shot...Thanks
ConeDodger
post Feb 23 2011, 09:51 PM
Apex killer!
QUOTE(turnaround89 @ Feb 23 2011, 07:43 PM) *
I'm from the Midwest Andrew. I hear that! I said that to make sure that you don't use a heat gun or hair dryer to spot heat the outside of the window at that spot. I suspect you could cause a crack.
- Lo-Fi Version Time is now: 26th December 2024 - 05:49 AM
