For My Next Trick, Minimum Cost /6 Converion, An experiment to show low cost done well. |
Madswede |
Nov 22 2011, 08:59 PM
Flat Out Driver Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
I'm of two minds on this: one says go for it, make it a 2.4S ...the other says it might be better for the business to try your best to stay as close to budget as possible. I think you might find more business with "done right" /6 conversions as opposed to big six major engine upgrades, even if this example involves some top end work...that should be a standard caveat I think.
Series9 |
Nov 22 2011, 09:13 PM
Must resist........
rick 918-S |
Nov 22 2011, 09:22 PM
Hey nice rack! -Celette Group: Members Posts: 20,519 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Must resist........ If your still trying to stay within budget that may be a stretch... (IMG:style_emoticons/default/laugh.gif) |
Series9 |
Nov 22 2011, 09:29 PM
Must resist........ If your still trying to stay within budget that may be a stretch... (IMG:style_emoticons/default/laugh.gif) You're right. Those are just the tip of the iceberg. Then I'd need a 2.4 CW crankshaft, S heads, cams......... The machine work for the case alone is $$. |
Nov 22 2011, 09:33 PM
914-6 GT in waiting Group: Members Posts: 19,340 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Must resist........ If your still trying to stay within budget that may be a stretch... (IMG:style_emoticons/default/laugh.gif) You're right. Those are just the tip of the iceberg. Then I'd need a 2.4 CW crankshaft, S heads, cams......... The machine work for the case alone is $$. Running engine on pelican and part out this engine? |
Series9 |
Nov 22 2011, 09:41 PM
Series9 |
Dec 8 2011, 08:37 AM
I just sold the Bosch distributor that came with the engine for $325.
The cost of the engine in the first post has been adjusted accordingly. (IMG:style_emoticons/default/sunglasses.gif) I would like to spend that $325 on 1.5" headers. Anyone? |
Series9 |
Dec 15 2011, 02:43 PM
Found headers for $168.
Here's a picture of the custom intake I'm going to fit to this engine. It's based on 2.7 intake runners with a custom plenum. Attached image(s) |
Jeffs9146 |
Dec 15 2011, 03:08 PM
You going to add a pop-off valve for that?
May not need it since it is metal! (IMG:style_emoticons/default/confused24.gif) |
Ferg |
Dec 15 2011, 03:16 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Were the injector ports welded shut? Was that an intake that used a single carb set up?
How are you going to mount injectors? |
Series9 |
Dec 15 2011, 03:25 PM
Ferg |
Dec 15 2011, 03:28 PM
Were the injector ports welded shut? Was that an intake that used a single carb set up? How are you going to mount injectors? I may get other 2.7 runners and get the adapters for the late injectors. I purchased that manifold only for the plenum. Gotcha (IMG:style_emoticons/default/smile.gif) |
racerbvd |
Dec 15 2011, 03:29 PM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
Series9 |
Dec 16 2011, 07:24 PM
You going to add a pop-off valve for that? May not need it since it is metal! (IMG:style_emoticons/default/confused24.gif) Negative. |
Mike Bellis |
Dec 16 2011, 07:27 PM
I think the MS ECU I sold you is set up for a Ford MAF. Check the board add ons. Just in case you want to go that route...
Series9 |
Dec 16 2011, 07:39 PM
Mike Bellis |
Dec 16 2011, 07:42 PM
I think the MS ECU I sold you is set up for a Ford MAF. Check the board add ons. Just in case you want to go that route... When I get to that point, I'll call you. Many hours to be spent before I reach that point....... Right on... http://bgsoflex.com/megasquirt.html will help you too. Any Ford Mustang MAF can be used. It will be very helpful for tuning and drivability... |
Series9 |
Dec 17 2011, 08:51 AM
SLITS |
Dec 17 2011, 09:19 AM
Hah ... I bought one dem der kits ... makes great wall art (my HPV-3B won't communicate with my 'puter).
I do like the moto on the pulley ... had to install mirrors to see it while I am driving. (IMG:style_emoticons/default/lol-2.gif) |
Series9 |
Dec 17 2011, 10:01 AM
Hah ... I bought one dem der kits ... makes great wall art (my HPV-3B won't communicate with my 'puter). I do like the moto on the pulley ... had to install mirrors to see it while I am driving. (IMG:style_emoticons/default/lol-2.gif) I'm going to use an EDIS6 and it will talk to the MSII. |
Lo-Fi Version | Time is now: 30th June 2024 - 09:30 PM |
