| Andyrew |
Jun 1 2011, 09:54 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
So my 3rd replacement ignition switch started tweeking out on me. Im tired of this. This is not a stock 914 so I decided to get an aftermarket switch. 10 bucks at Autozone and I have a switch that I doubt i will ever break.
So I pull the wiring which I have become so familar with and see that there are 6 prongs on it. One obviously ground(Black), One obviously power(red, thick), One keyed power (red, thinner), and one obviously starter(yellow).. But then I see 2 other small wires, a white, and a white/brown. Where do these suckers go? There is no accessory switch to the 914 so I doubt anything can go there, Are they the wires that are keyed power or say a relay? How do I wire this on a 4 prong switch??? I would think that the two smaller wires just go on keyed power, but I'd hate to do it and be wrong. Thoughts? Thanks all. |
Andyrew Giving up on ignition switches, Need wiring diagram Jun 1 2011, 09:54 PM
tradisrad go here and find your year and wiring diagram.
Gr... Jun 1 2011, 09:59 PM
Andyrew I know its usually brown, but its obiously not in ... Jun 1 2011, 10:05 PM
r_towle #26 on diagram two, "steering column switch... Jun 1 2011, 10:38 PM
Andyrew
#26 on diagram two, "steering column switch... Jun 1 2011, 11:04 PM
kg6dxn
I saw 26 but there are to many wires on that dia... Jun 1 2011, 11:13 PM
NORD In the center tunnel there is a wire, don't re... Jun 1 2011, 10:47 PM
kg6dxn The black wire is the ignition hot lead. the 2 sma... Jun 1 2011, 11:00 PM
Andyrew OK so lets put this down.
NEW SWITCH -------- 91... Jun 1 2011, 11:07 PM
kg6dxn
NEW SWITCH -------- 9... Jun 1 2011, 11:15 PM
Andyrew
NEW SWITCH -------- ... Jun 1 2011, 11:18 PM
kg6dxn
So what your saying is im right? :wacko:
I j... Jun 1 2011, 11:23 PM
chrispy Doesn't one wire go from the switch to the hea... Jun 1 2011, 11:18 PM
914Mike
So my 3rd replacement ignition switch started twe... Jun 1 2011, 11:27 PM
Andyrew MMMMkay... On my testing zone I had the little red... Jun 1 2011, 11:57 PM
Andyrew So I disconnected the yellow wire and tried the ke... Jun 2 2011, 12:01 AM
Andyrew WTF
I disconnect the switch and check it out. Loo... Jun 2 2011, 12:18 AM
messix its not hitting "ground" its conducting ... Jun 2 2011, 12:31 AM
Andyrew
its not hitting "ground" its conducting... Jun 2 2011, 08:58 AM
jcd914 It sounds like you are trying to connect the after... Jun 2 2011, 01:21 AM
Andyrew
It sounds like you are trying to connect the afte... Jun 2 2011, 09:06 AM
Cap'n Krusty I've probably installed a couple of hundred af... Jun 2 2011, 10:03 AM
Andyrew Captn,
Yes the aftermarket switch is clearly lab... Jun 2 2011, 10:34 AM
r_towle pull the wire from the battery POSOTIVE terminal..... Jun 2 2011, 10:43 AM
Andyrew I'll give it a test tonight. Battery is kickin... Jun 2 2011, 10:54 AM
Cap'n Krusty
I'll give it a test tonight. Battery is kicki... Jun 2 2011, 11:17 AM
r_towle cant ohm the red wire while its connected to the b... Jun 2 2011, 11:03 AM
Andyrew Well I can say that that relay is LONG gone... Sea... Jun 2 2011, 11:14 AM
r_towle reminds me of my plow truck...a dual battery diese... Jun 2 2011, 11:21 AM
Andyrew Rick,
Cables are under 5 years old. Starter has ... Jun 2 2011, 11:43 AM
Andyrew Pulled the positive cable from the battery and sep... Jun 2 2011, 12:51 PM
914Mike
Pulled the positive cable from the battery and se... Jun 2 2011, 01:22 PM
Cap'n Krusty The wires have to be disconnected at BOTH ends for... Jun 2 2011, 01:24 PM
Andyrew 914Mike,
I see. That makes sense.
Actually the... Jun 2 2011, 02:13 PM
Tom Andyrew,
Did you remove the positive battery ... Jun 2 2011, 04:31 PM
Andyrew Tom,
No, I didnt disconnect the positive battery... Jun 2 2011, 04:45 PM
Andyrew For shits and giggles i installed the wiring again... Jun 2 2011, 07:38 PM
kg6dxn Test the continuity of your switch (ohm out)
Powe... Jun 2 2011, 08:04 PM
Andyrew Mike, this is what i tested last night (multiple t... Jun 2 2011, 08:23 PM
Andyrew Mike, this is what i tested last night (multiple t... Jun 2 2011, 08:35 PM
Andyrew Ooook.. I just tightened the bolts down but left t... Jun 2 2011, 08:40 PM
kg6dxn Have you tried to hot wire your car? Just to see i... Jun 2 2011, 09:00 PM
Andyrew Defective. The starter terminal worked itself loos... Jun 2 2011, 09:01 PM
kg6dxn Damn Chinese parts... Jun 2 2011, 09:05 PM
Andyrew Mike, yes i test all functions of the key switch w... Jun 2 2011, 09:34 PM
Andyrew Drove to work!
:trophy: Jun 3 2011, 08:32 AM
porscheless Andy,
Glad you got your car sorted; the OEM... Jun 3 2011, 09:11 AM
NORD Glad its fixed :headbang: :driving: Jun 3 2011, 09:00 AM
Andyrew Joe, where did you get your OEM switch? Porsche? Jun 3 2011, 09:16 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 02:13 AM |
