RoadGlue |
Sonoma County Gear Head ![]() ![]() ![]() ![]() Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California ![]() ![]() |
Cracker |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States ![]() ![]() |
Why does your car have to run such small wheels/tires? The vintage pictures above show it in proportional trim...wouldn't you want to campaign it in a class that allows for the this original configuration? Has the engine changed as well? Curious - I promise not critical.
Tony |
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,628 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
gms |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,718 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest ![]() ![]() |
Why does your car have to run such small wheels/tires? The vintage pictures above show it in proportional trim...wouldn't you want to campaign it in a class that allows for the this original configuration? Has the engine changed as well? Curious - I promise not critical. Tony The short answer is that using 7" x 15" wheels causes me the least amount of headaches with the vintage racing groups I run with. |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,741 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
I saw Doug at a German car gathering last weekend.
He had two VW splittys there. A '62 15 window and a '67 (?) double cab. Spectacular restorations with plenty of extra oomph and talent applied. Good luck Glenn Be safe Rory |
flyer86d |
Member ![]() ![]() Group: Members Posts: 460 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States ![]() |
I've seen the 15 window. The attention to detail is amazing and the mods are terrific. He just got done fixing the fuel system of our 1973 911T. Doug is the best!
Charlie |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Why does your car have to run such small wheels/tires? The vintage pictures above show it in proportional trim...wouldn't you want to campaign it in a class that allows for the this original configuration? Has the engine changed as well? Curious - I promise not critical. Tony The short answer is that using 7" x 15" wheels causes me the least amount of headaches with the vintage racing groups I run with. This is interesting. My Vintage run group allows up to 7 wheels which I run, but they do not allow flares at all. So it seems odd that a vintage run group that allows those flares will not allow wider wheels. So do they have max track width limitations? Seems you would need massive spacers to make that setup look right. |
gms |
I agree with you guys 100%, It makes no sense why some groups allow lager diameter wheels and wider wheels and some don't like the flares and some just don't care.
What I have here is a 914/6 that is allowed in all the groups (I run in) without changing anything. Remember I have built two transaxles (5 speed and 4 speed) to run at different track, changing wheels would probably require more transaxles. I do not want to have to buy two sets of rain tires and two sets of race tires and have four sets of wheels. |
gms |
I ended up finishing fourth, there were two Cobra kit cars and a Mustang in front of me. My times were pretty consistent and not to bad for this being my first race in 11 months. Thanks to Mark Kinnaman and Mike Bednar for lending a hand at the track!
GaroldShaffer |
I ended up finishing fourth, there were two Cobra kit cars and a Mustang in front of me. My times were pretty consistent and not to bad for this being my first race in 11 months. Thanks to Mark Kinnaman and Mike Bednar for lending a hand at the track! ![]() (IMG:style_emoticons/default/smilie_pokal.gif) Sorry I couldn't make the trip up. (IMG:style_emoticons/default/sad.gif) |
gms |
(IMG:style_emoticons/default/smilie_pokal.gif) Sorry I couldn't make the trip up. (IMG:style_emoticons/default/sad.gif) I suppose you have some lame excuse that you were buying MORE 914s (IMG:style_emoticons/default/biggrin.gif) |
gms |
I was cleaning the rear trunk of the race car preparing for the upcoming race and took a picture of the Karmann number
week 38, day 1 7th car made on September 15, 1969 ![]() |
gms |
Helmet is in, I am
READY! ![]() |
RoadGlue |
gms |
I am going to give the Toyo Proxe RR a try this weekend
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,812 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,449 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
gms |
wndsrfr |
I am going to give the Toyo Proxe RR a try this weekend I've been on the RR's for two years now...and like them a lot. Pay attention to the mounting & placement instructions... What size are you running? 225/45 15 I put over 2500 track miles on my last set of 225/45/15's, no cording anywhere. Then again, it's only putting down a bit over 200rwhp weighing just under 2000 pounds & driven only on weekends by 70+y.o. driver <;o) |
gms |
The rubber gets hard on my tires long before they wear out but I can usually get 2 seasons. I used to run Toyo Proxes R888 and was happy with the slow fade in performance hopefully these will be the same.
Lo-Fi Version | Time is now: 29th April 2025 - 01:21 PM |
