redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Dood! Haliburton would buy your heads! They can be drilled, and maybe...
(IMG:style_emoticons/default/wink.gif) Sorry man... me too. M |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
oh man... snapped a freakin rocker! at least you can put it back together even better than before this tine (IMG:style_emoticons/default/wink.gif)
sucks man..... |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
the sad thing is it only had about 4500 miles on it (IMG:style_emoticons/default/sad.gif)
Aaron Cox |
seanery |
I'm gathering all the bits for the sideshifter. I can't decide if I want to use the one on the floor or get it rebuilt. (IMG:style_emoticons/default/headbang.gif)
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Yuk. Sorry man.
aircooledboy |
Sweet Pea's 1st ride in daddy's "vroom -vroom" ![]() ![]() ![]() Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest ![]() |
QUOTE(seanery @ Jun 27 2004, 08:34 PM) I'm gathering all the bits for the sideshifter. I can't decide if I want to use the one on the floor or get it rebuilt. (IMG:style_emoticons/default/headbang.gif) I'm with ya there too bud. 2 complete side shifter set ups. Let me know if you need anything. |
Joseph Mills |
on a Sonoma diet now... ![]() ![]() ![]() Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 ![]() |
Sean,
I just dismantled two trannys this weekend. I'm pulling some syncros and a 5th gear to swap with my 3rd. If you need some side shifter parts they are yours for the asking. |
lmcchesney |
Member ![]() ![]() Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None ![]() |
Sean, do you think your geometry was off? Maybe 911 swivel foots this time.
L. McC |
JWest |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,663 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None ![]() ![]() |
Answers to a few of your questions:
The round thing that came off the top of the spring is called a retainer. There were two "keepers" (that you found one of) that pulled through the retainer. You need to find the other one (at least it is steel - get a magnet). The piston does not look too bad (from the dark pics) - you can probably deburr and reuse it, but the rust on the cylinders may have taken away that option (hard to tell how bad it is from the pics). The mark on the pushrod could be from hitting the pushrod tube or the pushrod tube spring retainer. The mark is shorter than the total amount the pushrod would move from cam lift, so I'm a little confused about that. Technically, you did not "drop" a valve, you bent a valve. Just to minimize confusion. |
seanery |
Thanks James.
The dent in the piston is a little worse than the pics show. At the very top it's removed/smashed a bit of material. If I'm going to the extent of tearing it down this far they are gonna get replaced. The rust is superficial surface rust, wipes away with my finger. The pushrod thing is bizarre. I just don't get it. I'm gonna replace the tubes and maybe that one pushrod. |
Lo-Fi Version | Time is now: 22nd April 2025 - 06:50 AM |
