3 Pages V < 1 2 3 >
> 914 trailer pics (single or dual axle), Post your 914 trailer pictures here
MJHanna
post Jun 30 2004, 06:29 AM
Post #21
Does this 911 make my butt look big?
open trailer
MJHanna
post Jun 30 2004, 06:30 AM
Post #22
frt view
MJHanna
post Jun 30 2004, 06:36 AM
Post #23
current trailer in background
GaroldShaffer
post Jun 30 2004, 08:41 AM
Post #24
You bought another 914?
You did a nice job on your trailer. One question, with it being a single axle do you need to tow the car backwards? Just wondering if you have enough tongue weight with teh car facing forward?
Your trailer is exactly the size that I'm looking for. Only other thing is I would want to be able to put wood side rails on when using to haul other things like landscape supplies (dirt, multch) and such.
dheinz
post Jun 30 2004, 03:47 PM
Post #25
cross member
This is my rig.
dlee1967
post Jun 30 2004, 05:08 PM
Post #26
V8Lurker
Garold, I pull the 914 facing forwards. I calculated the center of gravity of my car (the heavy V8 one) and positioned the axle at what I thought would be the balance point with 75 lbs of tongue weight. As it turns out I have about 125 lbs as I was a little off on the calcs and I added the floor jack to the tongue. Well at least I was close..... The position of the axle was 7'4" from the front edge of the flat bed portion of the trailer. You could always weld on stake bed mounts on the sides of this type of trailer and insert the side rails only when needed. They are available at most trailer stores for about $1 each. David Lee
Mike T
post Jun 30 2004, 05:44 PM
Post #27
can't 'member
Here's my trailer. It started out as an open center. Diamond plate was added to the upper portion but the beaver tail is still open. The triangular plate in the front center is for the winch. The winch gets it's power from the light plug. Pretty slick. (IMG:style_emoticons/default/cool.gif)
Mike T
post Jun 30 2004, 05:47 PM
Post #28
can't 'member
rear shot.
VegasRacer
post Jun 30 2004, 07:59 PM
Post #29
ELVIRA
This trailer had an open pit. Plywood was added to the center section. My favorite option is the extra long pull-out ramps. I will never own another trailer where you have to carry the ramps.
banderson
post Jul 1 2004, 06:58 AM
Post #30
I was thinking of building one a while back. I would want the smallest 914 worthy trailer to double as a utility trailer. Single axle and brakes. I like the idea of surge brakes because they work on any tow vechical.
Are electric brakes better and how do you adjust them?
majkos
post Jul 1 2004, 07:40 AM
Post #31
Elec.brakes are controled by an leveler on a elec.brake thingie(I don't know what they're called!) which is hooked up to the brakes via brake lights.This devise also has an adjustment on the side to control braking power,too much? turn it back,not enough? turn it up.I 'love these things 'cause if you're hauling as* and the trailer starts to swing,reach down and gently swing the leveler to slow the trailer before you brake your truck,no jack-knifing! Not that it happens to me,just heard too many horror stories.
joea9146
post Jul 1 2004, 09:12 AM
Post #32
This is the brake box that I use for the electric brake setup.
Brake_Box
morph
post Jul 1 2004, 07:35 PM
Post #33
quality parts builder
scored some fuchs (IMG:style_emoticons/default/biggrin.gif) but here is some photos its alittle dirty but its a work trailer,i bought it and the truck to tow 914s home.and ill be using it for a race car as well .me and my friends joke about it bieng the appearance & perfomance"drag truck" because i use it to drag home 914s (IMG:style_emoticons/default/laugh.gif)
morph
post Jul 1 2004, 07:37 PM
Post #34
another shot
jdogg
post Jul 2 2004, 08:36 AM
Post #35
I am shopping trailers right now myself. What is everyone's opinion regarding a wood deck vs. diamond plate steel deck?
MJHanna
post Jul 2 2004, 09:08 AM
Post #36
Wood rots... steel lasts longer if you keep it painted. scarie when you drive your car on a wood deck and it start to drop the car (IMG:style_emoticons/default/wacko.gif) Steel is heavier and has more structural strenght.
GaroldShaffer
post Jul 2 2004, 09:17 AM
Post #37
What is your plan for this trailer? Car hauler / utility trailer? I have a 6 x 8 Tilt bed utility that I used to haul the riding mower to the inlaws and for all the yard work crap. It has a wood deck and sits outside all year. After 6 yrs of use I will need to replace the wood deck this winter.
I would say a wood deck is fine for a once in the while car hauler as long as you keep the maintance up on it. If you are using it all the time I would then get one with a steel deck. I would really like to get myself one of those feather lite aluminum ones.
morph
post Jul 2 2004, 10:50 AM
Post #38
the cost for my trailer new was only 1199.00 .
i shopped around the steel decks where alot more.the deck space is 7x14 plenty of room for a 914
tires and a tool box.but yes the wood decks do need to be replaced in time,but my dads back hoe trailer was a wood deck and was untreated and abused and it lasted 11 years.and it wasnt replaced due to the back hoe falling though it it just look like hell (IMG:style_emoticons/default/wink.gif)
TimT
post Jul 2 2004, 02:53 PM
Post #39
retired
wood rots, steel rusts
wood is lighter, steel is heavier
a nice compromise is a steel deck trailer, but dont get one with a full steel deck. Get one with a split deck, its a bit lighter
URY914
post Jul 3 2004, 09:31 PM
Post #40
Aluminum, Dude. The best of both worlds-light and rust free.
3 Pages V < 1 2 3 >
- Lo-Fi Version Time is now: 27th December 2024 - 10:27 AM
