OmaPossu |
Member ![]() ![]() Group: Members Posts: 241 Joined: 4-October 09 From: Finland Member No.: 10,886 Region Association: Scandinavia ![]() |
Hello,
This is a thread about late hours in my garage trying to get 1970 914-6 back to life. There are already hundreds pics in here: http://www.harrasteet.1g.fi/kuvat/OmaPossu+II/ One question, what are these holes for? Spot welding? http://www.harrasteet.1g.fi/kuvat/OmaPossu...+1.5.11+009.JPG |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,812 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I don't know for sure, but my guess is those holes are for when they dipped the bodies at the factory.
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 124,560 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
I've got a box of the covers for those holes somewhere
RFoulds |
914Rennsport ![]() ![]() ![]() Group: Members Posts: 850 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region ![]() ![]() |
Are the flares steel or fiberglass? What is the serial number? I am constantly trying to find my old one.
Add the serial number to the database please! |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
Are the flares steel or fiberglass? What is the serial number? I am constantly trying to find my old one. Add the serial number to the database please! 9140472344 It is in the data base under my name Jukka bought it earlier this year! I also sold him some steal flares to replace the fiberglass ones!! |
Ferg |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None ![]() ![]() |
Just had a guest at the house from Finland (IMG:style_emoticons/default/biggrin.gif) Great cook! |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,190 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
One question, what are these holes for? Spot welding? That would be my guess ... (IMG:style_emoticons/default/popcorn[1].gif) |
OmaPossu |
Then to the biggest problem of this car. Drivers side front corner has some signs of past accident. It's been repaired badly. It's more than inch up and and bent little right too. That can be taken care with "celeste bench".
Front boot floor has some bad crinkles (right word?) and inner fender is not right shape. How to take care these? Some pics there: http://harrasteet.1g.fi/kuvat/OmaPossu+II/...t+boot/Problem/ |
The celette bench will get the basic attachment points back to factory specs.
The wrinkled sheet metal will need to be replaced or hammered back to where it belongs. I'm in the same boat with my original /6. Tons of sheet metal that needs replacing or massaging. A good automotive body guy will know how and what to do. (IMG:style_emoticons/default/bye1.gif) |
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
...WELCOME to the world
keep at it! (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
OmaPossu |
I found some numbers in trunk floor.
132045 Karman chassis numbers? Or what? |
carr914 |
OmaPossu |
From where I can check it's correct one for this car?
From where I can check it's correct one for this car? A quick search using the keywords "+chassis +number" got quite a few results, including the one below. http://www.914world.com/bbs2/index.php?showtopic=116615 (IMG:style_emoticons/default/shades.gif) |
carr914 |
Jeffs9146 |
From where I can check it's correct one for this car? I find it hard to imagine anyone would try to change that number - most people don't even know it's there. And I've seen them in at least 2 different spots I did research on this over the years and it does have the correct numbers for a 1970 914-6 as it is discribed in the link Andy posted! Notice the chassis number is 2045 and the vin number is 2344 so they are within 299 chassis! |
OmaPossu |
Behind this link is pic of two kind of front brake heat shields.
http://harrasteet.1g.fi/kuvat/OmaPossu%20I...nt%20brakes.JPG Which is right for -70 914-6? |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,790 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
the left one
Jeffs9146 |
It is the one on the left and the part# is 914.351.801.00! The one in the parts catiloge only shows 5 holes around the center in the photo but I would guess that is just to represent the differences! |
Lo-Fi Version | Time is now: 19th April 2025 - 01:44 AM |
