26 Pages V « < 2 3 4 5 6 > »
> Progress, The 2011 Hershey show gave me another shot of motivation
jsayre914
post Jun 22 2011, 04:13 PM
Post #61
Speed Up !!!
Wow Bob, your almost done, Looks great!! (IMG:style_emoticons/default/smile.gif)
dlee6204
post Jun 22 2011, 04:19 PM
Post #62
Howdy
Wow, keep up the good work! (IMG:style_emoticons/default/smilie_pokal.gif)
Series9
post Jun 23 2011, 07:05 PM
Post #63
Lesbians taste like chicken.
It's nice to watch someone else work. (IMG:style_emoticons/default/sunglasses.gif)
You're doing a great job. Keep it up. (IMG:style_emoticons/default/beerchug.gif)
scotty b
post Jun 23 2011, 07:24 PM
Post #64
rust free you say ?
QUOTE(Series9 @ Jun 23 2011, 05:05 PM) *
saigon71
post Jul 20 2011, 02:37 PM
Post #65
Problems with both the Mazda and motorcycle have cut into my 914 time over the last few weeks, but I was able to get some more done.
Drilled holes in new metal patch on drivers side, installed new allen bolts and re-ran front hood cable.
Took a wire wheel to the inner wheelhouse section to prep for primer...discovered a lot of surface rust in ths area that will require treatment before primer.
After reading other build threads on here, I have been pretty vigilant about keeping an eye on the door gaps and taking my time welding to keep the heat down. I have made a couple of small tweaks along the way, but the gaps have held well. Checking gaps after welding in the upper wheelhouse section, there was a more noticeable difference. After some adjustments to the turnbuckle, I was able to able to get it within .030" of the drivers side and still have the door close OK. The door now requires more effort to close it and will need some final tweaking.
saigon71
post Jul 20 2011, 02:47 PM
Post #66
Ended up with a bit of a mess where the floorpan meets the firewall on the passenger side & will have to make pieces to fill the areas. Hindsight being 20/20, I would have bought this section(s) welded them in and been done by now.
Needed to fabricate the verticals of both the inner and outer firewall. I was able to get a close measurement by measuring the rise of the old piece and adding the width of the metal cutting wheel. Something warped in the floor, leaving too narrow of a gap on the outside. Had to drive a solid wedge between the original firewall and new floorpan to pry these apart for the correct spacing and weld a chunk in to hold it in place. The wood splitting mall was crude but effective.
saigon71
post Jul 20 2011, 02:52 PM
Post #67
Outer firewall patch:
saigon71
post Jul 20 2011, 02:56 PM
Post #68
For the front firewall patch, I opted to make a template to simplify things:
Both pieces finished:
AndyB
post Jul 20 2011, 06:16 PM
Post #69
The Governor is watching me
Bob you are making great progress keep it up
saigon71
post Aug 2 2011, 07:45 PM
Post #70
Welded in the lower inner vertical firewall piece:
I had a large rusted section above the long on the firewall that had to be farbricated and replaced. Went with a posterboard template to get the shape accurate:
Finally, a solid inner floorpan on the passenger side! (IMG:style_emoticons/default/beerchug.gif) I decided to prep this 1/4 of the pan for finish...one coat of rust converter applied:
jonferns
post Aug 2 2011, 07:55 PM
Post #71
Nice work (IMG:style_emoticons/default/smilie_pokal.gif)
hot_shoe914
post Aug 2 2011, 08:31 PM
Post #72
on ramp passer
Looking good Bob, I better see this car at Hershey if I drive up for the 3rd year in a row. (IMG:style_emoticons/default/first.gif)
saigon71
post Aug 30 2011, 06:04 PM
Post #73
Seeing two stellar teeners at Matt's cookout as hurricane Irene approached made me realize it was time to get back to work.
18 GA patch pieces were made to close up the hole in the outer firewall:
Finished the rear passenger side floor pan on the inside. Two coats ospho (on rusty areas) followed by two coats rust bullet (again, only on rusty or pitted areas) two coats rust encapsulator and new seam sealer. It was nice to look at a small section of the car and say "this is done." (IMG:style_emoticons/default/biggrin.gif)
The jigsaw puzzle that is the rear floor pan on the passenger side continues to get pieced together. It became very complicated trying to make this part all in one shot, so I decided to go with a section at a time and weld it all together:
Experienced some cracking after applying the initial primer on the upper wheelhouse. I suspect it is from over-doing it on the rust converter, as I have run into this before using the product. From now on, I will only apply one coat. Wire brushed affected areas and re-sprayed primer:
saigon71
post Sep 4 2011, 05:22 AM
Post #74
My welding skills have improved significantly, but it still seems like I spend a ton of time grinding...
Tying the firewall, floorpan, and inner long together has been a challenge. Two small patch panels were fabricated and welded in where the outer firewall curves rearward to meet the inner long. Final piece welded into the floorpan where it meets the long. Took the wire wheel to the whole area to prep for a light Ospho treatment in one area and I hope to get this area primed tomorrow:
Tomas donated a used set of plastic MC lines to the cause as my originals were accidently strafed by a wire wheel. While the Ospho was drying, I installed them, taking any means possible not to disturb the new master cylinder. Thanks Tomas! Started cleaning up my rusty muffler bracket as well:
FourBlades
post Sep 4 2011, 11:38 AM
Post #75
From Wreck to Rockin
Great progress! (IMG:style_emoticons/default/smilie_pokal.gif)
You are getting there. (IMG:style_emoticons/default/piratenanner.gif)
It will be worth it. (IMG:style_emoticons/default/beerchug.gif)
John
saigon71
post Sep 5 2011, 07:04 PM
Post #76
Shot two coats of primer on the rebuilt pass side firewall/floor pan. It was a lot of patchwork, but I am pleased with how it all worked out. (IMG:style_emoticons/default/biggrin.gif)
Cleaned, treated and painted the exhaust bracket.
Cairo94507
post Sep 5 2011, 07:19 PM
Post #77
Michael
Very nice work; you should be proud.
AndyB
post Sep 19 2011, 04:02 AM
Post #78
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) Looking good Bob whats the current status?
saigon71
post Oct 14 2011, 05:47 PM
Post #79
The outer suspension console and engine mount were completely shot on my car, so I bought a relatively rust free chunk of longitudinal from a member of 914world and started disassembly. What a PITA drilling out all of the spot welds and grinding down the outer welds, then beating the pieces apart with a large hammer and screwdriver. My "original" inner suspension console must have been replaced at some point, because it was in better condition than the one I bought as part of the used longitudinal. All three pieces were treated with POR-15 on the inside while the weldable areas were shot with weld thru primer. I continually ran a piece of safety wire through the drain hole of the inner console while treating with POR to make sure the drain remained open.
Parts:
I decided to start with the inner console. It was a real bitch trying to measure exactly 28 1/4 inches from the hole in the center of the firewall to the front of the suspension ear hole with a tape measure while holding everything in place. Plus, this needs to be spot on for proper alignment. I decided to cut a piece of steel brake line to exactly 28.25" to simplify the task.
The inner console had a little bit of "rock" to it on the new long that seemed to be coming from the indent behind the bracket. Had to beat this area with a hammer for proper fit:
Still nervous about having the measurements EXACTLY right before tack welding this thing in place...I decided to call it a night.
trojanhorsepower
post Oct 14 2011, 06:37 PM
Post #80
Great Job!
Keep it up!
27 User(s) are reading this topic (27 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th December 2024 - 03:19 AM
