Oil Strainer Basket |
bembry |
Feb 28 2011, 04:31 PM
Senior Member Group: Members Posts: 529 Joined: 29-July 05 From: Bakersfield, CA Member No.: 4,499 Region Association: MidAtlantic Region |
Guys,
Concerning the little oil strainer wire mesh "basket" on the motor: How often do you replace them? Or even check them? Replace every oil change? Or do you just clean it out? Just wondering. . . |
Feb 28 2011, 05:31 PM
914 Idiot Group: Members Posts: 15,066 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
When I had one, I cleaned it out every oil change.
Mine's gone now, due to not fitting when the oil pickup extension for the "tuna can" is installed. --DD |
McMark |
Feb 28 2011, 05:51 PM
You don't need to replace it. Just clean it.
Factory manual called for cleaning every 3000 miles at first, then in 1972 changed it to every 5000 miles, then in 1973 changed it to every 20,000. Finally, in 1975 they dropped it from the maintenance schedule completely. So I'd say it's up to you. Clean it as frequently as you feel comfortable. |
MartyYeoman |
Feb 28 2011, 06:51 PM
Senior Member Group: Members Posts: 1,527 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
You don't need to replace it. Just clean it. Factory manual called for cleaning every 3000 miles at first, then in 1972 changed it to every 5000 miles, then in 1973 changed it to every 20,000. Finally, in 1975 they dropped it from the maintenance schedule completely. So I'd say it's up to you. Clean it as frequently as you feel comfortable. (IMG:style_emoticons/default/agree.gif) Just don't over torque the attachment bolt. That can really screw up your day! |
gothspeed |
Mar 1 2011, 11:19 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
When I had one, I cleaned it out every oil change. Mine's gone now, due to not fitting when the oil pickup extension for the "tuna can" is installed. --DD Speaking of .......... I was gonna buy one of those but do not want to lose the strainer .......... so I decided to make my own 'tuna can' that will still utilize the factory mesh filter. I have two configurations in the works with differing fabrication difficulties ............ I will post pics of both when I get them done (IMG:style_emoticons/default/smile.gif). |
Lo-Fi Version | Time is now: 2nd January 2025 - 10:56 AM |
