> Electrical Guru's, an alternative to battery cut out switches ???
76-914
post Feb 25 2011, 10:25 AM
you tell me........ http://www.emxinc.com/blueguard.html (IMG:style_emoticons/default/confused24.gif)
underthetire
post Feb 25 2011, 11:34 AM
It would need to control one hell of a relay to isolate the battery. Could be done, maybe a old ford starter relay. Probably be better to use it to isolate the fuel pump.
PeeGreen 914
post Feb 25 2011, 11:37 AM
QUOTE(underthetire @ Feb 25 2011, 09:34 AM) *
I would think fuel pump or ignition would be easy enough. Battery or starter may take a little much.
Spoke
post Feb 25 2011, 11:48 AM
Jerry
This is just a universal wireless controller, a set of relay contact to control other heavy-duty relays on the machine itself.
Mike Bellis
post Feb 25 2011, 01:05 PM
Resident Electrician
The output relay is only rated at 2 Amps. It could drive a high power relay for your battery cut off. There are some Ford style relays that are rated for continuous duty.
I purchased some Bosch style relays that are remote controlled from Ebay. I run it to the fuel pump.
Tom
post Feb 25 2011, 04:35 PM
In electrical/electronics, almost anything is possible. That's why we have the term KISS.( Keep it simple, stupid.) The more complicated you make it, the easier it is to fail at an inopportune moment and then it can be difficult to troubleshoot.
Just curious, why would you want to have the battery cut-off on a relay? A heavy duty switch designed for that is as simple as it gets. If for anti-theft, I would go with a small relay to isolate the fuel pump, or a simple inline on/off switch for the fuel pump.
Tom
whatabout1
Toys in Red
That would keep me from leaving my phone at the shop (IMG:style_emoticons/default/idea.gif)
post Feb 25 2011, 09:50 PM
I didn't plan on using one at all really. My relay is a barking dog. I was just thinking that people could use on of these "instead of" a battery disconnect. e.g. on the starter, ign switch or fp as already mentioned here.
- Lo-Fi Version Time is now: 26th December 2024 - 02:42 PM
