For My Next Trick, Minimum Cost /6 Converion, An experiment to show low cost done well. |
Series9 |
Aug 11 2011, 04:50 PM
Does that $5k Raby engine include Carbs/FI or is it just a long-block?
Anyway, I'm shooting for 140hp to start. The $5k build budget will include digital FI and distributorless ignition. A little down the road, I'm going to open up the engine and swap in some S pistons, Nikasil cylinders and S cams. It'll end up around 190hp. |
jimkelly |
Aug 11 2011, 05:07 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
good point - though the average 6 conversion using all STORE BOUGHT bits would probably cost $5k (tin/exhaust/oiltank/throttlelinkage/etc/etc) excluding engine and labor?
the 2056 - does not come with ignition or exhaust or engine core or a bunch of other bits. 125 HP without tangerine exhaust. so i guess $5000 + type4 core + mallory dist + exhaust + carbs = $7000 +- so i guess the question is - does one want to spend 50% more to do a six conversion - not on the cheap. http://www.914world.com/bbs2/index.php?showtopic=42456 last question - can carbed 6 get thru emissions relatively easily? in my state all 914 must go thru emissions - thus i will stick with low cost V8 or possibly suby conversions. that said, who would not want a high reving six ; )) |
JmuRiz |
Aug 11 2011, 06:48 PM
914 Guru Group: Members Posts: 5,488 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Cool to know that engine mout can handle you 3.6...makes me think it'd work on my 2.7 (hmmmm)
Also I'm interested in what you have planned for the EFI and distributor-less ignition. I didn't even think those were possible on a budget. Wish there was a builder like you closer to me... |
Aug 11 2011, 07:48 PM
914-6 GT in waiting Group: Members Posts: 19,507 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
good point - though the average 6 conversion using all STORE BOUGHT bits would probably cost $5k (tin/exhaust/oiltank/throttlelinkage/etc/etc) excluding engine and labor? the 2056 - does not come with ignition or exhaust or engine core or a bunch of other bits. 125 HP without tangerine exhaust. so i guess $5000 + type4 core + mallory dist + exhaust + carbs = $7000 +- so i guess the question is - does one want to spend 50% more to do a six conversion - not on the cheap. http://www.914world.com/bbs2/index.php?showtopic=42456 last question - can carbed 6 get thru emissions relatively easily? in my state all 914 must go thru emissions - thus i will stick with low cost V8 or possibly suby conversions. that said, who would not want a high reving six ; )) I don't think the 5K engine is still 5K. I'm just guessing...I could be wrong. I think all these projects need a flexible budget. At least that's my excuse for getting in over my head on mine. |
John |
Aug 11 2011, 08:25 PM
The only way to make a 5k budget on a 6 conversion requires one to do all their own labor (for free) AND fabricate most of the bits themselves.
Patience will bring deals, but this patience may take years in order to gather all the required bits for rock bottom prices. I didn't end up re-doing anything on my conversion, but I do need to pull the engine and re-seal the chain housings, and it could stand to have the heads rebuilt, but I did my 3.2 conversion 5+ years ago. The only way I was able to keep my budget in the 5k range was that I sold off most all my -4 parts and I also fabricated conversion parts and sold them. I did engine sheet metal, shift rods, block off plates, engine mounts, etc. |
Aug 11 2011, 08:36 PM
I'm doing mine for $5K. I bartered the rest from Eric Shea for an NOS ash tray.
Series9 |
Nov 17 2011, 08:23 PM
It's been a while, but the 2.2 is finally here. $520 delivered:
a914dude |
Nov 17 2011, 08:27 PM
Wanker Group: Members Posts: 247 Joined: 18-September 10 From: Saskatoon Member No.: 12,191 Region Association: Rocky Mountains |
good point - though the average 6 conversion using all STORE BOUGHT bits would probably cost $5k (tin/exhaust/oiltank/throttlelinkage/etc/etc) excluding engine and labor? the 2056 - does not come with ignition or exhaust or engine core or a bunch of other bits. 125 HP without tangerine exhaust. so i guess $5000 + type4 core + mallory dist + exhaust + carbs = $7000 +- so i guess the question is - does one want to spend 50% more to do a six conversion - not on the cheap. http://www.914world.com/bbs2/index.php?showtopic=42456 last question - can carbed 6 get thru emissions relatively easily? in my state all 914 must go thru emissions - thus i will stick with low cost V8 or possibly suby conversions. that said, who would not want a high reving six ; )) Jim, the original 914/6 had carbs. What else could they compare it to? (IMG:style_emoticons/default/confused24.gif) |
bcheney |
Nov 17 2011, 08:57 PM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
It's been a while, but the 2.2 is finally here. $520 delivered: I bought my original -6 engine for this same dollar amount 4 years ago. I had it rebuilt to 2.2 E-Spec. Still working to get it installed...so many things get in the way...I hope to complete the install by this Christmas! Glad to see you're making progress!! |
sixnotfour |
Nov 17 2011, 08:59 PM
914 Wizard Group: Members Posts: 10,517 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Wow -6 oil cooler and flywheel. does it have a bosch dizzy too ?
