OmaPossu |
Member ![]() ![]() Group: Members Posts: 241 Joined: 4-October 09 From: Finland Member No.: 10,886 Region Association: Scandinavia ![]() |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
The transmission was updated to a side shift long ago!
skota |
Member ![]() ![]() Group: Members Posts: 95 Joined: 21-October 10 From: madison wi Member No.: 12,291 Region Association: None ![]() |
Nice collection of cars you have there! well done!
OmaPossu |
OmaPossu |
Nice collection of cars you have there! well done! Kotajarvi is Finish name and you have quattro so you must be allmoust relative (IMG:style_emoticons/default/wink.gif) |
Jeffs9146 |
The transmission was updated to a side shift long ago! Changed or updated? I think it's possible to rebuild tail shift to side shift, am I right? When we talked about it I was sure it was changed due to the serial number on the trans! Here is one of the e-mail conversations 2011/1/26 Jeff Tuck <jeffs9146@yahoo.com> I do not know anything about the original transmission! It was swapped out before I got it and the person who sold it to me didn't know anything either! I would try to get a COA and see if the transmission number is listed! There was a guy keeping track of all 914-6's in the USA and I spoke with him once. He told me the car was sold in Palo Alto so you may be able to call the dealership and get some history?? (just a thought!) Don't forget to put fluid in the transmission before you install it! |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,146 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I think between steering wheel and horn pad should be something "elastic"? What? This: http://www.pelicanparts.com/cgi-bin/ksearc...347-823-01-M100 --DD |
OmaPossu |
The transmission was updated to a side shift long ago! Changed or updated? I think it's possible to rebuild tail shift to side shift, am I right? When we talked about it I was sure it was changed due to the serial number on the trans! Here is one of the e-mail conversations 2011/1/26 Jeff Tuck <jeffs9146@yahoo.com> I do not know anything about the original transmission! It was swapped out before I got it and the person who sold it to me didn't know anything either! I would try to get a COA and see if the transmission number is listed! There was a guy keeping track of all 914-6's in the USA and I spoke with him once. He told me the car was sold in Palo Alto so you may be able to call the dealership and get some history?? (just a thought!) Don't forget to put fluid in the transmission before you install it! Yes, so it was! Sorry, english is not my main language! I'll ask another way, if I have tail sift gearbox can I change it to side shift without changing transmission case (shell)? I'll asked Finnish Porsche dealer to find out my transmission number but nothing come out. Have to ask direct from Zuffenhausen. |
Jeffs9146 |
Yes you can!
You need a side shift tail cone with parts, shifter plate, shifter, shifter bar and bushings. I'm sure the good Dr. has more detail but that still wont make it a numbers matching transmission! The number on the 914-6 transmission starts with 914/01! Link to 901 detail information! |
OmaPossu |
Yes you can! You need a side shift tail cone with parts, shifter plate, shifter, shifter bar and bushings. I'm sure the good Dr. has more detail but that still wont make it a numbers matching transmission! The number on the 914-6 transmission starts with 914/01! Link to 901 detail information! Thats good to know! Now I can tell my friend, who bought my ex 914, that he can change that crappy old tail shift to side shift without buying new transmission! Or would it be easier/cheaper to buy used side shift trans? |
Easier, yes. Cheaper? Not sure.
To change from the tail-shift to the side-shift setup, you not only need to change the transmission (or modify the tail-shift one), but you also need a complete later gear-shift linkage, including all of the rods and even the gear shift lever itself, plus the motor mount bar and all of the mounting hardware for that bar. --DD |
Jeffs9146 |
Easier, yes. Cheaper? Not sure. To change from the tail-shift to the side-shift setup, you not only need to change the transmission (or modify the tail-shift one), but you also need a complete later gear-shift linkage, including all of the rods and even the gear shift lever itself, plus the motor mount bar and all of the mounting hardware for that bar. --DD (IMG:style_emoticons/default/agree.gif) Except he has a factory 6 so the Motor Mount is not an issue! |
OmaPossu |
Easier, yes. Cheaper? Not sure. To change from the tail-shift to the side-shift setup, you not only need to change the transmission (or modify the tail-shift one), but you also need a complete later gear-shift linkage, including all of the rods and even the gear shift lever itself, plus the motor mount bar and all of the mounting hardware for that bar. --DD (IMG:style_emoticons/default/agree.gif) Except he has a factory 6 so the Motor Mount is not an issue! Jeff, I wrote about my ex 914 (1971 1,7), not 6. |
Jeffs9146 |
Oh! (IMG:style_emoticons/default/beerchug.gif)
OmaPossu |
Niklas |
Porsche 914 Sweden ![]() ![]() Group: Members Posts: 366 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia ![]() |
I think it is for a 1972.
Niklas |
Jeffs9146 |
Along the top of the transmission stamped into the ridge there should be a number! I remember seeing it I just don't remember what it was except it was not 914/01!
Jeffs9146 |
Double post (IMG:style_emoticons/default/blink.gif)
Attached image(s) ![]() ![]() |
Jeffs9146 |
Here is a photo of a 914-4 stamped serial number and a 914/6 stamped serial number! |
Jeffs9146 |
What's going on with the web site today! If I edit it makes a whole new post?? (IMG:style_emoticons/default/WTF.gif)
Lo-Fi Version | Time is now: 19th April 2025 - 07:47 AM |
