barada |
Member ![]() ![]() Group: Members Posts: 257 Joined: 5-October 08 From: Atlanta Member No.: 9,613 Region Association: None ![]() |
Bruce
Got any front lower Hood latches and rear trunk latches left? Also may need the latch that mounts to the hood up front. For a 74 914. Thanks Phillip |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I should have those still available. I will check later and get back to you.
Pat Garvey |
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States ![]() |
I too have bought many parts from Bruce, clearly top quality at very fair prices ! (IMG:style_emoticons/default/smile.gif) I second that opinion! Pat |
detoxcowboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa ![]() |
Brruce I love you shiny parts and you never come by with them like you the 914 ice cream man anyumore..
seriously the expensive ball pin joints are not supposed to be re-use, I am not trying to be Knowledgeable just looking out for your protection and you customer. They are $20 each at Pelican but loose control of one wheel and your dead screwed, happend to me on a differnet part that one pin/bolt came out as I pulled from a stop at the end of a fwy off ramp 3;30 in the morngin... If i was doing 75 when it happend .. justy a heads up.,, ![]() |
bdstone914 |
Joe,
Thanks for the heads up about the taper pins. I wonder if the problem with the pin coming out was with the special retaining nut with the slit on the side? I have a shop now where you and other 914 nuts ( not that you are one ) are welcome to come and salivate over Porsche parts. Free cup of chilled Sparklets water with any purchase. The shop is at: 10000 Indiana Ave Suite #9 Riverside CA Call before coming as I am not at the shop that much but it is only 2 miles from the house. Bruce |
jeeperjohn56 |
Member ![]() ![]() Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None ![]() |
Bruce, If you still have the trailing arm nuts and the trailing arm bearing caps I'll take them and also a set of transmission hardware. paypal address John
Lo-Fi Version | Time is now: 18th June 2024 - 05:45 AM |
