Saturday, 5 April 2025
3 Pages V < 1 2 3
> I need a radiator for my SBC conversion, Ideas? Part numbers?
Mike Bellis
post Sep 10 2014, 10:13 PM
Post #41
Resident Electrician
Temp sensor should be on the engine to know how hot it really is. Griffin is experienced in front engine, front radiator vehicles. Not 914 conversions.
I cant speak the tubing but it does sound small. Hot hot does it run? I'm running 1.125 ID hose and mine stays too cold most of the time. It only warms up if I'm driving on the freeway during a hot day.
speed metal army
post Sep 10 2014, 10:30 PM
Post #42
Waiting for the rain to stop...
Don't forget flow! The rad needs to be big enough, but you also have to move the coolant to cool properly. Mike Bellis is running a really cool water pump(Mike?What kind again?)Lots of GPH + properly sized rad and fans = cool. Im running a renegade LS cooling kit that also uses an electric pump, and I have zero cooling issues. The renegade kit works, but it can be done way cheaper. Also, the better you can shroud the inlet side of your rad, the better.
Mike Bellis
post Sep 10 2014, 11:20 PM
Post #43
QUOTE(speed metal army @ Sep 10 2014, 09:30 PM) *
Super cool pump... (IMG:style_emoticons/default/smile.gif)
CptTripps
post Sep 11 2014, 09:51 AM
Post #44
:: Punch and Pie ::
I used an aluminium double-pass VW Scirocco radiator. It's short enough to fit upright between the headlights.
mikesmith
post Sep 12 2014, 02:25 PM
Post #45
Not certain about Mike's setup, but I have the Dedenbear pump on my shopping list based on others' recommendations here...
3 Pages V < 1 2 3
- Lo-Fi Version Time is now: 5th April 2025 - 02:26 PM
