69 Pages V « < 37 38 39 40 41 > »
> Just another damned project thread, 914-6 3.2 conversion in GT dress-up
ConeDodger
post Jan 9 2014, 05:39 PM
Post #761
Apex killer!
Looks good Mark. I'm going to try to get down next week and go by WEVO for the 915 kit. Thanks for the pics!
McMark
post Jan 9 2014, 05:55 PM
Post #762
914 Freak!
Wevo is good stuff. Sounds like a good plan. I'm working on something for the sub-$2000 market while I have the opportunity.
Dave_Darling
post Jan 9 2014, 07:09 PM
Post #763
914 Idiot
3D printed? (IMG:style_emoticons/default/wink.gif)
--DD
ConeDodger
post Jan 9 2014, 08:13 PM
Post #764
Apex killer!
QUOTE(McMark @ Jan 9 2014, 03:55 PM) *
WHAT??? (IMG:style_emoticons/default/huh.gif)
ConeDodger
post Apr 11 2014, 01:11 PM
Post #765
Apex killer!
There has been sounds of cutting and grinding coming from the OC (Original Customs) this week. I haven't seen the pictures but I'm told I have no more 4 mounts! In the process of prepping the engine compartment for the new 3.2 Carrera motor, McMark discovered some rust. Not much I'm told but enough that he had to call me. When I bought the car, there was pretty much no rust to speak of with one exception. The battery tray had let go of the wall above to hell hole. I had met a guy who I now know to be an imposter claiming to be a 914 expert and he offered to repair the battery tray and I said 'have at it' A new tray was installed and following some work to the wheel arch, a bit of Diamond Silver Metallic made it look like new. Sure enough, this "expert" just covered up some rust with bad bodywork. (IMG:style_emoticons/default/mad.gif) McMark has a new guy at his shop who is extremely productive and hates rust with a passion! I'm sure it will be straightened out in short order! (IMG:style_emoticons/default/biggrin.gif)
Pictures when McMark gets a chance. The engine is going in soon!!! (IMG:style_emoticons/default/driving.gif)
McMark
post Apr 13 2014, 07:30 PM
Post #766
914 Freak!
Okay. Picture time.... (IMG:style_emoticons/default/biggrin.gif)
DME is mounted between the seats. We'll cover it later with carpet or a custom box, whatever Rob wants. The previous SDS install left us with a hole in the firewall and a plate beneath the passenger seat. We reused both as necessary. So the DME harness passes through the firewall in a 35pin sealed connector.
We found some rust in the hell-hole area. Nothing major, but while we're in there. (IMG:style_emoticons/default/happy11.gif)
Pitting like this was all over. This is behind the four cylinder mount we removed. I gotta talk to my guys about taking better pictures. (IMG:style_emoticons/default/rolleyes.gif)
The area behind the 4 cyl mount is patched, and the top of the long is new. There's still a hole in the firewall and the area where the battery tray welds on is rough.
Again with the bad pictures. All the metal work in the hell hole is done, except for the new battery tray. Oh, and I'll get better pictures when the engine is back out, but we also closed up some previous holes made for the ground cable and patched in a new lug/mount for the ground cable. All back to stock! (IMG:style_emoticons/default/biggrin.gif)
We also replaced the rear trunk hinge mounts.
Engine is in the car for test fitting, wiring harness fabrication, modifying valve covers, etc.
ConeDodger
post Apr 14 2014, 12:03 AM
Post #767
Apex killer!
Those MSDS headers look good! (IMG:style_emoticons/default/evilgrin.gif)
ConeDodger
Post #768
Apex killer!
(IMG:style_emoticons/default/biggrin.gif) In case you're wondering how I'm feeling about all of this... (IMG:style_emoticons/default/first.gif)
ConeDodger
post Apr 14 2014, 12:01 PM
Post #769
Apex killer!
A question for those of you who have gone with the Getty Carbon Fiber lids. I picked up a set used and will be putting them on. For the rear, have you used a prop rod? One spring? Both springs? A gas shock?
I should think not much would be needed... (IMG:style_emoticons/default/smile.gif)
I will be using pin pads as the GT did. In the rear, the rubber pulls.
ConeDodger
post Apr 14 2014, 12:24 PM
Post #770
Apex killer!
But now for the most important question of all. Mark, will my Check Engine light still work? (IMG:style_emoticons/default/blink.gif)
McMark
post Apr 14 2014, 12:42 PM
Post #771
914 Freak!
QUOTE(ConeDodger @ Apr 14 2014, 11:24 AM) *
(IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif)
ConeDodger
post Apr 14 2014, 01:12 PM
Post #772
Apex killer!
QUOTE(McMark @ Apr 14 2014, 10:42 AM) *
Oh no!!! (IMG:style_emoticons/default/huh.gif)
bandjoey
post Apr 14 2014, 01:13 PM
Post #773
bandjoey
Can't u just open the engine lid to check if the engine is still there? Looking Good! (IMG:style_emoticons/default/happy11.gif)
ConeDodger
post Apr 14 2014, 01:14 PM
Post #774
Apex killer!
QUOTE(bandjoey @ Apr 14 2014, 11:13 AM) *
That's so analog... (IMG:style_emoticons/default/dry.gif)
ConeDodger
post Apr 14 2014, 01:43 PM
Post #775
Apex killer!
McMark asked me this morning about the relay board mount. Apparently no longer needed.
IIRC, that's your relay board anyway. Remember rescuing me when I had some bizzarro shizit going on while autocrossing in Sonoma? (IMG:style_emoticons/default/biggrin.gif)
Chris H.
post Apr 14 2014, 01:51 PM
Post #776
QUOTE(bandjoey @ Apr 14 2014, 02:13 PM) *
Why is this so funny to me? (IMG:style_emoticons/default/av-943.gif)
Lookin' good Rob. We humble test drivers of 914World are standing by....just PM when ready. Or call.........or e-mail.....or you can post on this thread.......or start a new one......really no rules on how you want to communicate. We make it easy.
ConeDodger
post Apr 14 2014, 02:06 PM
Post #777
Apex killer!
QUOTE(Chris H. @ Apr 14 2014, 11:51 AM) *
Probably because it is really funny! (IMG:style_emoticons/default/lol-2.gif)
I suspect it'll be running this week or next and it can be seen at WCR Teeners at Tahoe II... But, NO ONE and by the way, by that I mean NO ONE, drives her but me. If you know my car, you know why! (IMG:style_emoticons/default/biggrin.gif)
Mike Bellis
post Apr 14 2014, 02:59 PM
Post #778
Resident Electrician
QUOTE(ConeDodger @ Apr 14 2014, 01:06 PM) *
(IMG:style_emoticons/default/hide.gif)
This car will be awesome!
ConeDodger
post Apr 14 2014, 03:41 PM
Post #779
Apex killer!
QUOTE(Mike Bellis @ Apr 14 2014, 12:59 PM) *
Shut up Mike. (IMG:style_emoticons/default/mad.gif)
(IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif)
McMark
post Apr 14 2014, 06:47 PM
Post #780
914 Freak!
Got the order list for plumbing the oil cooler. We already had a Mocal AN-12 thermostat, Rob's oil cooler is already AN-12, and this includes fittings for a Patrick Motorsports tank.
- Lo-Fi Version Time is now: 24th November 2024 - 02:26 PM
