Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
If you're using the 911 oil cooler you'll need to mod the fitting that otherwise won't clear the trailing arm... I'm aware of that. I'll modify it. You do know that this isn't my first /6 conversion..... (IMG:style_emoticons/default/shades.gif) |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
Series9 |
You do know that this isn't my first /6 conversion... Yes. But for a lot of people reading along, it might be _their_ first /6 conversion... Fair enough. I have a different way of converting a cooler that involves completely removing the original supply tube and clearancing the bottom of the cooler between the two lower mounting holes. I then take steel JIC fitting with -16 male on one side and NPT on the other. Put that in the lathe, turn down the NPT side to accept the supply seal on the engine. Fab a bracket that also bolts to the two bottom oil cooler bolts and weld it to the new fitting. I'm thinking about making a small run of them and selling them to people doing conversions. I'll take pictures. I found pics from the TurtleGirl build. Attached image(s) ![]() ![]() ![]() |
rktmn247 |
Irish Green with GT envy! ![]() ![]() Group: Members Posts: 347 Joined: 18-August 05 From: Mililani, HI Member No.: 4,612 Region Association: None ![]() ![]() |
You do know that this isn't my first /6 conversion... Yes. But for a lot of people reading along, it might be _their_ first /6 conversion... Fair enough. I have a different way of converting a cooler that involves completely removing the original supply tube and clearancing the bottom of the cooler between the two lower mounting holes. I then take steel JIC fitting with -16 male on one side and NPT on the other. Put that in the lathe, turn down the NPT side to accept the supply seal on the engine. Fab a bracket that also bolts to the two bottom oil cooler bolts and weld it to the new fitting. I'm thinking about making a small run of them and selling them to people doing conversions. I'll take pictures. I found pics from the TurtleGirl build. That's a great idea! Let me know how much $. Thanks for doing this thread! |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,645 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
joe
let me know if you do make a run of these I'll take one! brant |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,335 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I would probably be in for one once you come up with pricing. I have a good core. thanks, Mark
Series9 |
joe let me know if you do make a run of these I'll take one! brant The good thing about doing it this way is that you don't have to send me the cooler. The mod to the cooler can be done by the customer because it's not super precise work. I'll have to make some before I have a price. It would come as an adapter fitting and two longer studs to replace the shorter stock ones in the engine case. |
Does this change the length of the hose required to connect to the cooler?
Series9 |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Series9 |
Thanks, but I'm pretty sure I have one on the way. |
Does this change the length of the hose required to connect to the cooler? Yes. It assumes you are making custom hoses. If you're already converted, you would have to remake the supply line. Factory hoses wouldn't work. Probably not for me then. |
wertygrog |
wertygrog ![]() ![]() Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California ![]() |
I'm down for the oil cooler mod too!
p.s. love the thread! (IMG:style_emoticons/default/beerchug.gif) |
Series9 |
I'm down for the oil cooler mod too! p.s. love the thread! (IMG:style_emoticons/default/beerchug.gif) I was giving this a lot of thought yesterday. I seem to remember that Liz's had a clearance issue between the hose fitting and the bottom of the cooler. I had to tighten the hose on the engine fitting and then install the two pieces on the engine. So, I'm going to make the mod fitting to accept the hose directly via crimp at a hydraulic shop. I'll either deliver the fitting for you to add hose and crimp or deliver the fitting with a pig tail hose already crimped. To drain the oil, simply remove the two nuts holding the fitting to the block. I'm going to need CAD services so I can have the flange laser cut. Anyone? |
Series9 |
What have we here? (IMG:style_emoticons/default/unsure.gif)
These might have a bad rep, but I have one that's been holding the 3.6 in the RS firmly in place for six years now. No longer a freebie. I paid $90 delivered. Attached image(s) ![]() |
Series9 |
Bonus!
The MS-II I purchased for $85 has a 3.0 board: Attached image(s) ![]() |
What have we here? (IMG:style_emoticons/default/unsure.gif) These might have a bad rep, but I have one that's been holding the 3.6 in the RS firmly in place for six years now. No longer a freebie. I paid $90 delivered. How does that work? Welded to the original bar? Rich |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,446 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
Yeah, how does that mount work? That's one of the parts I have yet to buy for my conversion...
Series9 |
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
joe - between us : )
what HP are you shooting for with this $5k project? 200+- vs a raby 2056 for $5k producing 130-140HP +- jim |
Lo-Fi Version | Time is now: 28th June 2024 - 05:54 PM |
