Giving up on ignition switches, Need wiring diagram, Bought a universal starter/ignition switch.. |
Andyrew |
Jun 2 2011, 08:40 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Ooook.. I just tightened the bolts down but left the wires hanging in the same location, same issue, starter cranked. So then i loosened the bolts a little so there was still contact but it was just like my test position, no issue, theb tightened it halfway and it jumps back and firth between wanting to start and not( keep ib mind there is plenty of contact between the wires and the switch at all these times, this would be an issue with the switch).
Now im going to remove the switch and tighten the bolts all the way down and check it with an ohm meter |
Mike Bellis |
Jun 2 2011, 09:00 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Have you tried to hot wire your car? Just to see if it will start? At least it will let you know for sure the ignition switch is bad.
Andyrew |
Jun 2 2011, 09:01 PM
Defective. The starter terminal worked itself loose and causes the issue
Mike Bellis |
Jun 2 2011, 09:05 PM
Damn Chinese parts...
Andyrew |
Jun 2 2011, 09:34 PM
Mike, yes i test all functions of the key switch when im doing the keyed testing.
New switch installed, tests good, took it easy on tightening. Everything seems just fine! |
Andyrew |
Jun 3 2011, 08:32 AM
NORD |
Jun 3 2011, 09:00 AM
Senior Member Group: Members Posts: 1,505 Joined: 14-September 04 From: Lynden Washington Member No.: 2,756 Region Association: Pacific Northwest |
Porschef |
Jun 3 2011, 09:11 AM
How you doin' Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Andy,
Glad you got your car sorted; the OEM's are available. Put one in my car last week and all problems starting ended. Joe |
Andyrew |
Jun 3 2011, 09:16 AM
Joe, where did you get your OEM switch? Porsche?
Lo-Fi Version | Time is now: 7th January 2025 - 10:20 PM |