John |
Nov 17 2011, 09:03 PM
Steve |
Nov 17 2011, 09:07 PM
914 Guru Group: Members Posts: 5,682 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Sorry for the hijack, but I have not seen any longevity numbers for a big type four. I could not get more than 15k miles out of my 2.4 liter four (103x71). I had it overhauled twice before giving up and going to a six back in 1986. For the cost of rebuilding the four twice I could of had a six in the first place. My stock 3.2 motor has over 150k miles on it. It runs great and does not leak any oil.
John |
Nov 17 2011, 09:11 PM
Sorry for the hijack, but I have not seen any longevity numbers for a big type four. I could not get more than 15k miles out of my 2.4 liter four (103x71). I had it overhauled twice before giving up and going to a six back in 1986. For the cost of rebuilding the four twice I could of had a six in the first place. My stock 3.2 motor has over 150k miles on it. It runs great and does not leak any oil. Amen. |
monkeyboy |
Nov 17 2011, 09:19 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Sorry for the hijack, but I have not seen any longevity numbers for a big type four. I could not get more than 15k miles out of my 2.4 liter four (103x71). I had it overhauled twice before giving up and going to a six back in 1986. For the cost of rebuilding the four twice I could of had a six in the first place. My stock 3.2 motor has over 150k miles on it. It runs great and does not leak any oil. Amen. Not sure what the specs on your motor was, but Jake is claiming 100,000 miles. You aren't getting that for $5,000 though. |
JmuRiz |
Nov 17 2011, 09:51 PM
A 6-cyl for $520, wow....with the 914 cooler mod already on it? Amazing, I'll post my $ numbers tomorrow when I can see my spreadsheet.
Steve |
Nov 17 2011, 10:16 PM
Sorry for the hijack, but I have not seen any longevity numbers for a big type four. I could not get more than 15k miles out of my 2.4 liter four (103x71). I had it overhauled twice before giving up and going to a six back in 1986. For the cost of rebuilding the four twice I could of had a six in the first place. My stock 3.2 motor has over 150k miles on it. It runs great and does not leak any oil. Amen. Not sure what the specs on your motor was, but Jake is claiming 100,000 miles. You aren't getting that for $5,000 though. It was a stock 2.0 liter with 103mm cylinders and the stock 71mm 2.0 crankshaft. I was also running 44ida webers on it. I know there are not too many people recommending 103mm cylinders these days. The technology has improved allot since the early 80's. The first 2364? four sucked a valve and the second overhaul broke a ring. Both within 15k miles. Maybe my mechanic at the time didn't know what he was doing. He used to build type 4 sand rail motors. I paid $5200.00 for my 3.2 liter six, 11 years ago. Its actually my second six. The first six was a 2.7 with a top end overhaul. I installed it back in 1986. It had a top end overhaul when I installed it and it lasted about 100k miles before it started pulling head studs. It never left me stranded. What size motor is Jake claiming 100k on? |
Steve |
Nov 17 2011, 10:18 PM
Sorry for the hijack, but I have not seen any longevity numbers for a big type four. I could not get more than 15k miles out of my 2.4 liter four (103x71). I had it overhauled twice before giving up and going to a six back in 1986. For the cost of rebuilding the four twice I could of had a six in the first place. My stock 3.2 motor has over 150k miles on it. It runs great and does not leak any oil. Amen. Too funny. I thought I was a fan of the 3.2 motor, you have two of them. (IMG:style_emoticons/default/beerchug.gif) |
0396 |
Nov 18 2011, 09:12 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Series9 |
Nov 18 2011, 09:32 AM
Series9 |
Nov 22 2011, 08:30 PM
I started a leak-down test on the engine the other day. Yeah right. Wishful thinking.
#1. 50/100 #6. 0 #2. 0............ Returned the test tools to the box and got a flashlight to have a look in the intakes at the valves. MMMMMmmm rusty. At minimum, the heads will need guides and facing, at least a few valves (maybe all of them), hone cylinders, rering, etc. I'm VERY bad at doing the minimum to get it going. I've already looked at JE pistons and other $$$$$$ parts. If there's good news, it's that this is a T engine. That means that is has a non-counterweighted crankshaft. That means there's no point in going crazy on the top end when the bottom end won't support the revs. If I can get away with leaving the bottom end together, I will probably be able to hold myself back. If not, the budget is going to get scrapped as I turn it into a 2.4S. Let me think about it. |
Lo-Fi Version | Time is now: 20th September 2024 - 05:03 PM |
